Question about GE Refrigerators
Ice maker is overfilling
My GE ice maker is over filling and dripping into the ice dispenser. how can I make it dispense less water?
  • mikeskad1 Sep 25, 2009
    the model is GSS201EPA WW and where is this switch located?
  • 403 Answers
It sounds like your water control switch is bad. Is this a commercial unit or residential unit. I need to no this as repairs are done differently. If you can let me also know the model if you can. Try turning down your water supply in the back. Only problem with doing this if the unit does not get enough water it could burn the motor. Let me know what you find. Thanks.
JimmyC
Posted on Sep 25, 2009
  • James Chavez Sep 28, 2009
    Refrigerator - Icemaker Makes Too Much Ice and Overflows the Bucket
    If your icemaker is making too much ice or overflowing:
    • Be sure the bucket is properly positioned directly under the icemaker.
    • Make sure the feeler arm is not broken. (the feeler arm is the metal rod or
      plastic paddle. The metal arm moves up and down and the plastic paddle moves in and out when the
      icemaker cycles). If the arm is broken, the icemaker needs to be replaced.
      You can order from GE Parts 1-800-626-2002 or order a part online.
    • Some refrigerators have a freezer shelf that must be
      used when installing an icemaker. The purpose of this shelf is to elevate
      the ice bin. If the shelf is not installed properly, the feeler arm does
      not correctly judge the level of ice in the bin, causing the ice to overflow.
    NOTE: Bottom mount refrigerators with icemaker in the fresh food
    section is a service issue. The feeler arm is vertical and cannot be
    seen.
    If you would like to schedule a service appointment, please contact GE Consumer Service or schedule a service appointment on-line.
    How icemakers work
    Automatic icemakers check the level of ice in the bin using a "feeler arm" (metal rod or plastic paddle).
    When a load of cubes is dumped, the feeler arm moves to allow cubes to fall. If the feeler arm is not
    able to move back due to ice cubes blocking the path, the icemaker stops production. As ice is removed
    from the bin, the arm may then spring back into position starting production once again.
    Let me know it this works, also if I can provide you with more info.
    JimmyC
    To turn off an icemaker
    • With the metal feeler arm, simply raises the arm until it locks into place.
    • With the plastic paddle, turn off the electronic power switch found
      on the front of the icemaker icemaker or on the refrigerator control
      panel..
  • Krunked_si Sep 09, 2010
    i have a residential model and my water did not stop flowing from the fill tube. I had to turn off water supply. How can I fix this?
Hi, I have a Kenmore Elite Refrigerator model #596.76253702 that leaks water from the bottom every time the ice maker refills. The problem keeps getting worse since I purchased this product 2 years ago.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Ice maker water not stopping
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Aug 24, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The water dispenser and ice cube maker stopped working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Apr 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The water dispenser in my refrigerator ice maker is leaking
if you have recently changed your filter, had the water turned off, or disconnected from the ref this is a common problem. you have air in your water line. fill 5-6 large cups of water or until it stops spurting and your drip should go away
Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker makes ice cubes, but the doesn't dispense ice cubes.
If you could observe exactly where the water is dripping from it would help but...If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Aug 19, 2009 | Refrigerators
Water leak from ice dispenser line
hi..
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line...
thank u
rate me!!
Jul 26, 2009 | GE Refrigerators
GE side by side; model # TFX25JRYD Serial #
So the dispenser is getting water. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Jul 12, 2009 | GE GSS25JEM Side by Side Refrigerator
Ge top freezer refrigerator ice maker problems
most likely bad icemaker but could be a leveling issue or overfilling which both would be very noticable
Jan 04, 2008 | GE Â 17.9 Cu. Ft. Top-Freezer...
Refrigerators Logo
448 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
