Question about Canon PIXMA MX310 All-In-One Printer
Black ink smudge - Canon PIXMA MX310 All-In-One Printer
    Scholar:
  • 97 Answers
I have a different model but on mine if you go to
Start
Control Panel
Printers & Faxes
Click on Your Printer Name
Click on Printer
Click on Properties
Click on Maintenance
there is a menu in there that will allow you to perform various cleaning functions. One of them is removing smudges.
Also, if you have your printer set for the wrong type of paper in your word processor, and you are printing say, on double-sided glossy and it's set for normal, you will not only NOT get the quality you want but the ink won't have enough time to dry before doing the other side and will cause a lot of smudge problems.
There are other solutions depending on whether or not you attempted to refill your cartridge.
Posted on Sep 25, 2009
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Jan 21, 2014 | Epson Stylus 1400 InkJet Photo Printer
Printer is smudging ink on left side of paper
Hello sir; Pull out transfer belt unit replace belt clean blade. it should take care yor problem.
Aug 28, 2009 | Ricoh Aficio CL3500N Laser Printer
Printer spits out black ink and smudges when printed
Your printer apparently needs to be cleaned, using your canon software utility. If the cleaning doesn't help, try to replace cartridges
May 31, 2009 | Canon MX700 Office All-In-One InkJet...
4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Apr 07, 2009 | HP Color LaserJet 2600n Printer
Waste ink tank over flowing??
Hi, like every ink jet printer, there should be an ink pad(spunch) at the bottom of the printer to collect the waste. That spunch might be full of ink. You could locate it, remove and try to clean it under the water. See if it works
Apr 03, 2009 | Canon i860 InkJet Photo Printer
I have black smudges on my printouts. I using
This may be the cartridge itself, take the black ink cartridge out and check the head on it (the part that points in to the printer, usually down) and see if it is dirty or has ink smudges on it.
Mar 12, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Black Smudge of ink along top edge paper Brother Intelifax 2800
try cleaning the grid on the drum unit otherwise there could be some thing on the fuser preasure roller.
Jan 16, 2009 | Brother IntelliFAX 2800 Laser Fax
Ink will not dry
Without having to apply a varnish, the best way is to use frog juice which is a spray which come as both matt or gloss and gives the same eefects as a varnish but isnt noticable with the matt. This reduces the solid black areas from smudging.
Nov 03, 2008 | Canon imagePROGRAF iPF8000 Printer
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
Canon PIXMA MX310 All-In-One Printer Logo
432 people viewed this question
old marine
old marine
