Question about Digital Audio 2000 WATTS SINGLE CHANNEL HIGH CURRENT AMPLIFIER DHC1204 Car Audio Amplifier
I need to clarification about Transducer ES
I need to clarification about Transducer ES 2000-9725 , Ipn 2000A, Np / Ns : 1/50000 , Rs 25 ohm, ABB frequently failure.
We have two Master drive 900 kw panel ,and The drive was commissioned on 2004
Oder No : 6SE7041-3HK85-0AA0
Type : D660-690-G890-930/1285CREF
Ser No: Q 6581945320037
660V-690V
INPUT 1119A
OUT PUT 1285ADC
One is used for roller press moving roller. Other one is used fixed roller.
Please find the year, which the drive was commissioned and the replacement
dates of the CT's. all cts are fail in fixed Roller
* 2007 /12/23 , Fault massage came as F011 - over current ,F029 and changed Transducer ES 2000 ABB ( W ph ) in fixed roller.
* 2008/03/09 , again Fault massage came as F011, - over current ,F029 and changed twoTransducer ES 2000 ABB ( W ph ) and ( V ) in fixed roller.
* 2008/09/14 , again Fault massage came as F011 - over current , and changed Transducer ES 2000 ABB ( V ph ) in fixed roller.
* 2009/ 07/15 , again Fault massage came as F011 - over current , and changed Transducer ES 2000 ABB ( U ph ) in fixed roller.
And also we have attached the drive parameter data
VSD Drive Data: order No : 6SE 7041-3HK85-OAAO, Type:D660-690G890-930/1285CREF, Se No:Q6S81945320037
Environment temperature :- 32C at motor Area ,
Environment temperature :- 24C at VSD room
Environment temperature :- 30C at CT Area
Length of motor cable :- 100m
Data with number and type of motor
Type : - IPQ4 454 4AM00-Z, Se No: So1146696020001/2004 IM B3, SIEMENS
950kW , 1493, delta 690V, 920A,
Total inverter parameter fixed roller: -
Inverter:- Fixed roller side
Converter parameter:- Fixed roller side
Total inverter parameter moving roller: -
Inverter : - Moving roller side
Converter parameter moving roller :-
We have fail CT's for further investigations
NOTE : Due to 5th failure effect of cement production.
Can you pl acknowledge me
Looking forward to hear from you soon,
Thanks
Pathiraja
2 Suggested Answers
  • 78 Answers
SOURCE: Current Firmware version says 000.000.000: Upgrade
First of all connect it to ur pc and then format it and then try it i am sure it will work
Posted on Nov 01, 2009
Odometer speedometer display not working
Hi Dennis,I am not sure if your vehicle has a cable driven speedometer or it is electronic.I would first inspect the driven gear/transducer at the transmission. Sometimes acid from battery leakage can corrode terminals at the transducer.
Nov 05, 2013 | Mitsubishi Cars & Trucks
Please let me now the dealer name in bangalore, india.
Contact for DIN rail products in India: Name Anand Kulkarni Phone +911334235451 Details ABB Limited
Integrated Industrial Estate SIDCUL
249403 Haridwar
Uttarakhand
Dec 22, 2010 | ABB F362-25/0,03 Two Pole Circuit Breaker
I have a 3 year old insignia 8" portable dvd player, NS-8PDVDA. I have not used it in 2 years and never charged the battery. It is dead. Is there anything I can do? Do I need to replace the battery? If so,...
http://www.amazon.com/NS-7DPDVD-PD040922-PD101351-JE-A15-09V0A1-JEA1509V0A1/dp/B001R28LJ2
Link for AC Adapter.
http://rover.ebay.com/rover/1/711-67261-24966-0/2?ipn=psmain&icep_vectorid=263602&kwid=1&mtid=691&crlp=1_263602&icep_item_id=260544576977&itemid=260544576977
Link for Car Adapter
http://bestbuy.partsearch.com/Model/Best+Buy+Company+Incorporated/Insignia/NS8PDVD.aspx
Link for batteries.
You can do further searches and maybe get yourself some better prices. Good Luck!
Mar 21, 2010 | Insignia NS-8PDVD
Tengo un control universal NOBELSOUND NS-V3 y necesito un codigo
hola buenas noches tengo un problema y es que tengo un control universal nobelsoun ns-v3 pero no he podido encontrar el codigo de mi tv el cual es un panasonic y el modelo es CT-Z2151V ESPERO QUE ME PUEDAN AYUDAR GRACIAS
Mar 01, 2010 | Directed 434MHZ Remote Control
Tv made a pop noise and then sound was gone. It has done this a few times already
You have an overheated capacitor that is failing. You will need an oscilloscope or ohmmeter to find the faulty capacitor. Most are in teh 25-30 ohm range. and around 5 volts. A service manual would be helpful.
Dec 22, 2009 | Insignia NS-LCD19 19 in. LCD TV
PURCHAING BATTERY
go to radio shack. they have most all batteries. good luck.
Jan 24, 2009 | ABB Ssac Abb Rs2b13 Time Delay Cycle Timer...
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
REMOTE CONTROL NOBELSOUND NS-V3 CODES AND MANUAL
tengo un tv lg con un control universal nobelsound necesito saber cual es la clave
Aug 09, 2008 | Directed 434MHZ Remote Control
Installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Apr 26, 2008 | Lowrance LMS-332C GPS Receiver
Diesel audio NS-600
it can be done providing it isn't driven too hard.
May 19, 2007 | Diesel Audio NS-600 Car Audio Amplifier
Digital Audio 2000 WATTS SINGLE CHANNEL HIGH CURRENT AMPLIFIER DHC1204 Car Audio Amplifier Logo
175 people viewed this question
Top Digital Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Digital Audio Car Audio and Video Expert? Answer questions, earn points and help others
