Question about Dometic Rooftop RV Air Conditioner
Have Dometic 600315.331 Have checked both caps, relay (PTCR), compressor windings (open & short)- All check OK. I wonder if we have low freon? Suggestions??? Thanks
  • 1 more comment
  • s_heyer Sep 25, 2009
    Thanks Terrencio. When switched on fan runs, all modes, but compressor does not appear to try to start at all- no hum for even a second. 2)I have continuity between all, r/c, s/c, r/s compressor windings but no reading to ground. I believe it is Okay. 3)I checked the caps, both start and run with ohm meter, both deflect and return. I have not put an amprobe on yet because I don't think the compressor is trying to start. By the way I also checked the PTCR which has continuity and the overload. I didn't see any low pressure switch either in the schematic or on the physical unit. Where do I look next? Thanks.
    Could you send me the link to the service manual? Thanks
  • terrencio
    terrencio May 11, 2010
    I found the manual online, the wiring diagram does not show any low pressure switches that would shut it down due to low refrigerant. So I have to ask a few questions. 1 what does the unit do when you switch it on? Hum? fan only? or nothing? 2. when you say you have checked the compressor windings, what are the ohm readings, r-c,s-c, and r-s, and is there any ohm reading from any winding pin to ground, not continuity, but ohms check? 3. When you say you have checked the caps, is this an ohm meter deflection test, or capacitance test, if capacitance what are the readings as compared to the capacitor ratings? I am more interested in the run cap than the start cap at this point. 4. If the compressor hums but does not start, what is the amperage draw? with the above info. I will be better able to assist.
    President:
  • 3,433 Answers
Dometic has had a bad run of pc cards the've been changing. Contact a dometic dealer and make an issue over the curcuit board and once hey get it lit, They can tell more about the refrigerant charge. Good Luck, Ned
Posted on Sep 25, 2009
Ac compressor runs but will not cool
check thermostat, replace capacitors amp compressor to be sure its running if not relay module issue.
Aug 08, 2015 | Dometic 651815 Duo Therm 13,500 BTU...
AC not working
Please first check the fuse, if it's okay, have the refrigerant checked by an A/C specialist.
Aug 01, 2014 | Toyota Avensis Cars & Trucks
Compressor cycles on overload checked run cap it reads 15.7 ufs rated 15 .installed new overload and relay compressor still cyc;es. Installed a 3 and 1 and compressor ran. can I install the 3n1 permently...
The way I check compressor problems is : If it kicks off on the overload , remove the overload / relay . Check all 3 terminals with the meter set on beep . Also , check each terminal to any part of the copper compressor lines . A beep there would indicate a shorted compressor . I would then replace the overload / relay ( wiring correctly with the capacitor ) and connect an amp meter to the overload wire . Plug in the refrig and check the compressor run amps . New compressors usually run 0.7 amps . If the compressor runs anywhere above 2.5 amps , then a lot of wear is on it and not much longer life . I never use a 3 in 1 due to these are only a partial fix and will not last long . Actually , If a refrig comes into the shop , these are jerked off the compressor and thrown away . I consider 3 in 1 absolute junk and frown on any technician using them . Refrigerators come to our shop ( we pick up from lowes , home depot trade ins ) and I've thrown many away , which also means they cannot be permanently used .
Aug 02, 2010 | Maytag MSD2758G Side by Side Refrigerator
What will cause a ptcr 5overload to burn
Could be the fan motor, the relay or the compressor itself ; if the fan doesn't work , replace it, if it's ok , replace the compressor relay (no more than $30 ) and if still having troubles , probably the compressor is bad. But before do anything make sure the condensing coil is clean and free of dust .
Oct 13, 2009 | GE Refrigerators
Controls checkout... no compressor start. Freon??
You can buy line taps that clamp on to give you service ports
Sep 25, 2009 | Dometic Rooftop RV Air Conditioner
LG LHD30 the compressor does not cycle on
Compressor won’t Start
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Aug 07, 2009 | LG DH30 GoldStar Dehumidifier
Rooftop a/c unit fans runs but when i turn it to ac it trips the breaker. what do i need to do?
If it is tripping the breaker when the compressor is trying to kick on, then you probably have a bad start capacitor. Remove the upper shroud and then the small access panel on the side of the unit. Make sure the disconnect power before accessing this panel. In this area, there are two to three capacitors (depending on the model). The start capacitor has a small black relay on top of it, visibly inspect that for char or burn marks, if there are any, then replace that capacitor and relay(PTCR). If there are no burn marks, then you need to have the compressor checked out for shorts or open windings.
Hope this helps,
Jeff
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Brisk air, dometic rv a/c unit
possible tired motor, or dying capasitor
Jun 24, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
452 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
