Question about RCA RP1667 AM/FM Radio
How do you set up the preset stations on the rca
How do you set up the preset stations on the rp1667, I do not have the instructions
4 Suggested Answers
tech48
  • 624 Answers
SOURCE: Presets stopped working
I have repaired a few of these receivers in the past few years and have found several with microprocessor issues and some with a lot of heat stressed solder connections on the main amplifiers board around the voltage regulators.
The problem you are having is similar to problems the others I have repaired were having.
There is nothing you can, as an end user, do beyond a hard reset of the microprocessor by unplugging the unit from the wall and wait about an hour or 2 before you plug it back in.
By resetting the microprocessor you can at least see if the problem is a minor one or not. most likely it is an electronic problem that will take some good troubleshooting skills.
The bigger problem you face with this particular unit is that RCA no longer supplies parts for the audio equipment they sell.
Once the supply of what they have in stock is gone, thats it, no more parts at all for RCA audio. That supply has not been replenished in around a year.
All of the RCA audio equipment sold now is exchange only if it is under warranty.
I know this because I work at an authorized RCA repair center and I am the audio tech. I have not repaired an RCA audio unit under warranty in about a year because of that.
I have fixed 3 or 4 of the same unit you have, but not under warranty.
If you or somebody you know has very good soldering skills you can try reflowing the solder connections on the main board and even reflowing the microprocessor. It could solve your problem, but not advisable unless you are very good with a soldering iron and have done this sort of thing before.
I am sorry for this rather bad news, but it is true. I have been repairing audio equipment for over 17 years and am very familiar with RCA products.
If I can be of any further help please let me know.
Posted on Jun 22, 2008
SOURCE: setting station presets on Sangean ATS 505
A copy of the manual is at
http://download.qrz.ru/pub/hamradio/schemes/receivers/DX-398_Owners_manual.pdf
or you could enter dx 398 manual into google.
best regards apritt
Posted on Nov 30, 2008
SOURCE: I need an instruction manual for an RCA RP3750
I have the manual but I can seem to get it uploaded.
Posted on Jan 06, 2011
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
Setting presets
You may have to press the button and keep it depressed until,you hear the station you stored.
Feb 16, 2018 | RCA BRC10 Bathroom Clock Radio
How do I set the clock & preset the stations. I bought the radio 5/4 /11 & there was no brochures or warrantee in box.
Setting the Clock 1. Press and hold the CLOCK button until the hour begins to flash 2. Use the left arrow and right arrow buttons to change the hour. 3. Press the CLOCK button again. Use the left arrow and right arrow buttons to change the minutes. 4. Press the CLOCK button again to save.
PRESET Stations the PRESET stations: 1. Tune to desired station. 2. Press and hold the PRESET button until the PRE-SET indicator on the display begins to flash 3. Use the left arrow and right arrow buttons to select the PRESET location for the station. Ten locations (0-9) are available. 4. Press the PRESET button to save the location. To tune a PRESET station: Press and release the PRESET button to step through the PRESET stations.
http://www.northerntool.com/downloads/manuals/142796.pdf
May 06, 2011 | Milwaukee Tool 49-24-0200 AM/FM Radio
I can't figure out how to set the radio station pre sets
hi,
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
unit.
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
ok
Dec 24, 2010 | Teac CD-X9 Shelf System
LG LX-M240 operating instructions: I cannot set the presets
Owner's Manual is PN 3834RH0020U
On pg13
1. Press TUNER/BAND to select AM or FM
(Leftmost rectangular button on left of volume knob)
2. Select station by using TUNING +/-
3. Press PROGRAM/MEMO on the remote
A preset number will appear.
4. Press PRESET +/- (or PRESET ^/v on remote) to
select the preset number you want.
5. Press PROGRAM/MEMO again. The statio is stored.
6. Repeat above for more stations.
Believe you can store up to 30 stations.
Stations on presets 1, 2 and 3 take longer to 'kick in' when listening to the radio
as they are the 'tens' prefix for the preset numbers. 4 - 9 'kick in' immediately.
Jul 01, 2009 | LG Audio Players & Recorders
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
May 04, 2009 | JVC FS-D88 Shelf System
Zenith Z212G radio, Need preset modification instructions
Zenith Z212G radio, preset modification instructions
  1. Display desired station
  2. Press Memo Set button to make "Memo" flash on display
  3. Select desired preset number
  4. Press Memo Set button to save
Apr 12, 2009 | Zenith Z115S Clock Radio
Instructions on programming Nakamichi SS5 radio presets
The solution is really very simple.
This unit is capable of a total of 30 presets.
10 AM presets in 2 groups (AM1 & AM2).
20 FM presets in 4 groups (FM1 - FM4).
Each of the individual groups can have a total of 5 presets.
In other words, there are 6 groups of 5 presets (AM1 AM2 FM1 FM2 FM3 FM4) for a total of 30 presets. Hope that makes sense.
You have preset buttons 1-3 on the top of the unit. Preset button #3 is the MEMORY or "set" button.
Try these steps and you should be up and running.
1. Choose which band you want to use. ie. AM1 AM2 FM1 FM2 FM3 FM4.
2. Tune in a station
3. Click the #1 preset button and watch the screen, let's say that you have tuned into the station FM 100.0, the station frequency is displayed along with the "group" you're in (ie. AM1...FM4) and you will also notice a number in between your "group" id and your station. This is the # you're going to set and the way to change this from 1-5 is simply by pressing the #1 preset button until the # comes up that you want to save it to.
4. Press #3 Preset button (labeled "MEMORY")
5. That's it, now do all the stations you want but be mindful that once you have programmed 5 presets to any given group, you have to move on to the next group until you've maxed out the total # of presets.
Hope this helps.
Jan 25, 2009 | Nakamichi SoundSpace 5 Shelf System
HOW DO I INPUT CODE 5423 INTO MY BLAUPUNKT PF3 CAR RADIO
After switching on the set will display 'COD' Pressing any station preset key will display '000'Enter the code via presets 1 - 4 (Pr1 displays 1 or 0 only) and press the station increment key. The set will now operate.
Or use instructions from this link (same).
Regards
Apr 02, 2008 | Car Audio & Video
Help with fm presets
I'm not sure on this particular model, but often if there are seperate buttons for the station presets you just tune to the required station and hold the preset button you want in until you hear a beep - then the station is memorized in that preset.
However in this case the preset up/down and enter/memory buttons are used - the manual is available here:
http://www.sherwoodusa.com/cc_manuals.html
and full instructions for setting presets both automatically and manually are on pages 35/36.
Mar 16, 2008 | Audio Players & Recorders
RCA RP1667 AM/FM Radio Logo
56 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
