Question about Sony Handycam DCR-TRV110 Camcorder
Cam keeps swithching from 8/Hi8 to D, then D to Hi8 mode. Can you help?
I've checked both tape formats at a camera shop = fine. Appreciate any fix-it suggestion. Thanks !!!!
Video heads need replacing
Posted on Mar 19, 2008
Hi8 MP tapes
hi,
what is your camcoder ? HI8 or Digital 8 did you record all the tapes with same camcoder ?
what ever HI8 doesnt go on Digital 8 and vice versa
Apr 02, 2014 | Sony Video Cameras
How to play tapes not recorded by Sony Handycam DCR-TRV130 Digital-8 Digital Camcorder
It is my understanding that the camera won't playback those formats, timecode or not. There are VCR type units for the HI8 and other formats. They should be cheap on eBay now...
Nov 18, 2012 | Sony Handycam DCR-TRV130 Digital Camcorder
I have a working TRV81 Hi8 HandyCam and 15 Hi8 tapes I'd like to convert to digital and make ready for edit on IMovie (Mac). Would appreciate any advice....
The only way to do that is to play it in a device that plays Hi8 tapes and somehow converts it to a digital signal (likely through firewire as DV), then capture it to your computer just like a digital camcorder.
There are several ways:
1. Buy a device (like a camera) that plays it, output through RCA cables to your other camera or tape deck that is digital through the line in, and then just record that. (Alternatively, you could put that signal into a DVD-R machine and record onto a DVD, then just copy the files off the DVD, if you don't have a way to capture DV through firewire.)
2. Buy a device that plays Digital8 (same tapes, but miniDV FORMAT) and output directly from the tape through firewire. This means you must buy a SONY (only brand that made [now discontinued] Digital8) camcorder or deck [if decks were made, though those are usually expensive].
So, the simple answer: get a Digital8 camera and capture, or get another digital camcorder and a Hi8 camcorder and play through the digital one into the computer.
Buying a Sony Handycam (OLDER model) will be your easiest option, and probably possible on ebay, etc., for $100-$200.
Short of this, you could look to a friend or a professional solution for just getting the tape copied (like VHS->DVD services exist, there is probably some place you can mail your tape to).
EDIT: I should add: You included "8mm" in your title-- that is a bit confusing. 8mm refers to a few formats. One is film (obviously not what you're referring to), but then there is the older "8mm" tape format; it's like Hi8, but I believe it's actually not the same tape-- unlike Digital8 and Hi8which share a physical medium. I don't think you can get an 8mm -> Digital device, so you'd need to go through the RCA cables, as described above. [And though Hi8 is actually 8mm in width, it's not quite the same as the other "8mm" format... for whatever odd reason someone decided.... frown.gif]
However, I suspect you ARE actually working with Hi8, so this shouldn't be a problem.
Nov 24, 2010 | Sony Handycam CCD-TRV81 Camcorder
Sony handycam video cassette
To the best of my knowledge 8mm VTR's have not been available for some time now. On the other hand there are plenty of Hi8 cameras and players available after market. eBay is a great source. Keep in mind that Hi8 cameras and decks will also play standard 8mm video tapes.
There are also many video tape transfer services that will transfer your 8mm tapes to DVD or other formats of your choice. Just Google "videotape transfer service"
Aug 28, 2009 | Sony Hi8 CCD-TRV138 Camcorder
Imovie imports Hi8 tape but not plain 8 tapes
What it is, is the standard 8mm tapes are not digital, and therefore won't import into imovie, unless you have the 8mm to Hi8 option enabled in playback mode, by setting it in the menu, under playback settings.
Dec 29, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
HandyCam - dual format -
Video head is broken, mine does the same.
Dec 16, 2007 | Sony Handycam DCR-TRV110 Camcorder
Camcorder won't playback most Hi8 tapes
may be your camera not design to play the analog tape...there are some model that can playback a analog tape...i think your camera is for digital playback only.... check your user manual
Aug 11, 2007 | Sony DCR-TRV285E Digital-8 Digital...
RCA PRO854 camcorder
maybe I would buy your camera,
yes as far as I know hi8 and 8mm are completely different cameras,
where are you and how much for the camera?
david@fullbliss.com
Jan 21, 2007 | RCA PRO854 8mm Analog Camcorder
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony Handycam DCR-TRV110 Camcorder Logo
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
