Question about Refrigerators
Frigidaire FRS26F5A fridge at 50 degrees
This refrigerator has uneven ice formation on the top portion of the condenser coil only. Have checked door seals, cleaned compressor coils, and triggered manual defrost mode. After clearing the frost from the coils, ice is forming again on the back wall of the freezer at the top of the coil within a few hours. My guess is that this uneven cooling is the result of low freon. Any other suggestions? Unit is about 6 years old.
  • 909 Answers
You will have a blockage in the ferfigeration system. Its not a big deal, a technician needs to regas the fridge. Make sure he installs a new drier before he pumps gas into the fridge. (When the drier is contaminated, it restricts gas flow). This is what you have with your fridge..
Posted on Sep 25, 2009
Frost build up
Hi
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt. Determine the temperature setting. The refrigerator should be set to temperatures ranging from 34 degrees to 40 degrees, while the freezer should be below 30 degrees. Adjust the temperature setting which will naturally improve the ice buildup that's been caused by the wrong temperature setting.
Move the refrigerator away from the wall. Oftentimes, this simple action is all that is needed because the unit is not getting enough air circulation behind it. Also, some refrigerators have vents underneath the unit, which are easily clogged with debris. Clean these vents and coils.
Remove food and shelving from the refrigerator and freezer portions of the fridge. If ice build up is happening in the freezer, the drain in the freezer may be clogged. With the unit off, remove coverings to expose drain and pour hot water down the drain hole until it comes out into the drain drip pan under the fridge.
Check the condenser coils. The evaporator coils could be causing the problem of ice build up. If this is the case, professional repair is likely needed to replace the motor, thermostat or other problems within the fridge.
Check this link for a detailed idea:-
http://www.appliance-repair-it.com/refrigerator-not-cooling.html
Please get back to us if you have further query or else please accept the solution.
Sep 07, 2011 | Refrigerators
Fridge side working but only cooling to 50 degrees
My 14 years old GE profile refrigerator keep cooling above 50 degrees and not going down to below 40 degrees. I did clean condenser coil and fans are running fine. I adjusted temperature control to maximum cold .Do you think it my be short of refrigerant?
Jun 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Side by side unit. no temperature control in freezer or fridge temperature of fridge is 60 degrees F on top. Freezer temp is 45 degrees. Bottom part of fridge is 28 degrees F.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 13, 2011 | Frigidaire PLHS267ZA Side by Side...
The refridgerator temp wont go down past 51 degrees F
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 09, 2010 | Frigidaire FRS26H5AS Side by Side...
Top Freezer won't freeze--blows 50 Degrees constantly!!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check the fans especially the condenser fan. the noise you hear is probably the klixon cycling because the compressor is hot. You can put a fan blowing on the condenser coil and see if this helps.
Good Luck,
Gilsh
Nov 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
My freezer seems to be working but my frig is is not getting below 50 degrees???
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 28, 2009 | Refrigerators
Freezer is frosted in back Refrigerator is warm
The problem is the defrost system located behind the freezer back panel.
The defrost system (AKA evap. system) is composed by an heating coil, a fan , and a defrost thermostat, and its function is avoiding ice formation on coil.
When defrost system is defective the fridge wont cool down properly
In your fridge , either evaporator fan, thermostat or heating element is faulty, and the ice on coils is preventing the appliance from cooling down properly.
Mar 29, 2009 | Hotpoint HSS25GFP Side by Side...
Water drips from evaporator fan channel Frigidaire FRT17G4B
It sounds as if this is a top mounted refrigerator. (freezer on top) If this is the case, check to see if you need to defrost the drain. You could also have a problem with the door seals. Remember the air coming out of the vent is freezer temp minus a few degrees. It could be that the moisture is condensing in that area.
Feb 01, 2009 | Frigidaire FRT17G4B Top Freezer...
Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Nov 20, 2008 | Kenmore 64802 Top Freezer Refrigerator
Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Dec 09, 2007 | Frigidaire Refrigerators
Refrigerators Logo
280 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
