When i turn my television on its white with lines going through it and it only stays on for a few seconds. whats the problem
  • 269 Answers
Hi! the problem you have mentioned is retrace line, it is cause by a loose solder on the crt board, a leaky capacitor. because you have mentioned that it only stays on for a few seconds.
Posted on Sep 25, 2009
White lines that are constantly on will go away for a few seconds then pop back up.. Mitsubishi 73" model number WD-73640
You need to replace the 4719-001997 DLP Chip. this should solve the issue.
This chip can be expensive so look around before you purchase. This is a common problem with these TVs, both white lines and white dots. You can find out how to replace the chip by going to this website: http://www.fixyourdlp.com/2012/09/04/solve-the-mitsubishi-wd-73640-white-dot-problem-with-a-new-4719-001997-dlp-chip/.Hope this helps
Feb 27, 2013 | Televison & Video
How do I Fix LCD White Screen?
If you see "fractured lines" across the screen, it would appear that your LCD screen is broken. That's the only way these kinds of lines appear.
You need to replace the screen.
May 14, 2012 | Computers & Internet
T.v. turns on but won't stay on
You need to replace the power source part in your tv. This is what's causing the problem.
Jul 17, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
White Horizontal Lines @ the top of my 32" Sharp Black Box TV
This Problem is usually caused by Leaky Capacitors in Vertical deflection circuit.
If you are handy with electronics,
Get a can of FREEZE Aerosol.
Open the Back Cover.
Put a mirror in front of TV.
Locate the Vertical Circuit.
Turn the TV on.
Spray FREEZE on top of individual Capacitor to see if it corrects the problem.
If it does, Replace that Capacitor.
Feb 06, 2009 | Sharp 32C-240 32" TV
White horizontal lines in my 27 in Phillips Magnnavox tv
I have seen this on mine. Check the cable going into your TV and make sure it is good. The ground portion of the cable could not be making a good connection.
Jan 17, 2009 | Philips Magnavox 27MS343S 27" TV
Turn on and stay on
It seems that Your TV set may have a problem with its power supply circuit, the problem is intermitent bring it to the repair shop.
Nov 06, 2008 | Televison & Video
Tv screen is red with white vertical lines stays on for a few seconds then turns off
your red CRT is shorted, please respond to this same post with the model number of your set and I will assist you with your problem.
Sep 26, 2008 | Televison & Video
Sony KV-27TW75 Black and White Picture
this is usually due to bad ground check cable line comming into tv and
CHECK/RESOLDER CONNECTIONS IN TUNER WHERE CASING IS SOLDERED TO PCB NEAR 4TH FEED THRU BACK FROM ANTENNA INPUT
Feb 04, 2008 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
