Question about Refrigerators
I have a Prima PBF115 refrigerator, and it always seems to be too cold. In fact it freezes a lot of my food. I can't find a manual, but I need to figure out if ''1'' or ''7'' on the temperature gauge is the cooler setting.
  • 20 Answers
1 is warmer, 7 is colder.
Posted on Sep 25, 2009
What could cause the fresh food section of my refrigerator to be too warm?
UR COLD CONTROL THERMOSTAT, UR AIR FLOW VENT, UR THERMISTORS, A EVAPORATOR FAN NOT WORKING OR OBSTRUCTED
Feb 24, 2015 | Refrigerators
Our amana side by side works well, in fact too well. It freezes salad greens in the vegetable drawers and now freezes things like yogurt on the open lower shelves too. We've turned dow the settings to...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Apr 07, 2011 | Amana SXD524VW Side by Side Refrigerator
My KitchenAid Subra fridge. it seems like the freezer is always producing cold air. It keeps the freezer so cold that it freezes the drain plug were the condensation is suppose to drain out of the freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 23, 2011 | KitchenAid Refrigerators
My refrigerator model no is RB1855SW 's always running, the food in the refrigerator is frozen, the temperature inside is below zero while the display shows +4 degree.
heatman101
Feb 24, 2011 | Samsung Refrigerators
Jenn-Air JCD2389G Side by Side Refrigerator Damper Door fell off. How do I put it back and what will happen if I cant?
Not knowing exactly how you broke it off, its hard to say just how its supposed to go back on. Since these are usually screwed into place, or in some cases its a snap tight fit, something is definitely broken, and you will likely need to replace the damper door. If you do not fix this properly, you will not be able to adjust the fresh food temperatures, and in fact you may freeze your refrigerated food, or it may be not cold enough to keep food fresh at all.
Feb 01, 2011 | Jenn-Air JCD2389G Side by Side...
Fridge temperature is too cold, food id freezing. freezer seems fine. even adjusting the fridge temperature up to 1 does not change the temperature. seems to be stuck at 30F.
heatman101
Dec 10, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Refrigerator is freezing my produce items (veggies&fruits) Freezer side is thawing and ice is melting waterfalls over and down all other levels. Freezer & frig. settings have always been set on...
heatman101
Dec 10, 2010 | Kenmore 25.1 cu. ft. Side-By-Side...
Fridge is freezing everything!
There is a flap that directs the air from freezer to fridge. Sometimes this flap can stick Or the actuator that controls the flap can go out. Same with autodefrost timer which seems to give a lot of people trouble. Thermostat is at the top, uncirculated cold air sinks, food in the bottom of the fridge freezes.
Sep 09, 2009 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool gold conquest refridgerator
if u find out let me know. when we turn both frig/freez switches off the frig light comes back on flashes to number 6. it still seems cold be like this 2-3 days the food still seems cold. good luck. jax, fl
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
My fridge makes loud popping noises and is over cold (freezing the things in the fridge & frosting up the freezer, when it is a frost free freezer)
Check in your owners manual for a "noise" section to see if you can identify the source. Refers make lots of unusual noises so it helps to understand if they are normal or not. Over cold in the fridge may be due to the air damper system being stuck open or food placed too close to the air duct outlet. Frost in the freezer can be due to moisture getting inside from a bad door seal, etc.
Sep 11, 2006 | LG LRTN19320 Top Freezer Refrigerator
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
