Question about Dell DJ MP3 Player
Headphone jack I only get audio when i press the jack to the side. How can I fix this?
  • squeeks Jan 04, 2008
    Took apart casing and the input jack is cracked. need to find a replacement part.
I have the same problem with my DJ 30, and it exists with several different types of headphones.
I am thinking about trying a mono to stereo adaper, where the plug is mono, and the ear phones are stereo. I don't know if it will work or not.
Posted on Dec 23, 2007
I can't get sound through my headphones on my Bravia kdl-52xbr5 tv. First time I have tried to hook up the headphones which are sharper image wireless
I take it the headphones are charged up and known to be in good working order? Are you using the 3.5mm headphone jack on the side of the TV or the white and red RCA jacks labeled AUDIO OUT (VAR/FIX)? If using the headphone jack the TV should shut off the internal speakers and output to the headphones. If using the mentioned RCA jacks you need to go into the audio options settings and set to Audio System. Also under audio settings, Audio Out, you can pick Fixed or Variable. If you opt for Fixed you will use the headphones to adjust the volume. If you opt for Variable you can control the headphone volume and muting using your TV remote control. Just make sure you have the headphone volume turned up adequately.
Dec 16, 2016 | Sony KDL-52XBR5 52 in. LCD HDTV
No sound from the Ipod jack side of the bose L1 system
There is no iPod jack side output (or headphone output) on any of the Bose L1® Systems.
If you are seeing an image that looks like an iPod, that is the iPod INPUT on the Bose Compact.
Here is more information about the Bose L1® Compact
L1 Compact Bose L1 Encyclopedia FAQ Wiki (fixya has picked up the wrong image - but just click the link and it will take you there).
Oct 31, 2013 | Bose Wave music system large Remote...
IRiver E100 headphone jack
The connector is defective - probably just wear and tear
Aug 15, 2017 | iRiver E100 Digital Media Player
We are trying to hook our TV up to our computer to use it as a monitor. What cords do we need to do this besides the normal monitor cord?
if you want audio as well, it will depend on what kind of audio connection your tv has next to the VGA (computer monitor) connection. If it looks like the normal RCA audio, (red and white plugs) you will need to get a male headphone jack (to plug into your computer headphone or speaker out jack) to stereo RCA cable so you would have a headphone jack on one side of the cable and a red and white plug on the other side. Now if your TV just has what look like a headphone jack next to the VGA (computer monitor plug) you will need to buy a male to male stereo headphone jack cable. for both of these, just make sure the cable you get it long enough, or buy an extension.
Mar 21, 2011 | Sansui HDLCD1908 19 in. LCD TV
The vizio e322vl headphone jack is not documented by Visio. There is an "Audio" spot next to "RGB PC" and I tried various jack sizes b none works. If you have a soulution, can you...
that audio jack is input only it is stereo jack to connect from the comptuer to the tv when using the RGB input. most headphone jacks if they are there would be on the side of flat panel tvs. otherwise the audio output may be digital(optical) or normal rca (red and white) that you can hookup to the headphone system.
Dec 23, 2010 | Vizio E322VL 32 in. LCD TV
Sound
Except for the Headphone jack (mini-jack) and the coax audio, all of the audio jacks are audio IN. Which jack do you have your speakers connected to? The headphone jack is on the side next to the coax connection (ANT) and the coax audio out is at the bottom of that set of side jacks. The headphone mode should automatically cut the TV speakers. The coax audio out is set up by pressing Menu and then using the down arrow to highlight Audio. Then press the right arrow button to enter the submenu. Press the up or down arrow to reach SPDIF. Then you use the left and right menus to select PCM, Digital Dolby or OFF.
I hope this helps.
Jul 10, 2010 | Element ELC-HS321 32 in. LCD TV
I am having the same problem with a twist, sound works from the fm and headphone but only from the right side no left audio. I have the 760 and it only has one speaker and my guess it that it gets its feed...
If you use the headphone jack a lot and your missing the audio from the speaker and one channel from the headphone jack, then it's possible that some of the headphone jack connections have broken off of the PC board. The audio goes to the speaker through the headphone jack.
Please see this link for more info and read the section about the headphone jack.
http://www.sharc.net/gps_audio_repair.htm
- Jim
Dec 19, 2009 | Garmin Nuvi 760 Car GPS Receiver
Sony Vaio VGN 'B series' - broken headphone jack.
Hi there, your question has two way you can fix it:
1) see speaker jack circiut on your motherboard, picture here
there are 5 pins to the jack socket, you may just find out 2 and 3 pin which is stereo audio output lines, and also need a ground 5 pin. then connect 3 wires go outside speaker. this way quite tough for you.
if you cannt do this way go next
2) find a USB audio card instead of onboard one. this is very easy.
reference here:
http://shop.ebay.ca/?_from=R40&_trksid=p3907.m38.l1313&_nkw=usb+audio+card&_sacat=See-All-Categories
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 24, 2009 | Sony VAIO® VGN-N130G/B PC Notebook
Soundcard problem on D530 SFF
Sounds like the audio return wires aren't connected. On the motherboard, there is a sound jack on the back left side of the mobo. The jacks from the front audio panel connects to it. Both the Left and Right channel have an out and an in connector. These send the signal to the headphone jack on the front panel and return the signal to the rear output jack if a headphone is not connected. Look for looe or broken wires. The other spot to check is the front headphone jack. If a headphone plug was pulled out or pulled sideways, it could break the solder joint on the PCB panel or break the shunt feeding the singal to the rear jacks. Hope this helps.
Ron
Apr 13, 2008 | HP Compaq Business d530 PC Desktop
Headphone jack does not work
your headphone jack is corrupted in internal, cause when you put your headphone jack in internal you activate the switch to switch speakers to headphone and this switch is out of order.
you have to go to a specialist to replace your headphone jack on your amplifier. sorry for this bad news. ;)
Mar 31, 2008 | Onkyo TX-8511 Receiver
Dell DJ MP3 Player Logo
81 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
