Will not boot up & I get a continues beep noise
  • 256 Answers
Continuous beep sound from the PC may cause due to RAM problem. Please open your PC cabinate and check that RAM is properly fit into SLOT or not. Take it out and insert it properly again. It will resolve your problem. If the problem still remain continue then RAM slot in your PC may be got damaged then you have to change the RAM with new one.
Posted on Sep 25, 2009
    Problem Solver:
  • 8 Answers
Once turn off ur pc abd remove ram and fix it in other place of ram
2 Suggested Answers
  • 4 Answers
SOURCE: beeps 2 times & a warbling noise when trying to boot up - unplugging power lead & pressing ON/Off button & reconnecting power lead starts up OK - but it can be OK for several days & th
i think you have to check the connection cable from your HD
Posted on Jun 24, 2009
When i turn on my lenovo g585 lap it start with one beep and comes the display and go boot with continuous beep sound and stuck the lap
Hi...
Gives continuous beep sound , When my laptop switch on (Lenovo G585). No display but leds (power & battery) were blinking.
Sep 10, 2013 | Lenovo G585 Laptop
My EEE PC1015 PE keeps giving error message "Reboot & Select proper boot device of Insert Boot Media in selected Boot device & Press a Key." Also, beeps continuously for approx. 1-2 min then stops...
in situations like this you just must download the correct manual and reinstall the OS,if you have no disk choose a different OS some are virtually cost-free
Aug 29, 2010 | ASUS Eee PC 1000H Laptop
MSI K8N Neo V2.0 beep code problem is continous beeps.
That's usually a bad ram stick. Shut down the pc & remove one stick at a time starting with the one furthest from the cpu & work your way down to the first one. When it boots without the constant "beep", you found the bad one! You can also check www.msi.com & look in the support area for a solution if mine is wrong.(I'm never wrong though,lol)
May 16, 2010 | MSI K8N Neo Platinum, 601-7030-010,...
WHEN I SWITCH IT ON IT KEEPS BEEPING LIKE A BUTTON IS PRESSED DOWN
Different PC manufacturers have different BIOS Boot codes.
Read first
http://pcsupport.about.com/od/nonworkingcomponent/ht/beepcodestb.htm
Then read:
http://www.pchell.com/hardware/beepcodes.shtml
http://www.computerhope.com/beep.htm
http://networking.ringofsaturn.com/PC/beep.php
Apple:
https://mediawiki.middlebury.edu/wiki/LIS/Apple_Computer_Beep_Codes
http://www.techbase.iofm.net/tips/applemac/tip1.htm
http://www.user-guides.co.uk/download/apple/applebeep/apple-beep-code.html
Dec 15, 2009 | Compaq Armada E500 Notebook
Sony pcg-tr3a laptop beep continue &notbooting
Ur ram is not working u need to change ram.this beep is becouse ur ram is nor wroking.
Plz dont forget to rate thnx
Sep 09, 2009 | Sony PCG-TR3A Notebook
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
Beeps 2 times & a warbling noise when trying to boot up - unplugging power lead & pressing ON/Off button & reconnecting power lead starts up OK - but it can be OK for several days & th
By warble, do you mean a high pitch non stop noise? If so... I think I went through that bout 2 months ago, it was a easy fix. Ifr it is the same problem
May 29, 2009 | HP Vectra VL420 Intel Desktop PC - Intel...
The laptop is not working and when it is turned on it has a beeping noise
There are different types of beep called POST beeps.
This informs that what the problem is on booting the system.
As per your concern I think it will be along beep 3-4 seconds long, and continued again and again, if this is your case then your RAM might be faulty or it is not connected properly.
To fixed the problem, re-connect your RAM and try,you should also try to boot with another RAM.
Thanks
Iqbal
Mar 24, 2008 | Computers & Internet
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
