Question about Zebra P110i Led Card Printer
Zebra p11oi will not print anymore
It stopped responding about a month ago. It does nothing until I turn it off then on again, then it will inialize shoot out a blank card and say ready on the LED display. I have completely uninstalled the program in my Contol Panel>Add Remove programs and reinstalled it using the disk that came with the printer I can even see the printer in my printer and faxes folder but it will not respond when i print.
  • 65 Answers
Make sure you have the ribbon set right in the driver. If the driver says ribbon X, and the printer is loaded with printer Y, it won't print. (Make sure any driver settings are done while logged in with Windows Admin rights - "regular" users don't have sufficient privileges to make driver settings changes).
Also, check the printer queue and device settings. Make sure there are no jobs stuck in the queue ("Cancel all documents"), and make sure the printer is NOT set to "Use Offline" or "Pause Printing".
Other than these items, it could just be that the printer has lived its life and ready to be put out to pasture. Feel free to contact us for other questions, or to consider replacement options.
Posted on Aug 02, 2017
5 Suggested Answers
SOURCE: Zebra 105 SE Printing Blank Labels
Seagull Scientific has drivers. Their Zebra driver is recommended by many.
That's the link for their printer drivers page. Go to the bottom and click on 'Download a printer driver'. Then scroll the list to find the one you need.
Posted on Jun 10, 2008
  • 19396 Answers
SOURCE: LCD display fault (blank) on Zebra card printer
lcd faulty?
Posted on Jul 10, 2008
  • 3 Answers
SOURCE: Zebra S4M prints one label then goes to flashing pause light.
most likely it is a printer driver issue. There's 2 drivers, one for 200dpi and one for 300dpi. Use the one for 200dpi. It could also be the label setting is incorrect. Try running a calibration.
Posted on Jan 27, 2009
SOURCE: I have Zebra P330i printer, have done the cleaning
Knowing that you were able to complete the proper cleaning procedure using the short and long cards, and the printer is on ready status, try to change the ribbon and test. Make sure the card is properly inserted with the magnetic stripe on the top facing down. Also make sure that the ribbon is properly loaded. There should be an instruction on the cover for its proper orientation.
If it still does not print, make sure your configuration on the printer is set to the proper type of cards HICO or LOCO and the ribbon type is properly set to YMCKO for color. Also, check if you have enabled mag stripe encoding or if you don't need to have it enabled. Enabling means that the printer will check for the mag stripe if its good or bad. If bad the printer will reject the card.
Do a self test print by following the below. 1. Set the printer's power switch (on the back of the printer) to the OFF ( O ) position. 2. While pressing the Printer's front panel button (next to the LCD display panel), switch the printer ON ( ' ). 3. Hold the panel button until the LCD display panel reads "SELF TEST". 4. Release the panel button, and the test card will print
If no prints, observed for any mechanical errors on the printer. Normally mechanical errors are detected by the printer with corresponding error message.
If none of the above works then you might have a print head problem. You may attempt to clean it by following below. Else if it does not help then have your print head replaced.
A cleaning using the Cleaning Cards usually suffices. However, a separate Print Head cleaning can remove more stubborn deposits when print anomalies persist. To avoid deposits, only use foam-tipped swabs. 1. Place the printer power switch in the OFF ( O ) position. 2. Open the Main Cover, release the Print Head Carriage, and remove the ribbon. Leave the Print Head Carriage in its raised position. (For details, see Chapter 2.) 3. Clean Print Head by moving an alcohol-moistened swab tip side-to-side across the Print Head elements. Only use moderate force. To re-order swabs, please refer to the Media List on the Windows Drivers and User Documentation CD supplied with this printer. 4. The swabs can also be used in a similar manner to clean the optional magnetic encoding head.
Posted on Jul 12, 2011
Hi, I have a Zebra 140xi2 printer. When I print, everything is shifted to the left. I checked the PRINT WIDTH (set at 127 4/8 MM), and the LEFT POSITION (set at 0000) in the printer configuration. Is there...
turn off printer and press "pause" button + "power on" at same time, keep pressing "pause" button for 5 secs. it will star printing a
'pouse test" ike a barrcode. After 3-4 labels, just paused the job otherwise it will never stop printing untill u swicth off again.
if printing halp printer, tried to reser printer to factory default and try again. if still printing half, the printhard its faulty.
Mar 17, 2014 | Zebra Office Equipment & Supplies
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
How to printer test page from the display panel zebra zm600
With most Zebra printers, a test page is printed by pressing and holding the PAUSE key while turning on the power. Keep pressing the PAUSE key until the printer completes the POST (power on self-test), then you can let go. A test pattern will begin printing. You can stop the pattern by pressing PAUSE. Turning the printer off & on again is the fastest way to end the test. This is a good page to print because it prints a large black box and it's easy to see if there are any printhead elements not functioning. It's best to use the largest, widest label you have for this test.
Hope that helps !
Aug 29, 2011 | Zebra ZM600 Printer
My Zebra s600 - the ink takeup reel is not working.. works a little when first powering on, but the ink roll then stops moving.. When I print a label, the label comes out, but the ink roll does not...
turn the printer off, press FEED, PAUSE and CANCEL at the same time, still pressing, turn the printer on, wait untill the ligths coming on, and then relese the bottuns, it gona print the sensor profile, then press the last button 4 times untill the 3 ligtns flases, it mins that the printer save the data, then turn off and on again.
Oct 13, 2010 | Zebra Stripe S600 Thermal Label Printer
My zebra only prints the left half? I have tried calibrating, it does nothing. Can you help me out? Thanks
One of two situations exists:
1. If the printing stops with clear stopping edge, then the PRINT WIDTH setting has been changed from the default full width setting of 104mm.
Best way to check this is to take your tallest and widest label and print out a configuration label. This is done by turning off the priner, pressing the CANCEL key and holding while turning on the printer. Release the button when the calibrate led turns off. A config label will print and you can check the setting for PRINT WIDTH.
2. If the printing stops by fading away to the right side, then that is caused by a pressure imbalance across the printhead. There is more pressure on the left side than the right side. There are two toggles the press down on the printhead and the pressure can be adjusted on each by turning the knob on top. Readjust the right side until printing returns across the label.
Hope that helps !
Apr 26, 2010 | Zebra Stripe S600 Thermal Label Printer
My printer locks up
go to your printer folder, right click on the z4000 printer, go to properties, tools, and actions. Then reset the printer to factory defaults. Do this right as it starts up. This might fix your problem.
Apr 02, 2009 | Zebra Z Series Z4000 Printer
Jan 21, 2009 | Zebra Z4M Printer
Attention light on hp 1115photosmart
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 01, 2009 | HP PSC 1410 All-In-One InkJet Printer
Label Printing stuck in queues
I think your problem comes from your spool server. Check if you can select not to reprint on errors. As far as the error issue is concerned, i need to konw the reason of the errors to help
Jul 21, 2008 | Zebra Z4M Printer
Zebra P110i Led Card Printer Logo
96 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
