Question about Kenmore 43142 Front Load Washer
How do you adjust the cogs to get your drive belt on?
  • 15,935 Answers
It's done by sheer leverage (screwdriver) if your machine does not have a tensioner.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
2002 AU ford falcon alternator change over.?
Disconnect battery take note of the way the drive belt is fitted write it down using cogs as markers then draw the belt onto them in same order (belt only fit one way) then with a 3/8 ratchet leave r the adjuster and remove belt unplug wiring undo bolts holding it to the motor.
Sep 25, 2016 | Ford Falcon Cars & Trucks
91 Toyota 4runner V-6 timing belt replacement
Remove covers note the marks on cam cog are lined up with pointer,s ,crank pulley on T.D.C.undo the adjuster ,make sure the cam doesn't move,slide old belt off new one on adjust belt.
Oct 13, 2015 | Toyota Cars & Trucks
Motor & belt turn, but the needle stops when it encounters normal cloth. Drive belt is NOT broken & the machine has hardly been used. Sews OK when turning the wheel by hand.
the drive belt is normally a cog type belt inside the head of the machine
I would be looking in that area and at the belt or at the tension of that belt
may be a service technician would be able to correctly adjust and fix the problem
Jul 20, 2015 | Singer 2250 Tradition
Bottom cog on front of engine has come off and the belt is loose
I would suggest that you ask the question again but be exact in your description of the problem
the cog is behind the harmonic pulley and either drives a chain, another cog or a timing belt
the cog ( what you may be referring to is the harmonic balancer pulley and that drives the fan. alternator which would equate to a loose belt because the pulley has separated from the pulley hub
A clear photo would be a big help
Jun 23, 2015 | Cars & Trucks
How to replace a cam belt
Line up marks on the front pulley.T.DC remove cover over the belt check marks on the cam cog lines up with a pointer,s then release adjuster pulley slide old belt off and new one on ! D,on,t allow any cogs to move.retention cam belt.
Mar 31, 2015 | Cars & Trucks
Viking mb555 pro mower self propulsion slow
If the drive mechanism is not worn... either belt or direct drive, increase the rpm by turning the carburetor adjustment screw. If the belt is slipping, get a new one. If the direct drive teeth are worn or missing cogs, replace the faulty parts. Belts often become slick on the side that contacts the shaft... try turning the belt inside out to get a fresh gripping surface.
Oct 11, 2014 | Garden
How to replace v - ribbed belt
Hello
See this video.
Try these links too
share.qclt.com/.../2GR.../Drive%20Belt/00800210.pdf
http://www.dataentryjobs.us/67948.html
Feb 12, 2012 | Cars & Trucks
How to remove top cover moulinex masterchef a77
The Rubber cog unscrews anticlockwise to come off.
Sep 02, 2009 | Food Processors
Kenmore 43142 Front Load Washer Logo
19 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
