Question about Konica Minolta Office Equipment & Supplies
I have a konica 7022, it says call for service code F-35-3. what's wrong with it. please help me.
  • Konica Minolta Master
  • 1,297 Answers
Fixing upper roller low temperature error.Verify the continuity the heater lamps and remove and clean the thermofuse.If the thermofuse not working change it.
Posted on Sep 26, 2009
Konica 7022 error F35-1
F 35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Aug 27, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Error code c3905 in konica minolta bizhub 950
When C-35**,C-38** or C-39**(fusing temperature related
abnormality) occurs, be sure to repair defective parts before
setting DIPSW3-1 to 0. Setting DIPSW3-1 to 0 with defective
parts not repaired results in a fire.
Dec 21, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
I have a Konica Minolta 7022 printer, scanner, fax, and copier machine. How do I get it to scan?
Please see this website complete manual for Konica MInolta 7022 printer I think i can help your problem
http://help.nceas.ucsb.edu/images/2/2a/Konica.pdf
Thanks
May 10, 2011 | Konica Minolta Office Equipment & Supplies
Hi, I have a Konica 7022 and it comes up with the error code PLEASE CALL SERVICE F-35-1 . Can anyone please advise a fix to this problem. Jack
I would call for service. Below is the official repair method. Sounds like a fuser has failed or at least the thermistor on the fuser. This ensures there is enough heat in the device to properly transfer the image to the page.
F35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Mar 01, 2011 | Office Equipment & Supplies
Konica 7022 copier at start up says call service and shows F-35-3
The thermistor TH1 on the fuser unit is coming up as faulty this will cause your f-35-3 error you can reset it in service mode 25 dip sw3 0 to 1 however i do not do this as there is an issue i would replace both thermistors and look at the fuser unit for wear if in bad shape replace the fuser unit assembly
Jan 22, 2011 | Konica Minolta Office Equipment & Supplies
Konica 7022 copier f 35-3 code
I have put in new toner yet there is still 'add toner' message on the screen.
What do I do? Please help me.
Aug 03, 2010 | Kyocera KM-1505 Copier
Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 (code F-26-1) Pls call service 0870-2425050)
i have a konica 7022 it say call service code F-35-3, what's wrong with it, help me.
Mar 21, 2009 | Toshiba 2060 Copier
Error code f-35-8
Ensure there is no jam in the fusing unit. Turn copier off. Turn the copier back on while pressing down on the 2 and 5 keys. Select 1, the software switch settings. Using the arrows on the touchscreen, select dipswitch 3-1. Touch the off key. Press return, then turn the copier off and back on. If the code returns, you may have to replace the temperature sensors in the fusing unit.
May 19, 2008 | Office Equipment & Supplies
Konica photocopier
My service info doesn't go back that far either, but this procedure should work to reset the code. However, I would make sure there's no toner build-up on the fuser thermistor or thermostat first, otherwise the code will reappear.
Here's the instructions on clearing the code:
Enter the 25 mode by holding down the 2 and 5 keys while turning on the copier.
Press the P key, then enter 47, then press P again.
Enter 0 and press the Print key.
Turn the machine off/on to exit the 25 mode.
If the code reappears, then theres a problem. If it doesn't, you're good to go!
Nov 11, 2007 | Konica Minolta DiALTA CF910 Copier
289 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
