Question about Dynex Wireless Optical Mouse
My wireless dynex mouse freezes up and I leave it idle for about 4 hours and I have to continuously replug the plug back into my PC, what is the reason for this? My batteries are new, only a couple weeks old. I need a solution.
  • 903 Answers
Do you have another mouse driver installed as well as the Dynex driver? There could be a compatibility issue. Go into the Add/Remove Programs applet in the Control Panel and see if there is another mouse driver installed -- maybe a generic Microsoft or HP mouse driver. Uninstalling this driver may fix the issue.
You can also check the Device Manager to see if there are any resource compatibility issues (which there shouldn't be). You may have a problem with the USB port it's plugged into -- try the mouse's receiver in a different port.
Did any of these solutions work? If not, we'll try something else.
Posted on Nov 18, 2010
My mouse pointer freezes up every day
Background running programs must be the reason for that you must use some start up manager or background application manager to avoid such type of problems, The one well known and reliable program is Reginout to manage everything on your PC.
Jan 08, 2014 | Dynex Wireless Optical Mouse
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
I disconnected my printer from the computer and now my dynex mouse refuses to move. I have tried the touch pad on/off ...nothing. The lite blinks on the reciever but the mouse lite is dark. Yes, I have...
hi there!
since you only disconnected the printer from the pc, it shouldnt have any effect on the other things connected to the pc. try to powercycle pc, turn off, shutdown, unplug power cord from wall outlet, leave it like that for 2mins. plug it back in, turn on. check mouse light and keyboard lights (caps lock, num lock lights) if none of these responds, check the drivers (device manager) if they have bangs (!), if yes, reinstall their drivers. =)
Apr 06, 2011 | Dynex Wireless Keyboard/Optical Mouse...
My Gigaware ubs mouse keeps looking up, how do I stop this?
You should try replacing the batteries in the unit, if it still freezes after that, try unplugging and replugging the wireless receiver. If it still freezes, try it on a separate PC. If it freezes still yet on a different computer, then you know the mouse has a hardware problem and should be replaced. If it doesn't freeze on the other PC then you will need to reinstall the software for the mouse on your main computer.
Sep 09, 2010 | Ultra Max Gigaware Wireless Laser Mouse
It uses up two AAA batteries in less than four hours of use!!
Hello Pabobr, hi, I wish this may help, I want to ask you a question, during that 4 hour use, does your mouse operate normally?
If yes, then thats a design problem, If no, you need to try other battery makes, and see if the changing battery names with solve your problem, if by any chance the problem still persist, try you mouse on another PC, see if the problem is your PC or not, if still you cannot break the 4 hour use, its already a design flow of that wireless mouse, call your dealer if what you have experience is the true just for confirmation. Try also other brands, you choose, still continue to use that mouse, and waste money on batteries or try other makes. Or go back to the traditional wire mouse.
Mar 10, 2010 | GE Wireless Optical Mouse
Mouse is not responding to any button push
Is it USB wired? If so, unplug an replug.
Wireless? is it charged, have you changed the batteries?, Have you installed the windows driver that came with the mouse beffore pluging the mouse?
Aug 02, 2009 | Dynex DX-WOM100 Mouse
Dynex wireless mouse DX-PWLMSE won't work
The mouse should be Plug and Play. Did you install the drivers before plugging the mouse's receiver in? The PC has to have the drivers first in order to take advantage of the Plug and Play capability. If you plugged the mouse's receiver in before installing the drivers, unplug the mouse receiver, uninstall the driver, reboot your PC, reinstall the driver, then plug the receiver in and you should be fine.
Otherwise, press the Connect button on the receiver first, and then the Connect button on the mouse, and that should establish the connection. You don't need to disable your touch pad in order to use the mouse.
Jan 22, 2009 | Dynex Wireless Keyboard/Optical Mouse...
Wireless dYNEX Mouse Model #DX-PWLMSE
I bought mine today, the same model and it doesnt work on my computer. I wonder what is wrong?
Mar 19, 2008 | Dynex Wireless Keyboard/Optical Mouse...
My mouse freezes up
have you tried new batteries?
Sep 15, 2007 | Dell U0636 Mouse
Dynex Wireless Optical Mouse Logo
218 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
