Question about Sony Playstation 3 (PS3) Console
Power problems my ps3 will not turn on... it keeps going right to standby...what do i do????
  • 4 more comments
  • Anonymous Dec 25, 2007
    brand new christmas morning. Turn on and keeps tripping into flashing red light mode. Very disappointed son and frustrated father.
    stays in standby wont come on. whats wrong?
    I turn off on the back, unplug power cord, wait 5-10 min. Plug cord back in, turn on switch. Stanby light comes on. Just touching the button on the front it goes green, beeps and shuts down.
    No lights, no nothing, just shuts down. Switch doesn't even work until turning off again, unpluggin waiting 5-10 min, yada, yada, yada.
    VERY FRUSTRATING.....
  • chrypto Dec 27, 2007
    PS3 turns on for 3-10 seconds then shuts down.
  • dbz gamer92 Aug 30, 2008
    when i try turn on ps3 it will turn on for about 3 seconds then shut down then light flashes red
  • Anonymous Feb 25, 2009
    my ps3 turns on for like 5 seconds and then flashes yellow then red
I had the same problem listen what you have to do is call Sony and if you are still under the warranty Sony will send you a prepaid shipping box with all required instructions on how to mail your defective PS3. They will more than likely replace it. The problem you have is the RED BLINKING LIGHT OF DEATH!!
You can get Sony's # on your PS3 box or web page. There is nothing you can do to fix it.
Posted on Dec 17, 2007
  • 10 Answers
Im having the same problem. However, what did work for me in the past is as follows:
1) turn your PS3 off (red light showing on console)
2) press and hold the power button 5-10 secs until it cycles all the way back to red again
3) This action resets the video display to its default and had worked for me in the past
4) turn it on as normal
However, Ive attempted this now and I can get the AV cables working but not my HDMI. Just suddenly stopped working after a month.
Same problem man
Posted on Dec 16, 2007
Try to sign in and error code 8071053D keeps appearing
  1. Turn the PS3 to standby power off.
  2. Turn off the power on the PS3 by using the power toggle switch on the back of the PS3 and unplug power cord.
  3. Restart your wireless router, if using one.
  4. Plug in the PS3 power cord and power on the PS3.
  5. Try creating a new connection on the PS3 by accessing the Network Settings menu option on the PlayStation 3.
go for a minimum of 5 minutes in between each step to properly clear it
i hope this helps you and please vote for me
Dec 05, 2010 | Sony Playstation 3 (PS3) Console
Hello, My PS3 just keeps turning itself off. I have tried to reset the system but it keeps flashing red and yellow lights and then turns itself off into standby mode? HELP......
Try removing the game inside your disc. then try removing other external hardware and slots and try again. If problem persists it might be a system problem. Please go to the shp from where you bought it and ask them for a replacement.
May 16, 2010 | Sony Playstation 3 (PS3) Console
Need tech help!
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 21, 2009 | Sony Playstation 3 (PS3) Console
No menu appears when you switch it on only the wave and colour appears also will not turn off have to turn off from main switc
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
Hi ps3 stopted 3days ago ,it just keeps going 2
hardware failure need to send back to sony if still under warrenty they will not charge you if not it cost $150 and you need to set it up with sony support.
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
Blue wavy line but no profiles to select
Alright mate, Had the same problem as you and my ps3 is up and running now. What you need to do are the following steps:
1. turn on the ps3 so it is in stanby i.e. the red light is on. 2. push and hold down on the red button for as long as it takes to turn the ps3 back off on to standby, you should hear a beep. 3. when it goes back to standby do the same thing again, and this time you will hear one beep (when you pressed it) and two more beeps and it will go back to standby 4. when it is back in standby again, push and hold down the button again, you'll hear the first beep, then three more beeps, and it will go back to standby. 5. do the same again, however when it turns on this time, if done correctly, it should say connect the controller using a usb cable. do this and turn it on. 6. Go through everything it says on screen, 6 options should eventually appear, for me, option 4 did the trick, but i heard option 3 works too, as the other ones do too i presume. 7. the final part is that it will ask you to restore the hard drive etc... just keep pressing the ok button.
if all fails, then phone this number (sony) 0818 365 065. glad to help. let me know.... David.
Jul 02, 2009 | Sony Playstation 3 (PS3) Console
My playstation turns on and everything, but once i plug it in to any kind of television there is no picture or sound
Heres one solution that I found. If your ps3 turns on but does not boot up just stays a black screen most likely the hard drive got corrupted. So unfortunately you will lose all your saves. But to save the system when you power on the ps3 hold the button down its should beep once keep holding it and it should turn red in standby mode. Keep holding the power button down though. It should turn green again keep holding it should beep then double beep this time instead of going into standby. Let go now and some options will come onto the screen. You will need to plug in your ps3 controller and 6 options should come up. Reformat PS3 worked for me but I lost all my saves. Good luck!
Apr 06, 2009 | Sony Playstation 3 (PS3) Console
Not loading up to main screen
ok go to youtube and type" PS3 REPAIR/FIX" basicly what you do is put the ps3 on standby (the red light on) and then turn the main power off (the back switch) then hold the I/O button in the front (the on switch you use to put on standby) just hold it until it will go to standby then hold the I/O button again (the standby button) and then keep holding it until you hear one beep, then wait for two quick beeps. Then there should be a menu and select "Restore Defualt Settings". If it dosent work CONTACT SONY!
Mar 08, 2009 | Sony Playstation 3 (PS3) Console
Ps3 powers on no video.
Hey jlbrown55 , have you tried resetting the default settings? If not you just have the PS3 in standby (with red light on) and hold power till the systems turns on then 10 sec after and it will beep. Let it go right then and it should reset the defaults in about anouther 10 seconds. If that doesn't work, call Sony. It seems to be a growing problem. Good luck.
Oct 15, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
238 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
