Question about Canon PIXMA MP210 Photo All-In-One Printer
Error e then 7 flashes in window - Canon PIXMA MP210 Photo All-In-One Printer
    Scholar:
  • 81 Answers
I dont know why Cannon persist wuth there stupid messages by morse code,
E 7 means that a sensor has detected an incorrect ink cartridge
Options to fix
1.Check the ink cartridges are correctly installed
2. If you have recently replaced an ink cartridge with one from a supplier other than Cannon feplace the cartridge with a Cannon branded prosduct
3. If everything looks ok then try powering down the printer, unplug wait 2 minutes for all residual power to drain, then power up to see if the printer has resolved the problem, this just resets the sensor which reports the error but it often works as the sensors are the most likely part to give intermitten faults
Posted on Sep 25, 2009
How do I make pc video games work on windows 7.
Are the games Windows 7 compatible. They should have a notice on the box. If not, you can try installing them in compatibility mode.
Oct 10, 2014 | Computers & Internet
Windows 7 with Gigabyte motherboard says "ntldr is missing"
Check if UEFI is disabled after flash with newer BIOS version. If you flash BIOS the default settings gets loaded again. Check hard disk settings and boot settings.
Mar 03, 2013 | Gigabyte Computers & Internet
Windows 7 will not read SD card
Do you get an error? Does the computer see the card at all? Check in Disk Management
Right click "Computer", Properties, Manage, Disk Management. Do you see the SD card here, any errors?
Dec 27, 2012 | PNY Electronics - Others
WINDOWS 7 NOT RUNNING FOR MY PC
Please tell what error your PC shows or what problem ou faces... i might help you in this one
Sep 16, 2012 | Gateway 560GE Intel Pentium 4 531 3GHz /...
The computer won't boot Windows 7. It starts up fine, with the fans running with the LED lights on. Then I get an error message: "CD-ROM Boot Priority ..No Medium" I have checked the bios of...
It sounds like either Windows 7 did not install properly or you have a bad hard drive. I did some research on similar problems and most people have also tried to change the boot priority with no luck. If your are tech savvy I would try to run hard drive diagnostics and possibly reinstall Windows 7. If you are not very technical I would suggest taking it to a competent pc repair technician.
Apr 08, 2011 | Systemax SYX Crossfire X58 Gamer Intel...
How do I fix this error? https://www.netflix.com/layout/jscript/pkg-MoviePlayer-ffffff6-s-416793.js?v=416793 Windows 7 Home Premium 32 bit Toshiba satalite laptop L505D-S5983 Can get on netflex, but...
check for the script,
To fix flash related problems in your Windows 7 operating system try to change the web browser. Sometimes due to the addition of numerous add-ons the browser is unable to play videos online and videos crash too often. Similarly you can use another version of the flash available for free. A number of times it has been seen that using some old/new version of the flash helps to correct this problem. For instance if flash player 9 isn't working well you could try using the flash player 10 version or vice versa.
However, when the Active-X components are behind the Windows 7 flash problem then always check for active-x corruption through a registry repair tool.
You could also try to download and use Microsoft Direct-x technology that helps the multimedia streaming process easier and faster.
Sometimes the flash problems are linked to the conflicts in the sound driver. To cope with this reinstall the drivers. Your Windows 7 can do it automatically after you will uninstall those drivers and restart your computer. Alternatively you can find the sound drivers through the sound card company's web site.
For advanced and easy solution to flash problems and other common PC errors and crashes use RegInOut registry cleaner and PC optimizer software.
The above guidelines allow you to take measures to speed up computer and keep your Windows properly maintained. Prevention is the best cure.
If you need a complete registry cleaning solution and do not have time to follow all the tips you can try this globally recognized software utility available at Intel Partners site here reginout reg cleaner
Aug 19, 2010 | Toshiba Computers & Internet
Can't install quickbooks 2005 - need flash player 7
open the disk file where qb is and look at 3rd party files
then click flash 7 and ignore when it says error
then the darn thing will install no other solution listed works !
but this just did
Dec 20, 2008 | Intuit QuickBooks: Pro 2005 for PC
Canon PIXMA MP210 Photo All-In-One Printer Logo
old marine
old marine
