Question about HP TFT7600 ITL R/MOUNT K/B MONITOR (1211858)
How do i change my printer status from idle to ready?
The printer is HP Laser Jet P1007
Just right click on ur printer & use it online
Posted on Sep 25, 2009
  • Lulu
    Lulu Jan 14, 2014
    No, no, no. Your trick does NOT work.
The last page not able to delete that is given in last but first in the printer queue?
Posted on Apr 30, 2010
Hp 4100 laser printer says it's ready then says processing but nothing prints. what is going on?
if your using a network try to replaced your jet direct or try to re install your printer driver and change also the ip address of printer.
Sep 27, 2011 | HP LaserJet 4100 Printer
Hp laser jet 1007 printer drivr
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3435680&
Follow the link above then select the operating system(Windows XP, Windows 7, etc) you need the driver for then download the driver
Mar 07, 2011 | Office Equipment & Supplies
How do you run a page count report? HP Laser Jet 1320N
Configuration page
The configuration page lists current settings and contains a status log report.
To print the configuration page from the printer, press GO for 5 seconds, until the yellow light comes on, when the printer is in the ready state.
NOTE Make sure that you hold the GO button for less than 10 seconds.
Apr 19, 2010 | HP LaserJet 1320n Printer
Have a hpc color laser jet cm1015 we have a
you change your cartridge which signal color code or mark replace this mark cartridge then solve your problem printer ready then make a copy
Nov 21, 2009 | HP Color LaserJet CM1015 Printer
EIO 1 ERROR
There's probably a problem with the card in the printer. It may need a firmware upgrade, you may need to adjust settings or even change the slot. The EIO 1 means it is now in slot 1. Here are some steps to try from the HP website:
Press (Select) to enter the MENUS.
Press (Down arrow) to highlight INFORMATION.
Press (Select) to select INFORMATION.
Press (Down arrow) to highlight PRINT CONFIGURATION.
Press (Select) to select PRINT CONFIGURATION
Check if the I/O card is on ready state.
Make sure that TCP/IP status is ready.
Check the network statistics for any bad packets or bad transmition.
Try to use another slot then the one that the JD is installed on.
If the problem persist,try performing a cold reset with the JD inside.Warning: This will reset the printer's configuration to the default settings,and also to the JD so you will need to set again the network values.
May 19, 2009 | HP LaserJet 2420 Printer
Printer status in idle
printer status idle - how do i get the printer status to read ready?
Apr 05, 2009 | HP TFT7600 ITL R/MOUNT K/B MONITOR...
49.FF95 SERVICE ERROR
Please look on: http://www.fixyourownprinter.com/
There are much solutions of this problem listed ...
For example this (it see good):
http://www.fixyourownprinter.com/forums/printer/46157#1
HP Laser Jet 4250n by TLYNN (3/20/07 12:22 PM) reply + / -
Anybody know the error code "49. FF95 Service Error"
We can't get around this...
Firmware Error 49 by Stephen (edited 3/20/07 12:29 PM) reply + / -
It could be a bad job.
First disconnect it from your network and any PC it might be attached to.
Power cycle it, then if it goes to ready status try the built in test pages, do they work?
If the printer will go to ready status and you have a parallel cable with the proper connector, then you can try upgrading the firmware from a PC, you can also try to upgrade the firmware over the network.
More reading:
http://www.fixyourownprinter.com/search/forums?f=&q=49+4250
Re: HP Laser Jet 4250n by TLYNN (3/20/07 12:59 PM) reply + / -
Still won't go back to ready status. Turns on to the same error code....
Cold Reset HP Laser Jet 4250n by Stephen (3/20/07 1:03 PM) reply + / -
Try a cold reset, it will reset the JetDirect settings, but it's the next step.
Cold Reset:
Power off printer, wait about 5 seconds, then power it on, when asterisks start appearing on the display press and hold the check mark until all 3 lights come on solid, then use arrow keys to find cold reset and push check mark to perform the reset.
Re: HP Laser Jet 4250n by TLYNN (3/20/07 1:06 PM) reply + / -
Thank You so much for your help... but that didn't work either. Same error code showed up.
Re: HP Laser Jet 4250n by Stephen (edited 3/20/07 2:27 PM) reply + / -
Then you probably need to replace the formatter.
Do you have another printer you can swap parts with?
There is a slim chance the memory DIMM is bad, you can try it with the DIMM removed, if there is more than one DIMM you can try installing just one and then the other.
A 49 error indicates that the formatter could not understand or execute an instruction within a file or cannot interface with an accessory, DIMM, or EIO device. Troubleshooting 49 errors is done through process of elimination. First determine if the printer functions in a stand-alone mode then test communications to the printer.
These errors can be divided up into two categories; the associated troubleshooting depends on the circumstance the 49 errors are occurring.
A 49 error is always followed by Hexadecimal numbers, for instance, 49.00FF. The Hex code is a memory address. Most Hex codes are not documented.
Re: HP Laser Jet 4250n by dmzcompute (3/20/07 2:26 PM) reply + / -
I do not see anywhere where the printer has been disconected from everything. If you have not done so already disconnect every cable from the printer with the exception of the power cable and turn the printer back on and see if you get the error and if not report back here for further instructions.
Re: HP Laser Jet 4250n by Stephen (3/20/07 3:28 PM) reply + / -
You might also try disabling the embedded JetDirect.
To disable the embedded LAN port
Turn the printer power off.
Power on the printer and watch for the memory count to begin.
Hold down the SELECT (Checkmark) button, when you see the memory count begin.
Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until EMBEDDED LAN DISABLED appears on the display
Press the SELECT (Checkmark) button. The printer then continues its power-on sequence with the embedded LAN disabled.
If this works the JetDirect built into the formatter is bad, you can either replace the formatter, or buy an JetDirect to install in an EIO slot.
Re: HP Laser Jet 4250n by Trev Pearson (3/20/07 10:08 PM) reply + / -
The only other thing to try, before spending money, is to get the network administrator to clear the print queue for that particular printer and then turn it on.
The theory being that a 'corrupt' print job is still in the system and as soon as the printer is turned on, that 'corruption' floods the network card with garbage which promptly goes 49.
If the printer comes 'ready', great. Then do a firmware upgrade. If not, then you will have to spend money on a new formatter.
Regards
Trev
Re: HP Laser Jet 4250n by roadrunner178 (6/21/07 2:09 AM) reply + / -
hi.
With a cold reset ,my problem solved.
try this as a first solution.
thank you
Re: HP Laser Jet 4250n by Anonymous (7/31/07 1:20 AM) reply + / -
THANK YOU WERY MUCH
FROM TURKEY
ZAFER
Jan 02, 2009 | HP LaserJet 2420dn Printer
HP TFT7600 ITL R/MOUNT K/B MONITOR (1211858) Logo
2,495 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
