2001 Ford Escort ZX2 Logo
Posted on Mar 15, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rough idle, car stalls frequently at stops
I have a 2001 escort, the car runs smooth while driving, but as soon as I start to come to a stop the RPMs drop drastically and 99% of the time it stalls before I even come to a complete stop. If I use my AC the car will inevitably stall, & the serpentine belt makes an unbearable squeaking noise every time I turn the wheel. The belt tensioner was recently replaced because it threw the belt. i believe the rough idle had a lot to do with the tensioner going out, seeing as how the car jerks and vibrates pretty violenty at idle
I changed the spark plugs, wires and the coil was tested and works fine.
I cleaned the MAF sensor, and replaced the cam sensor.
I googled the codes from Autozone, and everything came up having to do with timing. Could timing be causing these problems? And if not what are my other options?
Jeff Armer
Level 3:
  • Ford Master 15,575 Answers
  • Posted on Mar 15, 2017
Jeff Armer
Ford Master
Level 3:
Answers
15575
Questions
Helped
7109560
Points
73899
We would need to konw the codes to be able to answer that .
5 Related Answers
Anonymous
  • 11896 Answers
  • Posted on May 06, 2009
SOURCE: 99 escort sputters and stalls, engine bogs down in idle
The CAMshaft position sensor is faulty.
Mackmech11
Josh
  • 122 Answers
  • Posted on Apr 18, 2010
SOURCE: changed timing belt on my 99 ford escort zx2 car no
if you have a no spark scenario i would check your crank sensor located at the top left side of the harmonic balance pulley.the crankshaft (about 11'oclock) a 2 wire plug with a sensor on it check to see if it is damaged or unsecured. this sensor can cause no spark if not working correctly. This sensor is based of frequency not voltage testing is difficult, just make sure that there isnt too muck air gap. and that it is secured.Lastly may want to check timing possible that the belt has jumped some teeth and she has fallen out of timing. maybe a bad tensioner The coil will adapt i think up to 10 degree, ****** or advance. Good luck
Anonymous
  • 921 Answers
  • Posted on Apr 27, 2010
SOURCE: 2001 Ford Explorer idles rough when at a stop in
sounds like a vacuum intake leak..check a those little tubes for cracks and security. also check your transmission levels, this will sometimes cause a surging problem while driving..if all this checks good then it might be dirty or clogged injectors..purchase a can of Sea Foam from Autozone $10 pour in 1/2 can to half tank of gas and drive around for thirty minutes..highway driving preferred, and see if that will clean up the fuel system.Can i get some feedback, thanks
A
Anonymous
  • Posted on May 01, 2010
SOURCE: 2001 ford focus idles rough will stall
Sounds like a vacuum leak
Also check out EGR Valve and TPS Sensor.
Testimonial: "THANKS BRO"
Anonymous
  • Posted on Mar 04, 2011
SOURCE: My 2003 Ford Escort ZX2
2003 zx2,rough idle when stoped and the car in drive,runs fine on open road,while idleing i opened the hood,when i loosened the oil fill cap i heard a pufffff,like a relief valve,it should not be building pressure should [email protected],please
The car keeps stalling splutters then stops running
Hyundai Elantra Questions - Engine stalls / hesitations at ...
www.cargurus.com > Questions > Hyundai > Elantra
CarGurusApr 20, 2013 - Engine stalls / hesitations at idle and low acceleration - Model: 1999 Hyundai ... stopped... and then at one last desperate pump of the gas pedal, the ...Despite all this, most of the time, the car runs smoothly, and several shops have .....Keep in mind that my car is Elantra 2001 with 82k miles on it, the car will ...
My car keeps shutting off when idle.. - CarGurus
www.cargurus.com > Questions > Chevrolet > Impala
CarGurusFeb 15, 2013 - whenever im on breaks or, it stutters for then cranks right back up. ... of your question, the stalling, hopefully somebody will come by to help you on that. ....Car having trouble starting,rough idling,shutting off at stop 2 answers.
How to Fix a Car That Stalls: 7 Steps (with Pictures) - wikiHow
www.wikihow.com > ... > Cars > Car Maintenance and Repair
wikiHowThere are many things that could cause a car to stall. ... Your engine stops runningbecause it is not igniting gas in the cylinders, this occurs either because there ...
1helpful
2000 Ford Escort zx2 runs rough and stalls in reverse
The Ford Escort ZX2, the 2.0 liter is a interference engine,The valve and the piston kissed each other as they met with a broken timing belt,Just to let you know a cam position sensor does not create rough idle, it can stall the engine at a stop sign,but the solution is a valve job, and who ever put the timing belt on after the job should have done a cylinder effeciency test.
1helpful
Engine Runs Rough at Idle
go to auto zone,its free ck.throtle senser
2helpful
2answers
96 honda accord v6
looks u up for a new head soon,,,,,if u leave it to long possible new motor
3helpful
Trouble with my rpms
Here are some of the causes of surges, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
2answers
Idle Air Control acting up.....
check your EGR valve, make sure that it is not clogged and the valve can move smoothly
2helpful
2answers
Corsica stalls at stop signs
sounds like the EGR valve is sticky, take a small screw driver and tap the valve when the engine is at idle and you will notice a change in the way the engine runs, if the vehicle smooths out disconnect the valve and drive the vehicle and it should not cut off please let me know and dont forget to rate me!!
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
