Question about Nintendo Rock Band for Wii
I a, trying to assemble a set of drums without instructions and cannot get the narrower piece of the leg that has the white plastic end to fit into the larger leg. Is there just 2 pieces to each leg and how do they fit together ? Thanks
    Sniper:
  • 58 Answers
Here is you a step by step instruction with pictures,,,,,
If this helps PLEASE RATE.. :) Thank you....
http://www.wired.com/gamelife/2007/10/how-to-assemble/
Posted on Sep 25, 2009
Testimonial: "Thanks!"
I need to reattach a couple of plastic pieces that fit on the under side of the seat on my motorcycle. The pieces have broken off as the bike was probably dropped at some time. The two pieces plastic...
There is a two part plastic glue found in hardware stores, but if you are trying to end join two narrow pieces together without adding a backing piece, it won't work.
Dec 17, 2014 | Adhesives, Coatings & Sealants
The other end of the elbow will not fit into the tubing. Do I need to take the plastic piece off?
There should be a clear plastic end on the mask tubing. This fits inside of the white rubbery tubing that fits onto the machine. It is a tight fit the first time or two you put it on.Try sliding it in one side at a time.
Oct 03, 2013 | Respironics Wisp CPAP Nasal Mask with...
How do you assemble the inner section of the reel and what is the spring for and where does it fit.Where does the piece with the grey one end and white screw end fit? Instructions with pack are not clear...
the spring goes under the spool(where the string is wound), the outer housing is where the grey piece and screw are used, as it secures the head to the shaft. you will need to put the outer housing one,then the grey piece,the screw,the spring,spool and then cap. Hope this helped Tim
Jun 11, 2011 | Garden
Don't have the directions to put evenflo exersaucer together, need help. Is there somewhere I can get the directions? reg. number 07T-0538604
Instructions
    • 1 Place the large, round base on the floor. The outwardly curving edge should be facing downward.
    • 2 Attach the three pedestals to the base. To do so, insert your finger into each pedestal and loop the spring within around the hook found on the base in the appropriate holes. Insert the three plastic tabs on each pedestal into the base, locking them into place.
    • 3 Press the wider end of a lower leg assembly onto each pedestal piece. By wiggling the lower leg assembly side to side, you will eventually snap the pieces into place.
    • 4 Hold the seat ring in your lap with the open edge facing upward. Press each of the six wheels into the wheel holders around the edge of the seat ring. Each wheel will snap into place when positioned correctly.
    • 5 Insert the cloth seat into the seat ring, aligning the diamond on the cloth seat with the triangle on the seat ring. Each plastic tab lining the edge of the cloth seat attaches to a peg on the seat ring. Snap these connections into place.
    • 6 Hold the Exersaucer tray on its side and press the seat ring into the center. Once the seat ring snaps into place, it should be able to spin in place.
    • 7 Attach the three spring caps to the Exersaucer tray. These spring caps cover the three large holes in your tray, and are attached by a firm clockwise twist.
    • 8 Attach the upper leg assemblies to the upper leg crowns. These crowns act as the "socket" and the upper leg assemblies act as the "ball." By pressing them together with a click, the upper leg assemblies can twist and rotate in place.
    • 9 Turn the tray upside down and press each upper leg crown base into the round holes in the tray with a firm twist. Each upper leg crown features a height adjustment hole, which will face outward when properly attached.
    • 10 Turn over the tray so that the upper leg assemblies are facing downward. Insert each upper leg assembly into a lower leg assembly, being sure to pull away the height adjustment tab to allow the assemblies to slide together.
    • 11 Press each toy into its respective port on the surface of the tray. The toys each have a distinct base, which clicks into the correspondingly shaped tray port
May 10, 2011 | Toys
I recently bought an Amloid My First Mini Cycle for my son. I was only given on packet of assembly intructions for the fork and front wheel of the cycle. Once you put that together the instructions say...
You need to hammer the cap on. The tube with open ends fits over the cap and lets you hammer it on. To make it work, you need something to hold the other end, like a block of wood, or I found a hockey puck worked perfectly. Assemble the rear wheels, then turn the cycle on its side with the cap end of the axle down. Put it on the block of wood or the puck, and then hammer on the cap with the help of the tube. Now if you can help me get the handlebars on, I'd be eternally grateful. Problem is the spacers seem to be too big to allow the fork into the slot in the handlebars, and without them, there is nothing to screw into to hold the handlebars.
Apr 30, 2011 | Toys
I took apart my eureka quick up vacuum and am not sure how to re assemble
I just did the same thing and had to reassemble also. I recommend turning it upside down. First make sure the belt is wrapped around the motor threads as well as the brush threads, then rest the brush more or less where it goes in the front of the vacuum. The white plastic pieces each have a small hole - you need to insert one end of the brush into each while plastic piece. When you lie the plastic piece flat you should see that the other end fits together with the top of the vacuum. The trickiest part is getting the tiny little wheels into place. Just worry about the 2 in front first. Set them carefully into place in the square holes in the front corners of the machine. Use your finger or a screwdriver to fit the mini axles properly into the grooves. Carefully push the bottom of the vacuum into place until it seems to snap in place (be careful that the wires are tucked in well) and screw in the 4 main screws. Final step is to reattach the smaller black cover to the bottom (back) side - be sure to get that wheel in place before fitting the cover on and then tighten up the final 2 screws.
Mar 25, 2011 | Eureka& Cordless Quick Up Vacuum
How to install xante ilumina drum units?
When you unpack the drum it has like a white nylon and three orange plastics. Remove the three plastics(tapes are holding the plastics) and at the end remove the white plastic it has an arrow. Do not touch the drum. Make sure not to much light hits the drum. You have four drums remember to sit correctly the drum and to its correct position.
Jul 02, 2009 | Xante Ilumina Digital Color Press Printer
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Kinderkraft crib model 710
On the bottom of the front rail that drops (the drop rail), there are two plastic tension pieces (one at either end) that engage the two fixed, bottom rail slider hardware (the long, narrow pieces screwed top-and-bottom into the lower, inside portion of the tall, upright crib ends). These tension pieces are spring loaded, and the outer edge of each one rides along the outside (i.e., the parent's side) of the two bottom metal rail guides. Their purpose is to supply outward pressure against the lower part of the drop rail - that's what you push against when you press your lower leg upon the bottom of the drop side of the crib to lower it. They insure that when up, the drop side locks safely into place. I suspect these tension pieces are your problem. It sounds like they are improperly installed. Good luck.
Sep 10, 2008 | Kinderkraft Vermont Crib
Nintendo Rock Band for  Wii Logo
192 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
