Question about Canon PowerShot A75 Digital Camera
I have a Canon Powershot A590 IS and it has about 14 or 15 white vertical lines down the left side of the LCD monitor that take up 3/8 inch and you can almost see through them but they are there all the time the monitor is on. Camera still take good pictures but I hve trifocals and I can not see the icons under the white lines well
Steve5
  • 423 Answers
SOURCE: LCD PICTURE IS PINK AND WHITE LINES (BLURRED )
Hi Sunil. The problem with your Canon A95 is quite common on cameras of 4 or 5 years ago. The repair is quite expensive, as the main imaging chip (CCD) has absorbed some moisture over time. There is more in-depth information here: http://www.imaging-resource.com/badccds.html
Posted on Apr 04, 2009
zohail
  • 1223 Answers
SOURCE: I have a canon powershot a590 IS. I uploaded
CCD FAILURE !
But good news is it is manufac fault and CANON will do it FREE just call them even if u are out of warranty , they have issued service advisory for such faults just call them in ur region and they will send a postage paid envelope for u
Pls rate me WELL !
See Advisory just call them !
Posted on May 18, 2009
t00nz
  • 4738 Answers
SOURCE: horizontal lines showing in lcd monitor and pink cast to printed photos
Oh my goodness, don't disassemble and don't go banging your A95's up for this problem. Sorry I missed this post when you first submitted it.
This sounds like it might a defective CCD imager. If so, Canon should FIX THIS FOR YOU FOR FREE, including FREE SHIPPING both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on May 20, 2009
smartr10U
  • 1305 Answers
SOURCE: Canon PowerShot A590 camera won't turn on. I have
If you make sure that the memory card is properly seated and the batteries in and the battery door properly closed, then it should power up. If still no success, it may be the micro switch that closes when the battery door is closed.
Posted on Sep 12, 2009
  • 6 Answers
SOURCE: canon powershot a590 IS lcd screen
I had this same problem. Once I got over about 1200 pictures, the screen just turned black, and the only setting that would work where I could see the lcd screen was the easy setting. I had read somewhere that this was due to the amount of pictures the camera had "counted", even if those pictures had been downloaded and erased from the camera. So I decided to reset the camera. Go to the tools list in the menu, scroll down to "reset all", and when it prompts if you want to "reset settings to default" click ok. This worked for me, and all of my settings - sunset, landscape, etc. - parameters in any of the settings (shutter speed, lighting, etc.) those will have to be reset.
Posted on Nov 22, 2009
How do I fix a vertical line on a 50 inch nec plasma monitor
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 28, 2016 | NEC Televison & Video
Got white vertical lines on left side of display
Vertical lines on an LCD screen are not a good sign. This usually means that your screen is going bad.
Jul 21, 2010 | Toshiba Computers & Internet
How do I take black and white photos using a canon powershot?
Place the camera in P, Tv, Av, M, Movie, or Stitch-assist mode. Press the Func/Set button, and scroll down to the "My Colors" icon on the left side (second or third icon down, should show "My Colors Off" at the bottom of the LCD). Now use the left/right buttons to select "B/W", and press the Func/Set button again.
Mar 16, 2010 | Canon PowerShot SX100 IS Digital Camera
Two vertical 1'' white lines on right side of Lcd panel
If the lines are parmanent, Then suspected part is LCD Panel.
Dec 27, 2009 | Samsung 226BW Monitor
Vertical white line near the left end of the screen.
Usually when there are colored lines on the LCD its because the screen is going bad. Quick way to verify this, try a different monitor on your computer and if the line goes away then you know for sure the monitor is bad.
If you try a different monitor and the line remains then you know that the video card is bad.
Jun 03, 2009 | Mitsubishi Power Adapter for DiamondPoint...
VERTICAL WHITE BAR ACROSS THE LCD SCREEN
Almost certainly the LCD panel has failed, and would be replaced by Dell if it is still under warranty. You can try to replace the VGA or DVI cable that connects the LCD to the PC. If the problem persists it is the LCD.
Mar 18, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
HP Pavillion zd8000 LCD problems
I had the same happen to me.. it started with one white vertical line.. then got the whole rainbow (red, green, blue).. Solution: Try connecting an external monitor.. if there is no problems, then it's not the video card or chipset.. it's going to be the lcd.. you can get it on ebay for about $200.. hope this helps..
Jose
Jul 16, 2008 | Computers & Internet
Canon PowerShot A75 Digital Camera Logo
53 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
