Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My system asks for installation of my 4GB DT120?
  • 395 Answers
What Operating System are you using, basically just insert the flash drive into the usb port on your computer/laptop. Give it some few minutes and it would instal device driver software automatically.
Hope this helped.
Regards
Posted on Sep 25, 2009
    Problem Solver:
  • 8 Answers
Just install it and do as said or just click next it will be installed automatically
    Problem Solver:
  • 5 Answers
RESTART THE SYSTEM AND PLUG IN THE PEN DRIVE IT WILL WORKS.WHY IT ASK THAT YOU SHOULD INSTALL YOUR 4GB DT120
  • 136 Answers
Ok
install it
just press by NEXT
My pc wont boot up, led's 3&4 flash, I have renewed the RAM and the fault is still there, does anyone have a clue what the problem is?
Allan Cairnduff,
Below is the information for the 3,4 diag error.
Memory modules are detected, but a memory failure has occurred.
  • If two or more memory modules are installed, remove the modules (see your service manual), then reinstall one module (see your service manual and restart the computer. If the computer starts normally, continue to install additional memory modules (one at a time) until you have identified a faulty module or reinstalled all modules without error.
  • If available, install working memory of the same type into your computer.
  • The memory specs for this computer are listed below.
  • Type DDR3 Synch DRAM Non-ECC Memory Memory Speed 1333MHz Memory Connectors Four (MT, DT, SFF), Two (USFF) Memory capacities Up to 4GB Minimum Memory 1GB Maximum Memory 16GB(with 1333MHz speed memory)/8GB for uSFF only Memory
    The OptiPlex 790 system supports up to 16 GB of memory in the mini-tower (MT), desktop (DT), and small form factor (SFF) chassis with 64-bit operating system. The maximum memory supported in the ultra-small form factor (USFF) is 8GB. The memory speed supported is 1333MHz DDR3 memory.
    However, 32-bit operating systems can only use maximum 4GB memory address space. Certain components within the computer require address space in the 4GB range, any address space reserved for these components cannot be used by computer memory the amount of memory available to the operating system is less than 4GB.
    NOTE:
    Memory modules should be installed in pairs of matched memory size, speed, and technology. If the memory modules are not installed in matched pairs, the computer will continue to operate, but with a slight reduction in performance.
    NOTE:
    The total amount of available memory will be less than 4GB. The amount less depends on the actual system configuration. To fully utilize 4GB or more of memory requires a 64-bit enabled processor and 64-bit operating system Thank You,
  • Dell-Jesse L
May 15, 2016 | Dell OptiPlex 790 USFF
My radio shuts off after 5 seconds.How can I fix this?
Maybe you have a timer to shut it off in 5 secounds? Check your user's manual
Jun 01, 2015 | Sangean DT-120 CLEAR Pocket AM/FM Receiver...
Asus s400ca doesn't recognize add'l 4gb memory
There is a 4GB limit on a 32bit systems. Most time it will show something like 3.2GB. You need 64 Bit for additional memory.
Mar 29, 2013 | Computers & Internet
Trying to put 6.56GB movie on my 8GB sandisk cruzer contour, says the file is too large for the destination file
The file system is likely the culprit for this. If you've formatted the USB stick with FAT32, the largest SINGLE file will be about 4GB. You can place as many smaller files as you want to fill the stick completely (in excess of 4GB), but once you approach 4GB for a single file - it will crash.
Format with NTFS instead. No 4GB limit is placed on files in this file system. A nice chart listing the differences between file systems can be found here. The forth row "Max File Size" shows the data you're asking about. NTFS supports 16TB (terrabytes are 1000 times larger than gigabytes) while FAT32 is limited to a "paltry" 4GB. Both FAT32 and NTFS are supported by Windows XP and newer OSes.
I hope this helps - please rate my reply - thanks!
Dec 28, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
Installation for my sansa e260 4gb on to my computer
http://www.sandisk.com/DriverDownload/driverList.asp go to that site and it will ask for ur email....go ahead and pit it in...i then you can download it....get the converter too i u want videos on ur sansa
Jun 21, 2009 | SanDisk Sansa e260 MP3 Player
Best Graphics Card, RAM for D101GGc
go for the nvidia geforce 8500, your board Support for up to 2 GB of system memory so no 4GB( too bad)
Jan 27, 2009 | Intel D101GGC Motherboard
4gb memory installed but less memory size detected
You probably have a 32 bit operating system. If so, then you will only see anywhere from 2.75 to 3.5gb of ram.
You need a 64bit operating system to fully see all 4gb of ram.
As long as you can see all 4gb of ram in bios, then you're ok.
Aug 11, 2008 | ASUS Computers & Internet
4gb on msi k8n neo-4 F
Hello pejegess,
If your OS is reading the 4Gb, it will be running the 4GB even if the bios is only seeing 3GB. You may just need to update the firmware on your motherboard but I suggest that you just leave it as is since the OS is recognizing the 4GB.
Sincerely,
Agent Xiong
Jun 03, 2008 | MSI K8N Neo4-F Motherboard
Brand new gateway m-6846 vista 64bit
The maximum amount of memory that your system can use is actually limited in two ways — not only is there a maximum amount of memory that your computer motherboard can accept, there is also a maximum amount of memory that your operating system (OS) can accept.
For instance, when you install 4GB of memory in a 32-bit Windows system (the most common version; 64-bit systems are typically used only by high-end users), your system will see (and utilize) only 3GB or 3.5GB.
Relax, there isn't a problem with the memory. Windows allows for 4GB of memory to be addressed, but this isn't 100 percent the same as having 4GB of physical memory.
What happens is that some of the addressable memory (regardless of how much you have physically installed) is reserved for use by page files or by some of the devices that you are using, such as a graphics card, PCI card, integrated network connections, etc., so it's unavailable for use as normal main memory.
The amount of memory needed for these devices is calculated by your system at startup; if you haven't maxed out the memory in your system, it's invisible to you, and all your physical memory (the RAM that's installed) is available for use. However if you've maxed out the DRAM in your system, this amount will be deducted from your physical memory, so you can't use 100% of your DRAM.
The maximum memory limitation varies by operating system; for instance, the 4GB memory limitation doesn't exist in 64-bit versions of Windows.
Memory maximums for current Microsoft® Windows OSs include:
  • Windows XP Home: 4GB
  • Windows XP Professional: 4GB
  • Windows XP 32-bit: 4GB
  • Windows XP 64-bit: 128GB
  • Windows Vista Home Basic: 4GB
  • Windows Vista Home Basic 64-bit: 8GB
  • Windows Vista Home Premium: 4GB
  • Windows Vista Home Premium 64-bit: 16GB
  • Windows Vista Ultimate: 4GB
  • Windows Vista Ultimate 64-bit: 128GB+
  • Windows Vista 32-bit: 4GB
  • Windows Vista 64-bit: 128GB+
May 23, 2008 | Computers & Internet
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
134 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Computer Links
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
