Question about Powerline Electronics - Others
I need to clarification about Transducer ES
I need to clarification about Transducer ES 2000-9725 , Ipn 2000A, Np / Ns : 1/50000 , Rs 25 ohm, ABB frequently failure.
We have two Master drive 900 kw panel ,and The drive was commissioned on 2004
Oder No : 6SE7041-3HK85-0AA0
Type : D660-690-G890-930/1285CREF
Ser No: Q 6581945320037
660V-690V
INPUT 1119A
OUT PUT 1285ADC
One is used for roller press moving roller. Other one is used fixed roller.
Please find the year, which the drive was commissioned and the replacement
dates of the CT's. all cts are fail in fixed Roller
* 2007 /12/23 , Fault massage came as F011 - over current ,F029 and changed Transducer ES 2000 ABB ( W ph ) in fixed roller.
* 2008/03/09 , again Fault massage came as F011, - over current ,F029 and changed twoTransducer ES 2000 ABB ( W ph ) and ( V ) in fixed roller.
* 2008/09/14 , again Fault massage came as F011 - over current , and changed Transducer ES 2000 ABB ( V ph ) in fixed roller.
* 2009/ 07/15 , again Fault massage came as F011 - over current , and changed Transducer ES 2000 ABB ( U ph ) in fixed roller.
And also we have attached the drive parameter data
VSD Drive Data: order No : 6SE 7041-3HK85-OAAO, Type:D660-690G890-930/1285CREF, Se No:Q6S81945320037
Environment temperature :- 32C at motor Area ,
Environment temperature :- 24C at VSD room
Environment temperature :- 30C at CT Area
Length of motor cable :- 100m
Data with number and type of motor
Type : - IPQ4 454 4AM00-Z, Se No: So1146696020001/2004 IM B3, SIEMENS
950kW , 1493, delta 690V, 920A,
Total inverter parameter fixed roller: -
Inverter:- Fixed roller side
Converter parameter:- Fixed roller side
Total inverter parameter moving roller: -
Inverter : - Moving roller side
Converter parameter moving roller :-
We have fail CT's for further investigations
NOTE : Due to 5th failure effect of cement production.
Can you pl acknowledge me
Looking forward to hear from you soon,
Thanks
Pathiraja
  • 3 Answers
SOURCE: Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Posted on Aug 08, 2008
  • 400 Answers
SOURCE: i want to put room temp on 30c but the default 24c
If you want the room at thirty C, it would appear you want the aircon to heat. To do this it would need to be a heatpump model which is capable of heating. If this is true, then it is a matter of changing the mode setting from cooling (default 24) to heating which would default at 30. Hope this helps. Look for a button with three or four icons, one should resemble an ice crystal (cooling) another should look like a radiating sun.
Posted on Jun 10, 2009
  • 7 Answers
SOURCE: I am using a Model SJ00-110HE 11Kw variable speed
Please go to the Hitachi site and download the user manual..it will explain in detail how to increase the speed
Posted on Nov 27, 2009
kinkate18138
  • 117 Answers
SOURCE: hey my laptop, on start
The error indicates that the Hard Drive in the computer has crashed and will require a replacement.
I made a quick search and found the part # of the HDD that was shipped with your model. It is
A1065524A. I would suggest that you replace the HDD with one with the same specification that was came with the computer.
You may either purchase it from Sony parts center or third party vendors.
Thanks!
Posted on Dec 13, 2010
SOURCE: Had the original inverter 2005
Hi well I am sorry to tell you but it seems like a section of the Inverter has failed, hopefully just in the drive/power circuitry to the remote panel, or indeed the remote panel itself? Also it just maybe possible that it is the "Cable" itself is faulty?, perhaps first simply try a replacement cable, if at all possible? The "Drive" is usually? a plug in board, this maybe able to be obtained and replaced, if indeed it proves to be faulty? But in all honesty I do NOT advise DIY, however it is entirely up to you, if you can obtain the service manual and have the tools and skills then all power to you, pun intended.
Otherwise, you will have to have the unit repaired by a professional. Although I would wonder if it isn't covered by a warranty of some sorts?
These inverters are quite good models, and the electronics are pretty good, this is why i suspect the interconnection cable, but unfortunately it maybe the electronics, there simply is no way to tell without actually testing the unit.
Perhaps the best course of action would be to get it looked at by a professional, and only first ask for a :"Quote" as to what's wrong and prospective costings and go from there.
Posted on Aug 14, 2011
Odometer speedometer display not working
Hi Dennis,I am not sure if your vehicle has a cable driven speedometer or it is electronic.I would first inspect the driven gear/transducer at the transmission. Sometimes acid from battery leakage can corrode terminals at the transducer.
Nov 05, 2013 | Mitsubishi Cars & Trucks
Please let me now the dealer name in bangalore, india.
Contact for DIN rail products in India: Name Anand Kulkarni Phone +911334235451 Details ABB Limited
Integrated Industrial Estate SIDCUL
249403 Haridwar
Uttarakhand
Dec 22, 2010 | ABB F362-25/0,03 Two Pole Circuit Breaker
I have a 3 year old insignia 8" portable dvd player, NS-8PDVDA. I have not used it in 2 years and never charged the battery. It is dead. Is there anything I can do? Do I need to replace the battery? If so,...
http://www.amazon.com/NS-7DPDVD-PD040922-PD101351-JE-A15-09V0A1-JEA1509V0A1/dp/B001R28LJ2
Link for AC Adapter.
http://rover.ebay.com/rover/1/711-67261-24966-0/2?ipn=psmain&icep_vectorid=263602&kwid=1&mtid=691&crlp=1_263602&icep_item_id=260544576977&itemid=260544576977
Link for Car Adapter
http://bestbuy.partsearch.com/Model/Best+Buy+Company+Incorporated/Insignia/NS8PDVD.aspx
Link for batteries.
You can do further searches and maybe get yourself some better prices. Good Luck!
Mar 21, 2010 | Insignia NS-8PDVD
Tengo un control universal NOBELSOUND NS-V3 y necesito un codigo
hola buenas noches tengo un problema y es que tengo un control universal nobelsoun ns-v3 pero no he podido encontrar el codigo de mi tv el cual es un panasonic y el modelo es CT-Z2151V ESPERO QUE ME PUEDAN AYUDAR GRACIAS
Mar 01, 2010 | Directed 434MHZ Remote Control
Tv made a pop noise and then sound was gone. It has done this a few times already
You have an overheated capacitor that is failing. You will need an oscilloscope or ohmmeter to find the faulty capacitor. Most are in teh 25-30 ohm range. and around 5 volts. A service manual would be helpful.
Dec 22, 2009 | Insignia NS-LCD19 19 in. LCD TV
PURCHAING BATTERY
go to radio shack. they have most all batteries. good luck.
Jan 24, 2009 | ABB Ssac Abb Rs2b13 Time Delay Cycle Timer...
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
REMOTE CONTROL NOBELSOUND NS-V3 CODES AND MANUAL
tengo un tv lg con un control universal nobelsound necesito saber cual es la clave
Aug 09, 2008 | Directed 434MHZ Remote Control
Installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Apr 26, 2008 | Lowrance LMS-332C GPS Receiver
Diesel audio NS-600
it can be done providing it isn't driven too hard.
May 19, 2007 | Diesel Audio NS-600 Car Audio Amplifier
Electronics - Others Logo
79 people viewed this question
Top Powerline Electronics - Others Experts
Are you a Powerline Electronics - Other Expert? Answer questions, earn points and help others
