Question about LG Televison & Video
Invalid format have PS3 hooked up through HDMI cable. can hear sound, but there is no picture. all tv says is "invalid format"
    Sniper:
  • 58 Answers
Use the power button on the front of the console, to put it in standby mode (red light on).
Then press and hold the power button until you hear two beeps.
This should fixya.... :)
please rate this answer!....
Posted on Sep 25, 2009
Testimonial: "thankyou, that actually worked, i did not know this could be fixed this way"
  • 3 more comments
  • Brandon Coats Nov 29, 2011
    I had the same problem and this solution works like a charm on the PS3! THANK YOU!
  • Mark Evans
    Mark Evans May 02, 2012
    I have to thank you my friend !! You let me to learn something very useful !!
  • Mark Evans
    I have to thank you my friend !!!! Not only you help me top fix that problem , you learn me something !!!! Big Up
  • baaman68
    baaman68 Nov 22, 2012
    Thank you it work for the SK-26H240S model westinghouse tv
  • Random Productions
    Random Productions Mar 25, 2016
    THANK YOU SO MUCH.!!!!!!!!!!!
Hooking up my ps3 using HDMI cord to my olevia 232-S13 and it says invalid format
Setting up your HDMI cable on your PS3 games console
1: Turn on your TV and set its input to HDMI.
2: Make sure your PS3 is connected via a HDMI cable.
3: Power on your PS3 and press and hold the power button for approx. 5 seconds, you will hear the PS3 start to beep, release the power button after the second beep.
4: Your PS3 should automatically configure itself for HDMI video and Audio output.
Jun 28, 2015 | Olevia Televison & Video
I own a Sony kdf-55e2000 , when I try to hook up a ps3 through the hdmi imputs i get a message reading "unsupported signal please check device output" i can here the sound but no picture.Is there any
try only having the hdmi cable hooked up to ps3 and tv, turn off ps3 and hold power button for 5 or 10 seconds and you should hear 3 beeps, this should reset the ps3 and detect the settings, if this doesnt work you mmay have to manually change audio and video settings in the ps3 settings menu to hdmi output and auto detect which settings work.
Jan 05, 2013 | Sony Grand WEGA KDF55E2000 55" Projection...
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
I have a ps3 and cant get a picture on my 42" LG
Ok, you need to do the following :
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, beep again 5 seconds. Release the power button when you hear this second beep.
The PS3 will start up and reset the display
Make sure you do this with the HDMI cable connected.
Hope this helps
Nov 07, 2010 | Sony Playstation 3 (PS3) Console
PS3 start-up. ''Invalid Format'' presented on screen. Can hear sound but no picture. TV is LG Plasma Model # 60PY3D
turn off the ps3. when you turn it back on by the console hold the button down until you hear a beep, keep holding it down until you hear a second beep, this will reset the format back to normal, if you have hdmi or anything else you can change it then from your video settings menu.
Jun 20, 2010 | Sony Playstation 3 (PS3) Console
I am having a problem with a new tv I cant get a picture using a HDMI cable my TV says invalid Format. what do I need to do?
The format of signal your pushing with you ps3 is to high adjust it down to stadard def and work you way back up most tv's are 720p and your ps3 will try 1080p as a defualt with your tv does not understand, also check the cable as well there are diffrent versions of hdmi such as 1.0,1.2. etc etc make sure you using a lowest bandwith cable that way there are no conflicts.
thanks I sure hope this was Very Helpful!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 13, 2009 | Sony Playstation 3 (PS3) Console
No video or sound
Well...I assume that you are using A/V at your house and HDMI at your friends house? The best way to fix it is to hold the power button down for 3-5 seconds and you will hear 1 beep then continue to hold until you hear 2 beeps. When you hear 2 beeps let off and this will take you to the restore menu and resets your video settings. The funny thing with a PS3 it will automatically pick up that you have an HDMI cable hooked up but not that you have an A/V cable. So when you hook up your AV cable it still boots in HDMI format and it has to be reset. Don't buy your cable yet it will do the same thing.
Thanks,
Ced
Aug 17, 2009 | Sony Playstation 3 (PS3) Console
Invalid format??
change the display settings to 1080i or 720p- his tv likely does not support 1080p.
Mar 30, 2009 | Sony Playstation 3 (PS3) Console
No video display,
UUUHH HHHH DUH!!ITS NOT MENT 4 PS2!!!
Jan 26, 2009 | Sony Playstation 3 (PS3) Console
Ps3 reset
turn the PS3 off. hold the power button for at least 5 seconds or until you hear another beep.
This should reset all your ps3's settings.  If you have an HDMI connection, wait for a couple of seconds so that the PS3 recognizes and negotiates the right video output for your TV.
Sep 07, 2008 | Sony Playstation 3 (PS3) Console
Open Questions:
Televison & Video Logo
1,906 people viewed this question
