Question about Canon PIXMA MP210 Photo All-In-One Printer
Paper not feeding thru properly
The paper keeps saying it is jamming yet it is like it isnt feeding through properly. any ideas??
    Sergeant:
  • 191 Answers
Please the dumping roll and paper feeding pad is very celing and
who do use paper ? this paper is very glose papre ? if yes,
when one by one give up and second time
the paper is regulary use the friently paper and out of air in paper
and put the paper trey and use regulary ok.
Posted on Sep 25, 2009
Jam in tray 2 bt there is not paper jams
There may be paper remnants left over from a prior feed jam. Please click the link below and select printers - jams and feed issues to find more info.
HP Color LaserJet 1600 Printer
Aug 21, 2014 | HP Color LaserJet 1600
Epson Photo RX510
Hi when you switch it on have you tried holding down the on off button for about 10 seconds as this often resets most printers.
Also when you sya thier is no paper jammed in printer are you absolutely sure their is not even i tiny bit of paper still stuck as it only takes a tiny bit of paper to make this message appear.
If you are confident in removing the paper feed witch is difficult to do as you need to make sure it goes back perfect as if it isnt the paper wont feed.
Alot of people say their is no paper jammedand they call somebody out to repair the printer and they get charged a fortune for removing a tiny bit of paper.
If holding the button down dont work then try switching the plug on whilst holding down the on off button let me know how you get on ok
Dec 10, 2007 | Epson RX620 All-In-One InkJet Photo...
My samsung clx 3170 keeps jamming up after every copy. You can see where the paper is trying to roll thru. because there is a slight indentation in the paper about a third of the way on each piece of...
Use this link and you will have all the information on your printer you should ever need
http://www.samsung.com/au/consumer/print-solutions/print-multifunctions-copiers/colour-multifunction/CLX-3170FN/XSA/index.idx?pagetype=prd_detail&tab=support
good luck
Nov 29, 2010 | Samsung CLX-3170FN All-In-One Laser...
Says paper jam but there isnt one
off your printer and manually feed paper by turning roller as guide, observe if sensor key freely move when paper pass, some sensor key stock when forcefully remove the jam paper inside.
Apr 05, 2010 | HP LaserJet 1020 Printer
Paper not feeding properly, nothing jammed as I have checked. Loading tray having problems.
Check to see if the printer is actively trying to feed the paper. If you hear it trying to feed and see the wheels turning, but the paper won't feed, check to see if a screw securing the feed wheel has come loose. If you hear the sound, but nothing moves to pull the paper in, then you probably have a bad printer. They're too cheap to replace to bother fixing - so get a new one.
May 25, 2009 | HP COLOUR LASERJET CM4730 F MFP Printer
Canon pixma mp150 saying paper jam but cant see one
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Dec 11, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Epson R220 paper feed.
TRY holding all 3 bottons at the same time for 20 sec this will reset the printer
Nov 18, 2008 | Epson Stylus Photo R220 InkJet Printer
'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
support.canon-europe.com
they suggested i do a roller cleaning - but i cant find this option ?
Jun 24, 2008 | Office Equipment & Supplies
Paper jam even when there is no paper in the printer
I had same problem. Have you checked for paper-jam from the back, as sometimes a small piece of paper may be still jammed in. Pull open the door and check. Do not pull jammed paper from the front as this disturbs the rollers and printing process. I di this, and have had to buy a new printer.!!
Feb 16, 2008 | HP Officejet J5780 All-In-One InkJet...
Paper jam
When you turn the machine on, does it get to READY status or does it go into a jam message right away?
If it gets to READY status, and you get a jam code after you try to print, then your feed rollers might be either dirty or worn. Try cleaning the rollers with with Goo-Gone which is a pretroleum based cleaner that wont dry out the rollers.
If it never gets to the Ready status, then you either have a stuck or broken sensor in your printer. This would be harder to troubleshoot. 1st you would have to know where the sensors are located, and then would have to be able to clean/check and or replace it.
Hope its the easier solution.
Good luck
Feb 07, 2008 | HP LaserJet 5p Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
206 people viewed this question
old marine
old marine
