Whirlwind -Air Cooler with Heater and Humidifier, FH-778 Air Conditioner
Problem for Whirlwind -Air Cooler with Heater and Humidifier, FH-778...
I have a trane unit in the attic that is for the
By kkolo7272 on Sep 25, 2009
I have a trane unit in the attic that is for the second floor and it is installed on i guess its side has to be that way water is comming out of this hole and into this pan that is connected but the pan keeps getting full of water what is the problem
Comments:
Sep 25, 2009
- thank you so much for emailing me back and youre answer is great this house is 30 years old and we have never had a problem with this unit a man came and fixed a fuse because the blower wasnt blowing.. there is this piece just hanging that is connected with like a lifting piece to stop something but their is a p trap comming out of this space as well as this hole when i shine a flash light the water is bubbling out of this eracer head hole.. stupid me tried to plug it up and caused all this back up do you think i need to call a repair man and if so i live in lumberton north carolina..... 28358 zip code people around here are not to trust worthy my brother is a air conditioner man in chicago but to far for him to come and help... ha ha and my husband is not your handy man im the only one around here that can fix almost anything given good directions i do not think this unit is installed improperly though....
Best Solution
posted on Sep 25, 2009
Very Helpful)
terrencio
Rank: Master
Rating: 96%, 8 votes
The water is condensate, which is produced by the air conditioner (this normal), The hole you are refering to shoule be connected to a drain, and should have a "p" trap installed to allow proper drainage and prevent sewer smells from backing up into the air handler. The pan underneath it should be a secondary catch incase there is a problem with the primary drain (the hole from the unit). the secondary catch should also be equipped with either a drain to allow the water to escape, or a moisture sensor to shut-down the air conditioner, and alert the homeowner to the problem, by way of the house getting warmer. The fact that you describe it as simply a hole draining into the secondary pan tells me that this unit is not installed properly. I suggest calling the installing contractor to remedy the situation, before costly ceiling repairs are required.
Comments:
Sep 26, 2009
- Your welcome, I'm glad I could help. and yes I do think you should have someone look at it. This is a slow moving smal diameter drain, and can plug up easily, it should be flushed out, also make sure your air filters are kept clean, I would suggest checking the air filters monthly, when they get plugged the coil will fall too far below the due point or freeze up and create an excess of water running off. I'm all the way up in Canada, the travel charge would be enormous, lol.....I hope you can find someone reliable to have look at it. cheers!
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" THANK YOU SO SO MUCH IN THE MIDDLE OF THE NIGHT AND WATER COMMING THRU MY CEILING LIGHT FIXTURE THIS HAS BEEN A GREAT RELIEF TO ME.... I CANNOT THANK " - kkolo7272
Popular Solutions for Whirlwind -Air Cooler with
Questions and Unsolved Problems for Whirlwind -Air Cooler with
Do you recommend Whirlwind -Air Cooler with Heater and Humidifier, FH-778 Air Conditioner?
Answer
Answer
Just missing the piece that holds the vent in the window for an Everstar portable a/c. Is it... (More)
Answer
Installed a new Hunter thermostat a few weeks ago. All was cool (pun intended) until yesterday when... (More)
Answer
MPMI-10CR-BB6 DONT WORK THE AC DOES NOT TURN ON AND WHEN ITS PLUGGED ALL THE LIGHTS ARE ON, WHY ITS... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlwind -Air Cooler with...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
