Question about HP Deskjet 5740 InkJet Printer
Almost 1/2 of the paper out during paper feeding
    Scholar:
  • HP Expert
  • 199 Answers
Whether it is happening at the time of cleaning the cartridge.
Posted on Sep 25, 2009
MY PRINTER SAYS ...MP TRAY PAPER IS EMPTY DURING PRINTING
Put more paper in the Manual Feed tray to allow it to continue or change the settings to bypass Manual Feed Options.
Sep 12, 2014 | Dell 2355dn AllInOne Laser Printer
Getting a error message JAM11 on copier CS-1815?
A paper jam in the
paper feed section
is indicated during
copying or printing
(no paper feed from
the cassette).
Jam code 11
Paper in the cassette is
extremely curled.
Check if the feed roller is
deformed.
Defective registration sensor.
Check if the feed clutch
malfunctions.
Electrical problem with the
feed clutch
The above is taken from the sm
Also the feed tyre needs cleaned / changing and or cassette springs need stretching !!!
Dec 03, 2013 | Copystar CS-1815 Printer
Documate error 8
Hello.
I am a Support Engineer with Xerox Scanners.
E8 is a Paper Jam error that could be caused by:
- paper crumpling during scan.
- paper is multi-feeding all at once instead of feeding separate.
- scanner continuously tries to feed after paper has fed through.
if the paper is crumpling during the scan, make sure the inside of the scanner is clear of any obstructions. use the paper guides in the ADF tray to keep the paper straight when feeding in.
if the paper is multifeeding while scanning, fan out the pages before inserting them into the scanner. if problem persists, try cleaning the rollers with rubbing alcohol and a lint free cloth.
if scanner tries to continually feed after the paper feeds through, the ADF tray will need to be reseated. open the scanner and remove the ADF tray at the top. line up the 4 keys at the bottom of the tray with the 4 corresponding key slots inside the scanner. push the tray back until it clicks into place.
We also have an extensive support site and knowledgebase at
http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Jan 28, 2013 | Xerox DocuMate 162 Pass-Through Scanner
HP4680 not feeding paper during alignment
Check and clear any piece of paper is on the paper feeder sensor will resolve your problem.
Revert back for more assistance.
Thank you for using Fixya.
Mar 11, 2010 | Office Equipment & Supplies
Paper feed error message. spits it out fast and
Your printer has a fail safe mechanism that pushs the paper that it's processing out to prevent any other jams during the printing process. Your rollers must have something jamming it's movement during printing. You will need to open the printer through the panels on the back, front, and side to ensure that you see the rollers and remove any paper or debrise blocking hitched on the rollers or in the printer. You may also want to ensure that the holders on the sides of the paper tray where the paper comes in are lined up correctly. Also, make sure not to pack the paper tray to capacity. Only use the tray half full.
Nov 29, 2009 | HP Designjet 70 InkJet Printer
I try to print and the printer just prints the first of several pages and the online/error red led comes on.
Try to pull the paper tray out and clean the feed roller inside with alcohol or water.Usually,paper dust on the feed roller causing it to slip during paper feed and printer jams.
Oct 08, 2009 | Samsung ML1740 Laser Printer
Konica 7025 paper jam
Does this happen when he orginals go thur the document feeder? How does the copy look if the orginal is placed on the glass. Vertical feed problem mite be dirty rollers or dirty clutch,
Aug 13, 2009 | Konica Minolta Office Equipment & Supplies
Paper wont feed
Make sure that the printer track is free of any torn paper. Make sure that the tractor feeds themselves are free from debris. Turn it off during this check.
Apr 24, 2009 | Office Equipment & Supplies
The machine gives a false error message.''misfeed A :internal path
Pull out paper cassett and look for paper in the feed section. Fold a sheet of paper in half and using the blue lever inside right side door feed paper between feed rollers. Make sure you do the whole width of feed section. There might be a small piece stuck you can't see.
Mar 11, 2009 | Ricoh Aficio CL7000 Laser Printer
HP Deskjet 5740 InkJet Printer Logo
73 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
