I have been giving a LX700 system with Phillips DVD, I have a Set Top box, a Teac TV with a Yellow, Red & black RCA jacks. How do I hook it all up? please help.
  • jsc52438 Sep 25, 2009
    The DVD doesn't have a Ant.in or out so thi sconfiguration will not work.
    Thanks
    President:
  • 1,462 Answers
To be clear to want to connect your LX700 system with PHILIPS dvd player and your TV tuner,
SOLUTION:
Here is the diagram of your connector
You have to get seperate Cable called RCA to TRS adapter
After getting thiis adapter you can connect your red and black RCA together and you get single 3.5mm jack connect this to Audio 2 shown in figure
And Connect the Yellow to Video/Y
Do the came thing dor your DVD player and connect the samt to input 3 or 2, IF your DVD has SVideo cable you can use that
Please leave me comment if you need furthur assistance
Posted on Sep 25, 2009
    Brigadier General:
  • 4,090 Answers
OK from the top.
Set top box
ANTenna IN holds the antenna from the wall
The ANT OUT goes to ANT IN on theDVD Ant OUT on DVD goes to to TV ANT IN.
The 3 RCA plugs go from the STB audio and video OUT to the DVD audio and video in Usually YELLOW is video RED and white are AUDIO. and they go to Audio in
DVD has audio and video out RYW plugs and they connect to the TV as Audio and video IN . Thhe SET TO BOX sets the AV channel on the TV to play back anything that is played from the DVD and the channel to record from.
so you need 2 sets of RCA plugs and 2 coax connection cords and plugs other than the main antenna from the wall
Please rate the help++++Thanks for using FIXYA
I'm trying to hook up my DVD player to my TV but my TV doesn't have a yellow jack only red and black
If your TV doesn't have a Video IN jack (Yellow) then you would have to attach your dvd by antenna (Coaxial) cable. What does the DVD have on the back ? EG: Video Out is Yellow, Red is Right Audio, White is Left Audio. If your DVD has Ant in & Ant Out you can use a coaxial cable from Ant out to your tv's antenna In socket and put your antenna cable (from your wall socket) to Ant in on the dvd. Turn on the dvd and put your tv on a blank station and tune your tv till you see the dvd screen . lock it in and that becomes your DVD channel to watch your dvd's.
Hope this is some help.
Sep 07, 2015 | RCA Televison & Video
How to hook up an old RCA 14 inch tv to DVD
Easy. All you have to do is to make sure that the DVD player is old the older types that have RCA connectors at the back of the DVD. Latest DVD may have RCA connections but I am not sure if it can send digital signal directly to the analog TV. Try this and see what happens. if your TV is old and does not have Component Video (Red/Green/Blue) RCA sockets (input) but has standard Pal/NTSC sockets (Yellow/Red/Black) hook up the yellow, red and black plugs into a DVD (out) RCA sockets of same colour, then hook up the other end of the cable in the (in) RCA sockets at the rear of the TV.
If it works, then all is well. If it doesn't work, then you have to hook up the cable from the DVD to the (input) RCA sockets of a Set Top Box, so that the Set Top Box will convert the signals for the analog TV. Just pay attention to the inputs and outputs at the rear of them.
On your DVD - plug the RCA cable to the (OUTPUT) RCA sockets. On the Set Top Box - plug the connectors in the (IN) RCA sockets and then use another cable connected to the OUT RCA's of the Set Top Box, then connect the other connectors to the (IN) of the TV RCA sockets. Hopefully you get the picture on what I mean.
Sep 01, 2014 | Televison & Video
Connect to a Panasonic home theatre/dvd player
You must hook up the DVD player in separate jacks into the TV with red, white, and yellow cables. To play the DVD player you must set the input in the TV menu
Dec 06, 2011 | LG 55 55LK520 LCD TV
I no longer have the manual for the product and I want to hook it up to my TV via a cable box; we have Charter cable. The cable box is a Motorola and it says Dolby digital on the front of the cable box. ...
The white, yellow, and red RCA phono jacks on the back are called VGA inputs and outputs. The Red is
right channel audio, The white is for left channel audio. The yellow is the video. Look carefully on the back of the unit and the input jacks and output jacks should be clearly marked.
There are several other input/output ports. One is HDMI which is flat and wide. Another, not common, is composite video which uses the three above mentioned RCA jacks as indicated plus two more colored jacks. This combination gives a better picture.
A third option is a screwed on cable for input and output. This is called a "F" connector and is only used if the receiver equipment has a built in tuner. The output of a cable box is usually an "F" connector and the above described outputs
If you connect the cable box to the DVD player input and the DVD player output to the TV input, you often must have the DVD player turned on so the signal will feed to the TV.
If the TV has multiple inputs, it is best to connect the cable box to one of the TV inputs and the DVD player to another TV input. Using the TV remote you can chose which input you want to watch. The remote should have a button labeled "input"
Apr 29, 2017 | Cyberhome CH-DVD 402 DVD Player
I hooked up a DVD player to my RCA Tv/ VCR Combo. I get sound, but no picture. All connections are tight. Cables are hooked up in the order they should be. I get cable from TWC. There are red yellow &...
The red and white are the audio, and the yellow is the video, check the back of the tv to make sure the yellow jack states input, if yes make sure the tv is set to aux/or video.
Dec 22, 2010 | RCA T20TF667 20 in. TV/VCR Combo
I am trying to hook up the mvd2016 to a visio tv that is hooked to our cable converter box. I hooked it up, i have the tv but no sound.
your RCA jacks from the DVD player....should be connected to the Vizio a/v 1 in the back of TV (yellow to yellow, red & white to red & white)... now to view using the remote to TV switch to a/v (play a DVD, you should now have a picture and sound)
Dec 19, 2010 | Memorex MVD2016 DVD Player
Can you put a phillips dvdr610 onto a television with built in freeview and then record from it. If so how?
If your TV has an OUTPUT MONITOR Output Jacks, Yellow, (Video) Red (Audio) & White (Audio) FEMALE RCA Jacks.Then these will output WHATEVER is showing on the TV screen. And can be used as an Output for any Recording Viewing device. There will be other, FEMALE RCA Jacks,AV, Yellow, (Video) Red (Audio) & White (Audio) and possibly also The Composite Video, Red, Green, Blue, all Video, These are INPUTS, they will be there also. Make sure.
Feb 16, 2010 | Philips DVDR610 DVD Recorder
How do you make the dvd player work
This is the Apex SUPPORT website have a look around in here and see if it helps>
http://www.apexdigitalinc.com/support.asp
Aug 31, 2009 | Apex Digital AD-1600 DVD Player
Help hooking a dvd player to a tv
  • have you try to hook the rca jacks to the tv they should be color coded red, white, yellow, yellow is the video, red and white is audio. same as hooking to tv box.
Mar 24, 2009 | Panasonic DMR-E30 DVD Recorder
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
