My computer when in 115v it turns on and then immediately off
My computer when in 115v it turns on and then immediately turns off, even though it has worked on 115v for a year. So I tried switching it to 230v and it stays on but the cpu fan does not work and nothing comes up on the monitor. Is my computer fried or can this be fixed?
  • 788 Answers
Switch the power button on the rear of the supply back to 115V.
Have someone remove the supply and replace with the same.
Sometime, just disconnecting the supply connections at the motherboard and re-connecting them, resets the supply.
I would go that rout first and go from their.
Posted on Sep 25, 2009
Will a Packard bell i media desktop run on united states power ?or is it strictly designed to run on European power ?
Here in the US, and with more than 20 years experience as a computer tech I would venture to answer that almost any computer should work almost anywhere in the world.
You only need to look at the input voltage and make certain the power supply is set to match the line voltage supplied where you are. Standard electricity in Europe is 115v or 220v @ 50hz and in the US it is 115v (almost universally) or 220v (rarely) @ 60hz. The biggest difference is the ac frequency used but for computer power supplies that is immaterial.
A computer power supply converts the ac input power to regulated and filtered 3.3v, 5v, and 12v dc so the ac frequency does not have any affect on the filtered dc output that actually operates the computer. Almost all power supplies have a voltage selector switch near the power cord plug on the back of the computer to choose 115v or 220v. Newer power supplies are designed to be auto selecting on input voltage so even that manual selection is no longer required.
You likely will need a different power cord since the shape of the prongs on power outlets in Europe is always different than here in the US. If I remember correctly from my time in Europe that even varies by country there.
As long as you keep in mind the possible different voltages and the different prong shape and arrangements for the ac power source your packard bell computer should work well here in the US.
Absolute worst case scenario would be that if the power supply already installed in your PC is extremely low quality and was designed to use only one input voltage then it is possible you may need to replace the power supply with one that is designed to be used anywhere.
Mar 02, 2017 | Packard Bell Computers & Internet
DeLonghi DD70PE Dehumidifier. Why does pump often stop working and F/P shows an error code until reset?
id be inclined to think that for some reason the pump is taking too long to pump tank out (or it thinks it is ) this would cause the fault you describe and the safety control shuts pump off for fear of a problem
Aug 18, 2015 | DeLonghi Dehumidifiers
How to gain access of keyboard from virus
Try starting your computer in Safe Mode
To do that
Turn off your computer
then turn it back on
and immediately press and tap the F8 key on the keyboard
even though there's no display yet on the screen
the one that will appear on the screen should be "Windows Advanced Boot Options"
and safe mode is there
you just need to choose it by the arrow keys on the keyboard
then once you selected it just press enter
you computer will go to Safe Mode
Aug 07, 2014 | Dell OptiPlex Computers & Internet
I I HAVE A KOHLER 220 VOLT PUMP FOR A TUB. WHICH WIRE IS THE GROUND WIRE WIRES ARE -- BROWN -- BLUE ---- AND GREEN/YELLOW STRIPE
green is always ground. even with a yellow stripe. you are missing one wire though. 220v requires 4 wires.
two hot (115v)
one neutral
one ground
Dec 31, 2010 | Kohler Home
Ok i neeed help!!!!!!!! on my power supply there is a switch which you can move to 115 volts to 230 volts. everytime i switch it to 230 volts the computer wont turn on? why is this happening? when i put it...
This is the power supply for your PC, depend on your local country power supply, some country like North US may use 110 V in their daily use electrical stuff and some country like Euro, UK use 240 V.
Your PC power supply is design to suit this 2 type of power input so can be sold everywhere. What u need to do is to make sure your local country power supply voltage and then just switch the input correctly, i think u have done it.
YBC (/\)
Oct 20, 2009 | Computers & Internet
My Amana Side-by_Side SXD26VL is not cooling. The
clean cond coil at back of unit.
check amp draw on the compressor wires.
Sep 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Camera turns itself off immediately even though it is fully charged
are you using rechargeable batterys or cheap ones
you have to get batteries specifcly designed for digital cameras or they wont power the camera properly.. try using different batteries !!
May 22, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
