Question about Whirlpool Duet GHW9150P Front Load Washer
GHW9100LW1 W/POOL WASHER
Power on but will not start
  • 2 more comments
  • dkei Aug 05, 2008
    Power on/wash cycle will not start. I checked to make sure the water is on, the water inlet screens on the washer are not plugged and the water supply supply hoses are open. I also checked to make sure the controls were not locked. The controls (water temperature, wash cycle type and finished alarm selections, etc are working, but when I press and hold the start button, the door does not lock and the water solenoid does not open. The door latch appears to be unbroken.
  • rkerns1288 Dec 23, 2008
    I push power button setting comes on I push start and nothing happens
  • jakeskiis Jan 30, 2009
    I have the same problem. Everything seems ok it just won't start.
    i was told by my applance service to try unplugging the washer for thirty minuites to see if the computer will reset.
    I'm waiting to try that now.
    I read in the trouble shooting manual, located inside the washer behind the lower front panel, that you need to replace the CCU board if this happens.
    Before I do this can anyone help with this?
    Thanks
  • fingerlake Mar 17, 2009
    Power is on, water is on, water screen input are clear. Press control on, Press Start nothing happens.
    Does anyone have a solution to this problem?
I am having the same problem. It just started yesterday. I loaded the laundry, shut the door, filled the dispensers, hit the Control On button and then held the Start button as normal. Nothing happened. The machine is getting power, water supply is on and no debris was clogging the inlet. The Start button simply does not engage the machine.
Posted on Aug 11, 2008
  • 139 Answers
If dorr does not lock then the fault is door interlock
Posted on Dec 16, 2007
3 Suggested Answers
SOURCE: ghw9100lw1
Try holding the End of Cycle Signal button for about 3 seconds and see what happens. Mine started working again.
Ok Yankee
Posted on Nov 17, 2007
  • 17 Answers
SOURCE: washer model GHW9100LW1 will nopt fill or start
Could be one or more of the following items not working properly or bad:
- Flowmeter.
- Water inlet valve
- Water pressure switch. (last thing to replace)
Make sure to unplug power cord before you replace the part and also make to clean drain tube and filter every year.
Posted on Aug 11, 2010
GHW9100LW1 F-11 code right afer it starts
Hi
Thanks for using FixYa. F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). To start with check the wire harness connections between CCU and MCU, and then check the motor. If both of them appear to be working fine then it seems that the MCU of your washer has gone bad as the control unit seems to be working fine. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Need to replace my barrens in my washer tub. ghw9100lw1
You better looking for a new washer. The cost for bearing about over 400 dollars.
New washer about $750.00 model 9550W at Sears or Sears outlet.
Good luck
Jun 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer model GHW9100LW1 will nopt fill or start
- Flowmeter.
- Water inlet valve
Apr 07, 2009 | Whirlpool GHW9100L Front Load Washer
Control lock light on
Hold the noise control button in for 4-10 seconds.
Jul 21, 2008 | Whirlpool GHW9100L Front Load Washer
Washer wont start
see this link to test it for issue
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Jan 13, 2008 | Whirlpool GHW9100L Front Load Washer
Ghw9100lw1
Ok Yankee
Nov 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
330 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
