Question about Kenmore Elite 45986 Front Load Washer
My kenmore elite door will not unlock - Kenmore Elite 45986 Front Load Washer
  • 15,935 Answers
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
3 Suggested Answers
  • 91 Answers
SOURCE: Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Posted on Jan 02, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore elite front loader washer:door locked after repair
If you have cleaned the drain pump and checked ALL the drain lines (this includes the drain line that runs from the bottom of the wash tub to the inlet side of the drain pump), then you may have to replace the pump.
Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and cannot pump at the correct volume to complete the drain cycle, the error code will continue to appear until the pump is replaced.
The following link explains how to replace the drain pump (if required):
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I hjave listed also have helpful exploded view parts illustrations to assist you in locating and properly identifying the parts you need.
If you are having problems with unlocking the washer, there is a manual release you can use to get the door open: http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_ The problem may just be a momentary glitch in programming related to the "F02" error code you are receiving. If there are any error codes present, the washer will not complete a cycle and will shut down. I would recommend double checking the drainage system one more time to ensure there's nothing caught in the pump impeller or any of the drain lines (you may have overlooked something), followed by replacement of the pump if the problem continues. This will hopefully cure any others issues you may be experiencing with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Posted on Feb 18, 2010
Kenmore elite washer he4 door striking mechanism
if the machine has stoped and unlocked you should be able to pull straight out
May 03, 2014 | Kenmore Elite HE4 Electric Dryer
I notice F22 error message on washer. Door seems to be jammed and will not unlock
This is a door lock failure code and it means the door lock is broken or just failed to unlock. Click on the links below for the detailed instructions for manually unlocking the door and replacing the door lock and switch assembly if it has indeed failed.
Manual Door Unlocking of Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Replacing the Door Lock and Switch Assembly on Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Mar 12, 2011 | Kenmore HE2 Plus Front Load Washer
Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite he washer lock light. cannot open
You can manually Unlock the door Lock System
1. Unplug washer or disconnect power.
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is heard.
6. The door may be opened.
Thank you !!
May 31, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite he4 washer machine
to get the door open unplug from power asnd leave for a few hours the door can then be opened The controller board needs replacing
Aug 28, 2009 | Kenmore Elite HE4 Electric Dryer
WHAT IS DU?
DU is door unlock error - A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
Solutions -
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
  • May 19, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore front load He3 washer: door wont unlock
    happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
    Feb 27, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore elite HE 3t - error code F dU and door is locked
    Just in case there is a pull string with a loop, all plastic under the latch, need to pull the toe panel off and reach up inside the right, unplugged of course until you feel the switch. a pull latch is below the switch incase this happens and hats off to all star/ a serial error or a faulty switch is most of what causes this to start.
    Jul 29, 2008 | Kenmore Elite 45986 Front Load Washer
    HE5t Kenmore Elite
    non existent code. if under warranty call tech support. probably control board. can manually override door lock. by removing lower panel and pulling tab at bottom of lock mech.
    May 30, 2008 | Kenmore Elite 45986 Front Load Washer
    Unlock the control panel to a kenmore elite front loader
    to unlock the controls
    select and hold drain/spin for 3 seconds until the control locked status lights turn off.
    Nov 22, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    230 people viewed this question
    Sal DeAngelo
    fordexpert
    Mike Carew
