Question about Compaq Computers & Internet
Replaced hard drive and now during start up, computor stops on bio screen and ask for pressing f2 to open windows or f1 for recovery. compaq sr1430nx
  • 496 Answers
This sounds like an error in your bios configuration go in and check to see if all your bios settings are correct and if there being saved everytime you reboot if theyre not being saved you may have to replace the cmos battery on the motherboard
Posted on Sep 25, 2009
Smart failure.. bootmgr is missing..I have recovery discs but dvd player is not working
Yes, you can make USB boot drive. However main problem is the Smart... error. It is your hard drive. You need to fix that first! Try reseating the drive. Next go into BIOS by pressing F key during boot. Might be F2? Make sure BIOS recognizes the hard drive.
Once you get the drive going again, you can start the install / repair again. USB drive tool.
http://www.microsoftstore.com/store/msstore/html/pbPage.Help_Win7_usbdvd_dwnTool
Oct 11, 2012 | Computers & Internet
My husbands ex wife bought my step son a used HP compaq d530 SFF desktop. She set an admin password on it and now she cant remember what it is. Is there anyway to restore it back to the factory settings...
If you are talking about problem with your password
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
hope this helps
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive) also
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
Hope this helps
Hope this helps
Apr 08, 2011 | Compaq Computers & Internet
My desktop compaq presario s4300nx starts up , i can accses set up with f1 but cant start recovery with F10 however the F10 button works in setup, no good to me, ...i have recovery disks the pc just...
you will need a Windows boot disk / Windows install disk / WinXP disk to reboot the PC and install / or repair your OS
rescue disk will not boot your PC
to enable that you need to enter the BIOS, press F1, F2 or Del to enter BIOS , then you need to look for the BOOT seq in BIOS, change that to CD DVD drive as the 1st boot device, Save and Exit and insert the boot CD and restart
this should give you the solution
Dec 16, 2010 | HP Compaq Presario S4300NX (DF216A#ABA) PC...
During start of the computer pc stopped for F1 and F2 key,when press F2 then it will run ,also mention Bios Update during start.Pl suggest what will i do,for Bios upgrade and its procedure...
Open cpu case find juper pin change pin recovery mode pc on 3
min after pin same position you can slove proble
no open update bios in cd rom
Oct 26, 2010 | ASUS P5RD1-VM Motherboard
I have a Compaq Presario Notebook 2100 when I turn-on it appears the following."disk failed and "operating system not found" what i am suppost to do. please help... Thanks a lot
You can go into the Bios by pressing F2 on startup and see if the hdd is detected there or not, you can make the bios default by pressing F9 and then F10.
If this doesnot works you will need the ricovery disc and you will have to boot to windows recovery console and there Use the fixmbr command in the Windows XP Recovery Console to repair the MBR of the startup partition.This should hellp you to fix the problem.
Mar 10, 2010 | Compaq Presario 1692 Notebook
Sr 1430 start up problem, during boot up, a screen comes up wanting me to press f2 to boot computor
Is it throwing up a 'disk read' or 'no physical drive installed' error?
In most cases, a boot error in bios (the pre-installed program a computer uses prior to loading an operating system such as Windows, Linux or Mac OSX) usually points to:
- disconnected cables running from the board to the hard drive(s)
- malfunctioning ports (IDE ports especially)
- dead or dying hard drive(s)
Open the case (if you don't mind voiding a warranty that you may still have) and check the cables that run from your drive(s) to the board and from the power supply to the hard drive(s) to ensure that the cables are firmly attached at all ends.
If so, the best way to test a hard drive without spending at least $100.00 for diagnostics is to install it(or them) into another computer and boot. If that computer boots with your drive(s), the problem may be on the board or with the PSU (power supply unit). In either case, you'll probably be looking at anywhere between $100.00 and $200.00 to replace.
Before you do anything, though, there's a button battery attached to the board; remove that for about a half hour, reattach it then try to boot. Sometimes this can clear up boot issues.
If the hard drive has died, DO NOT dispose of it. Most people think that their data is lost in the death of a drive and that's not true. Take it to a professional 'computer guy' and have the data extracted and saved to a new drive. The cost should be around $100.00 for data recovery... no more than that unless a new drive is part of the deal.
Sep 09, 2009 | HP Compaq Presario SR1430NX (PS566AA) PC...
Floppy drive
You're talking about My PC and device manager and I'm talking about Bios.
The BIOS (stands for Basic Input/Output System) is system software inside your computer that helps the computer start up, even before Windows does. It also contains key settings about what the computer has on board.
In newer computers, it exists on a special chip called CMOS (stands for Complementary Metal Oxide Semiconductor).
You can go into the BIOS to edit or change the technical information about key components of the computer like disk drives, keyboards, and display settings. It also keeps track of the date and time.
The BIOS can normally be accessed when you start your computer. You may see a reference to "Setup" when you turn your computer on. That’s your opportunity to get into the BIOS. It usually requires the push of a function key, such as F10, to get access to it. That "F" key varies between computers. Sometimes it’s not even one of the Function keys, but the ESC key or DEL key.
If a logo screen—like HP or Dell—is displayed during the start up process instead, then you may want to check with your computer maker for a command to turn off that screen and display the start up information, which is listed when a computer is powered on.
A partial list of BIOS access commands by brand is listed at the end of this article.
The BIOS also contains the boot-up sequence. Normally, computers are configured to boot from a hard drive.
Before you do anything to your BIOS, it’s always a good idea to record the original settings on a sheet of paper that can be kept in a safe place so you can reference it later if you need to reset it.
Here is a list of key sequences for various brand-name computers. If yours is not there, check with your manufacturer or watch for info flashed on-screen when your computer first starts, before Windows begins. It may say
"For setup hit..." That will be how to get into the BIOS on your machine.
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or Ctrl+Alt+Esc
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl+Alt+Esc
Award BIOS: (Del) or Ctrl+Alt+Esc
Compaq: (F10) (do this when the cursor is in the upper right corner of the screen blinking)
Dell: - F1 or Del.
Dell: - Some require pressing reset twice
Dell: - Ctrl + Alt + Enter
DTK BIOS: (Esc)
Gateway 2000: - F1
Hewlett Packard: - F1
IBM:
Older Models - In order to get into the configuration of the IBM setup screen (CMOS) screen you need to hold down both mouse buttons during boot up.
Aptiva - Press F1
IBM PS/2: Ctrl+Alt+Ins after Ctrl+Alt+Del
IBM PS/2 with reference partition: - Press Ins during boot
Some PS/2s, such as 75 and 90: - Ctrl Alt ?
Some PS/2s when pointer at top right of screen: - Ctrl + Ins
NEC: - F2
Packard Bell: - F1 or F2
Phoenix BIOS: (F1), (F2), or Ctrl+Alt+Esc
Phoenix BIOS: - Ctrl+Alt+S
Phoenix BIOS: - Ctrl+S
Phoenix BIOS: - Ctrl+Alt+Ins
Sharp Laptop 9020: - F2
Sony: (F3) while you are starting the PC, then (F2) or (F1)
Tandon computers: - Hold down the key after turning on power
Tandon: - Ctrl+Shift+Esc
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Olivetti PC Pro: - Shift+Ctrl+Alt + Num Pad Del
Miscellaneous PC’s: - Ctrl + Esc or Ctrl and Alt and +
Zenith: - Ctrl+Alt+Ins
Let me know how it is going!
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 15, 2008 | Computers & Internet
How to reset my compaq computer back to the factory setting
Reset your operating system software (Windows XP..)to Compaq factory setting : restarting your computer. Hold down F10 key, your computer will go into recovery software provided windows recovery was preloaded into your hard disk during installation.
Follow on screen instruction.
If it your Bios you want to restore to factory setting, restarting your computer hold F1 key, entering BIOS set up. Look and press the key assigned "Default Loading" save change and exit Bios set up.
Does that solve your curiosity
Jul 27, 2008 | Computers & Internet
How do you enter set up in an oler compaq presario. It came with win 98.also if hard drive controller is bad can I put in a new one without replacing motherboard
Depending on the actual model of the old Compaq, you can enter the CMOS/BIOS setup by pressing on the a special function key or key combination during Power-On Self Test (POST), before the operating system loads. During POST, the BIOS usually displays a prompt such as:
Press F2 to enter Setup
Common keystrokes that will access the BIOS Setup are F1, F2, F10, and Del. For older Compaq computers, like the Deskpro 286 or 386, you must place the Diagnostics diskette in the A: drive, and then restart the computer.
For newer Compaqs, like the Prolinea, Deskpro XL, or Presario, while the cursor is at the top right corner of the screen during bootup, press the F10 key.
The hard drive controller can not be replaced without replacing the motherboard. Incidentally, there are old PCI sundcards that has an IDE port and can be configured to replaced defective on-board IDE port.
If your concern has not been addresses after completion of the above procedures, you may need to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 17, 2008 | Computers & Internet
Computers & Internet Logo
48 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
