How will I get a new SSS ID if my previous SSS ID got lost?
How did you lose a SSID?
The wireless router has a default SSID and you should change the default SSID when you configure the wireless setting.
If you go into the router's wireless setting you can view the SSID and/or change it to something else.
The only way you can lose this setting is to reset the router to the factory defaults, and if this is the case just change the SSID to something you like.
Registration Information Office
Selective Service System
Data Management Center
PO Box 94 638
Palatine, IL 60094-4638
Phone: 847-688-6888 or Toll Free: 1-888-655-1825
Email: [email protected] a
[email protected]
May I know whether you are referring to the SSID or the wireless security key (WPA/WEP key)? NOTE: An SSID is the name of a wireless local area network
(WLAN). All wireless devices on a WLAN must employ the same SSID in
order to communicate with each other.
The SSID on wireless clients can be set either manually, by
entering the SSID into the client network settings, or automatically,
by leaving the SSID unspecified or blank. A network administrator often
uses a public SSID, that is set on the access point and broadcast to
all wireless devices in range. Some newer wireless access points
disable the automatic SSID broadcast feature in an attempt to improve
network security.
