Question about GE Dishwashers
Dishwasher is leaking water. Water is puddling
Dishwasher is leaking water. Water is puddling underneth and the side insulation appears to be wet.
  • 403 Answers
There is a tube on the side of your dishwasher for over flow. It sounds to me like your washer was moved and it banged against that line. You can put some caulking around where it enters the washer and that should be fine. The bottom can be several things. If your washer was removed and reinstalled like say maybe floor installation the supply line, or waste line may not be tight. If your unit has not been moved recently it is most likely the motor housing. Take off the one or two covers on the front bottom of the washer. Place the washer through the cycles and with a flashlight see at what cycle and where the water is coming from. It it appears to be coming from the white housing it's the motor. It's cheaper to just replace the unit as these motor housings are around $150.00. Check out craigslist. Hope this helps.
JimmyC
Posted on Sep 25, 2009
Testimonial: "This certainly gives me some options to try. Thank you. The dishwasher was recently moved due to renovations so could be some of these problems."
Dishwasher Leaking Water Front left side (when facing)
Had a similar situation with my dishwasher. Turned out there was some hard water build up on the rubber gasket. I would start there first. I would not use any harsh chemicals on it, (it may jeopardize the gasket) it usually flakes off. Hope this helps.
Nov 20, 2013 | Maytag Dishwashers
Displays E1 code. water is on
Hi there Dolly, error code E1 relates to water leaking. Its the code the machine displays when the flood switch in the bottom of the machine activates. The flood switch activates when the bottom of the machine gets filled with water from a leak. I surgest you have a look underneth the machine for signs of water. I hope this helps regards Gary.
May 04, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Basement flooded;Water Heater insulation is a little wet on right side of entrydoor; Relighting the pilot light has been unsuccessfull; What do you reccomend?
tank looks to be leaking and getting the insualtion and floor wet .. so replace water heater?? Once the tank is leaking there is no repairing it..
Mar 16, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Kenmore Dishwasher 17372 is leaking water through tub water inlet
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
wqeyrad
Jan 07, 2010 | Kenmore 24 in. 17372 / 17374 / 17379...
The insultation on the bottom of the door is wet. My repairman said water is getting behind the soap dispenser and the rubber gasket around the dispenser is hard. The dishwasher is only 4 years old. Is...
Yes it is possible, and depends on your water hardness. An easy was to check is to use a silicone caulking product and caulk around the dispenser. Let it cure fully before using the diswasher. Check for leaks.
Oct 05, 2009 | Bosch Dishwashers
Leaking from the lower right hand side during rinse cycle.
I had the problem with dribbles of water from the right side lower edge of the door, causing puddles across the floor.
Found there was a RECALL on MDB6000AWW models. The door inside panel was replaced by the dealer for free. No more puddles.
Aug 27, 2009 | Maytag MDB6000 Dishwasher
Water is leaking from my downstairs air conditioning vent
I seriously doubt it's the AC. It may be the draing in the upstairs shower, If it's a water line it is a very small leak and is probably puddling in you ceiling. if not nbeing absorbed. Best thing is contact your homeowners insurance because you are going to not only have a plumber to deal with , but a mols issue as well. Sorry, good luck.
May 31, 2009 | Heating & Cooling
Rain water leak
The most common source of this kind of leak is the windshield, have a glass shop check the sealing around the glass
Sep 04, 2008 | 1992 Mercury Grand Marquis
Leaking water on floor in front of dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Dec 27, 2007 | Kenmore 24 in. 16022 Built-in Dishwasher
Dishwashers Logo
213 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
