Question about Marshall Mg100dfx 100-Watt Combo Guitar Amplifier
Buzzing fan on a Marshall mg 100 head
My marshall mg 100 head has a cooling fan that buzzes for about 60 seconds when I turn it on, then the buzz goes away. Can I order a new fan?
    Novelist:
  • 133 Answers
Try to remove the fan and look for the sticker on the back side where the wires come out.
Remove the sticker, underneath it there will be a small aluminium cap (sometimes there is no cap and the axis is readily visible when you remove the sticker).
Take the cap off with a sharp tool (it shouldn't require a lot of force to do it), now you should be able to see the fan axis being held in place by a small clamp - put a drop or two of machine oil in there, move the fan blades a little to make the oil flow past the axis into the bearing.
Reinstall the cap, put the sticker back in place, reinstall the fan and test it.
Sometimes this will make things better, but if it doesn't then it is only fair to replace the fan.
regards
Triarcuate
Posted on Sep 29, 2009
    Problem Solver:
  • 17 Answers
You can order a new fan direct from marshall ... but the fan will be probably be ok for a long time ...
Posted on Sep 28, 2009
  • Marshall Master
  • 5,603 Answers
Check that there is no foreign object such as a wire or shard of paper touching the blades. Often this "blows away" and the fan will be quiet.
The second possibility is that the fan bearings are a bit dry. Usually this means replacing the fan eventually. It is best to use an identical fan regarding the voltage and current rating and general design/size.
A third possibility is if the fan is thermally controlled, these SOMETIMES are noisy due to the electronics controlling the speed pulsing the power to the fan. Not much you can do about this.
I would just make sure fan continues to operate. A fatal failure mode of fans is when they accelerate up for a few seconds and then "shudder" to a near stop while making a rattling noise and then accelerate again. Those MUST be replaced immediately.
Posted on Sep 25, 2009
Marshall mg hdfx100 power switch fell off, is there a way to turn it on without the switch
power switches are pretty easy to replace, i have the mgdfx50 and its only 4 spade connectors, 2 blue and two brown, doesnt have to be a marshall, just a 4 pole switch from an electronics store
May 24, 2012 | Marshall MG100HDFX 100-Watt Amplifier Head
Low volume on my marshall
I am very new here and don't know how to answer a question to a specific problem so I will write about the most common problems that I have had over the decades doing guitar amp repairs. If you find that your amp is extremely low in volume and then suddenly comes back to normal- check out the effects return [or power amp in] jack. Especially in Marshall amps-these corrode and your signal dies. If there is loud noise such as hissing and crackling with no guitar patch cord in the input jack- the input jack is likely at fault. They normally have switching contacts that ground part of the input circuit when the 1/4 inch male plug is disconnected. When this in is corroded or too weak to make normal contact, you can get these symptoms. If your amp is a solid state Marshall or Fender and there is a random buzzing sound with no guitar signal connected- hit the side of the amp and listen for the buzz to go away or become louder-if it does, this usually means that the connections are loose at the two large filter capacitors. In one or more Marshall amps, they use a filter circuit in the low voltage power supple for the preamp tubes. If you encounter a dead Marshall[the model escapes me now] remove the circuit board and resolder the four connections at the bottom of the bridge rectifier. If you have any other amplifier repair questions you can email me direct at computerlen@hotmail.com.
Nov 14, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
[23:05:39] Sharon Levit: hello! i have aproblem. iwll be glad if you can help me! so here is my problem: i bought a marshell 15 MG amp few days ago and this annoing buzzing problems. every time when i...
Make sure you are using this on a three wire grounded receptacle. If you are on an old two wirepower system, have a ground installed in the receptaclel you are using. If you are on a grounded circuit, then exercise your warranty for repair/replacement.
Aug 16, 2011 | Marshall Amplification Marshall MG15 15...
The guitar is not amplifying
faulty lead? when the lead is plugged in turn the amp distortion on (may be called 'gain') and when you tap the end that goes into the guitar with your finger you should hear a buzz. try another lead if not, and if it still doesn't work make sure that volume is up on the amp and the guitar. there may also be a knob in the back of the amp, turn that up too (but not all the way or when you do get it working you'll blow the speakers out).
Apr 19, 2011 | Marshall Amplification Marshall MG Guitar...
Its a marshal 8080 valvestate 80 v and it buzzes and some of the knobs crackle when turned,
Buzzing could be normal for this amp, especially if you have the gain cranked way up (or the volume way up) see if the buzz goes away when you turn the gain/volume down. If not, there is a problem that needs to be properly diagnosed by the amp tech at your local music store. The crackling is also unfortunately rather normal for an amp that's a little older. Oxidation builds up inside the knobs and makes that noise as you turn them. If it only happens when you change settings I wouldn't worry about it, but if it gets bad, a tech guy can clean it out for you.
Feb 20, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
When turning my Marshal MG250 DFX on, there is a terrible buzzing sound. I have tried it on different speakers and the buzzing still occurs. It does not change in volume when i adjust the volume. Whats the...
This is likely a filter capacitor issue. The right tool to troubleshoot is an oscilloscope. This could also be a failed power amp that is driving high DC current with ripple into your speaker. This can permanently damage the speaker. Repair this before using it.
Jan 13, 2011 | Marshall Amplification Marshall MG250DFX...
Marshall mg 100hdfx fan
Some of the Marshall equipment uses computer size fans and even on occasion the same connection.
Take the bad fan with you to a computer repair shop it will be much cheaper than a marshall part they should be able to help you out
Sep 09, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Marshall Mg100dfx 100-Watt Combo Guitar Amplifier Logo
1,191 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
