Question about AT&T 1738 Digital Answering System with Time/Day Stamp Answering Machine
Toll Saver doesn't work
When I set the ring to toll saver the answering machine doesn't work. Instead of hearing my message, it plays the prerecorded message and then does not record the callers message. Help?
  • 3 Answers
SOURCE: Answering machine atarts working after 2 rings only
Press the 'Change' button
Press the 'Setup' button until you hear the voice say "Number of rings"
Then use the "Skip" and "Repeat" buttons to change the number.
Press the "Change" button to finish.
Posted on Dec 31, 2007
SOURCE: Audio Feedthrough
how do you delete message that the machine is full
Posted on Jan 06, 2008
SOURCE: change # of ringer on an AT&T 1717 digital answering machine
I am also trying to change the number of rings before the answering machines toll saver activates.
Posted on Aug 24, 2008
how do i change number of rings before the answering machines toll saver activates.
Posted on Nov 05, 2008
SOURCE: I can hear messages being left but they won't play back
I had the same problem.
For some silly reason, there is an option of not leaving messages. You will see "AO" in the upper right-hand corner of the phone. This is for Announce Only.
To take it off:
Press/hold SET UP
Listen until you hear "Selected Announcement is A."
Press skip/repeat to save
(The other option is going to be the Announce Only which you don't want, so you can play around with the setting to make sure it's the right one.)
Call yourself to be sure you did it right.
You should now have numbers in the upper right-hand corner instead of AO.
Posted on Apr 24, 2009
How do I increase the rings before message answers?
Setting the Number of Rings (Excerpt from the Uniden Dect 1580 Phone manual
The ring time setting allows you to set the number of rings the caller hears before your answering system plays the outgoing message. You can set the ring time to answer after two, four, or six rings. If you enable the Toll Saver (TS) setting, the answering system picks up after two rings if you have new messages, and after four rings if there are
none. This way, if you make a long distance call to check your messages, you can hang up after the third ring to avoid long distance billing charges.
  1. Press Menu/Select.
  2. Select the Ans. Setup menu, and then the Ring Time submenu.
  3. Move the cursor to select a ring time (Toll Saver, 2 Times, 4 Times, or 6 Times).
  4. Press Menu/Select. You will hear a confirmation tone.
thanks
Jul 01, 2010 | GE 28112EE2 Cordless Phone
Would like to increase number of rings before answering machine comes on.
Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
How do you set the number of rings?
Ring Select and Toll Saver
Use Ring Select to choose how many times
the line will ring before the system
answers a call. Set for 2, 4 or Toll Saver.
When you set the system for Toll Saver, it
answers after four rings when you have no
new messages, and after two rings when
you have new messages.
1 Press and hold S for about two
seconds. The system announces the
current ring selection.
2 Press and release or
until the system announces your ring
selection.
3 Press and release P to exit
— OR —
Press and release S to change the
Remote Access Code (follow Steps 2–5
under “Remote Access Code”).
Here is the manual:
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
Nov 22, 2009 | AT&T 1717 Digital Answering Machine
Toll saver
Toll Saver is a feature that changes when the phone answers if you have voice mail messages. If you have no messages, the phone answers after the 4th ring. If you have messages it answers after the 2nd.
If you call in and you hear a 3rd ring, hang up.
Carl
Oct 01, 2009 | Panasonic KX-TG5632 Phone
Toll saver does not work. Ring count set to 4 rings
"2 rings" or "4 rings" (the default) are not "toll saver". You need to set the ring count to “toll saver”.
On the handset
1) Press Menu
2) Scroll down to Answering Device then press menu
3) Scroll down to Settings press menu
4) Scroll down to Ring Count press menu
5) Scroll up to “toll saver” and then press menu
Feb 05, 2009 | Panasonic (KX-TG1032S) Phone
How to set number of rings
1. Press and hold "set up" for about two
2 Press and release "ANNC/SKIP" or "MEMO/REPEAT"
selection.
3 Press and release "Play/Stop" to exit
Jan 21, 2009 | AT&T 1717 Digital Answering Machine
How do I activate Toll Saver on my EXA18580 series phone?
Toll Saver is the most confusing option with little or no information about it anywhere.
It overrerides the number of rings settings so that the answering voice mail cuts in after 4 rings or 3 if there are new messages. If you want to set rings to 6 or 7 or more, or have a consistent number of rings before voice mail cuts in, you have to turn off "Toll Saver".
From Telus:
Turn on "Toll Saver": *97 and hang up.
Turn off "Toll Saver": *96 and hang up.
Oct 27, 2008 | Uniden XCA 550 Corded Phone
Can not set no of rings on old sprint answer machine SP818 please help
Use Ring Select to choose how many times the line will ring before the
system answers a call. Set for 2, 4 or Toll Saver. When you set the
system for Toll Saver, it answers after four rings when you have no new
messages, and after two rings when you have new messages.
1. Press and hold [SET UP] for about two seconds. The system announces
the current ring selection.
2. Press and release [ANN/SKIP] or [MEMO/REPEAT] until the system
announces your ring selection.
3. Press and release [PLAY/STOP] to exit
-OR-
Press and release [SET UP] to change the Remote Access Code (follow
Steps 2-5 under "Remote Access Code").
Oct 01, 2008 | Lands Phones
Number of rings before recording answers
Choose how many times the line will
RINGS IS...” ring before the system answers a call.
• Set for 2 to 7 rings, or choose
Toll Saver 2/4 or Toll Saver 4/6.
• When set to Toll Saver 2/4, the system
no new messages and after two rings
when you do. Toll Saver 4/6 causes the
system to answer after six rings when
you have no new messages and after
four rings when you do.
• During setup, the Message Window will
display the number of rings (8 for Toll
Saver 2/4, or 9 for Toll Saver 4/6).
Sep 05, 2008 | AT&T 1738 Digital Answering Machine
Number of rings
Looks like 6 is the Max, according to the Manual.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu Option" on
page 16).
2) Press volume up/down to select a Ring Time (Toll
3) Press the OK soft key. You will hear a confirmation tone.
Toll saver is a feature where you can call the phone yourself, if there are messages it wil answer in 2 rings, if not it'll answer in 4 rings. The idea is to hang up on the 3rd ring and save the LD changes.
Hope that fixed Ya...
Geno
Mar 27, 2008 | Uniden TRU8885 Digital Answering Machine
AT&T 1738 Digital Answering System with Time/Day Stamp Answering Machine Logo
23 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
