Question about Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System
When I make call, the phone cut off before I
When I make a call the phone cut off before I finish my call. Need help on this matter.
Some 816 phones won't ring on incoming calls
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
enter in #62 the screen should say day ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
press # when finished.
Jun 05, 2010 | Samsung Prostar 816 Phone
Our samsung system only rings on one telephone- how do I get it to ring on all phones and lines
with the handset down enter #20 the screen should say MMC DISABLED
Mar 16, 2010 | Samsung 816 Keyset Display Telephone
THE PHONES DO NOT RING
with the handset2.gif down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming2.gif)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished.
Oct 01, 2009 | Samsung Prostar 816 Phone
Secondary phones will not ring
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring2.gif assn
press #when finished. hope that helps
Sep 22, 2009 | Samsung Prostar 816 Phone
Need a copy of page on setting up the Craftman miter saw model 113235120. There is one page in there with the set up to cut compound miters.
Make all cuts with molding flat on the table and bevel at 33.8 for ALL cuts ...to cut left inside corner, set miter at 31.6 degrees right. top of molding against the fence left side is finished piece... right inside corner set miter at 31.6 left with bottom of molding against the fence.left side is finished piece...left outside corner same setting, bottom of molding against fence right side is finished piece...right outside corner set miter at 31.6 right with top of molding against fence. right side is finished piece. hope this helps
Sep 01, 2009 | Craftsman Saws
How do I put second call on hold while finishing first conversat
FIRST U HAVE TO HOLD FIRST CALL. AND TAKE THE SECOND CALL.THEN HOLD SECOND CALL.FIRST CALL AUTOMATIC ACTIVATE.OK
IF HELPFUL THEN PLEASE RATE
Jul 10, 2009 | Uniden DXI8560-2 Twin - - Phone
Ringer
Jan 27, 2009 | Samsung Prostar 816 Phone
Phone dont ring
Sep 04, 2008 | Samsung Prostar 824 Keyset Telephone
Inserting staples
If the machine has an in-built finisher, the stapler is located in the rear of device. Pull the finisher release handle and pull the finisher towards you. Extract the staple cartridge by pulling up in the green tab at the rear right of the finisher. The staple cartridge can be opened by squeezing the sides together to allow the spring to act. (Sometimes it can be helped with a screwdriver popping the clear tabs located on the underside). Insert the replacement staple pack and pull the orange tab before closing the cartridge shut. Reinsert into the finisher and push down to locate it. Should work ok after all that.
Nov 26, 2007 | Canon imageRUNNER 3570 Copier
Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System Logo
19 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
