Question about Canon PowerShot A95 Digital Camera
When I power up my A95 I get get a loud stacatto noise
When I power up my A95 I get get a loud stacatto clicking sound.
Then the camera shuts down.
Sometimes the camera works normally. Other times noise only for a few seconds, but I can take pix.
Captured images show primarily reddish images with countless horizontal line distortions. that in a way correspond to the stacatto noise.
Batteries appear to begood and clean.
Any ideas??
  • 797 Answers
Go to Canon.com and find the service department. Call the 800 #. They should fix your camera for free, and will pay shipping both ways for no cost to you. They will send the necessary information to you by email.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=221&modelid=8776
Posted on Sep 25, 2009
  • 24 Answers
Sounds like your Canon might be getting close to retirement age. The Powershot A-series is a workhorse, but sometime they just get stubborn.
The clicking sound could be something in the motor mechanism that is preventing the lens from properly extending. The red hue probably indicates a loose connection within the camera body.
My Canon Power Shot A95 clicks when turned on.....what do i do?
The lens is trying to extend you may need someone to repair it.
May 19, 2014 | Canon PowerShot A95 Digital Camera
I have dell 3300mp,when I turn the power on it makes a very loud noise. It does not make the sound in standby or cool down. It does work and display a signal okay, but it is very loud. Sound like a fan?,...
The main fan that cools the lamp is mostly high speed when the unit is running. when it shuts down it slows the fan down, until it stops in standby. So the noise is only really loud when it is showing a picture.
try setting the fan to eco mode (slower running) and see if the noise is acceptable. If it is still too loud then you will have to replace it. Have a look at the fan and see if any of the plastic blades are missing.
Mar 26, 2011 | Dell 3300MP Multimedia Projector
Camera shuts off even with new batteries
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jul 12, 2010 | Canon PowerShot A95 Digital Camera
Loud noise
nost likely the color wheel, They are famous for having a piece come off the wheel which will cause a very loud humming sound.
Jan 15, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
E18 error w/sound effects!
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 18, 2009 | Canon PowerShot A95 Digital Camera
Compaq V2710us shuts down randomly with a loud click
Loud click sounds like either a short or overload, causing ground default. recheck inside for any loose connections anything grounding out the motherboard.
Jun 28, 2009 | HP Compaq Presario V2000 Notebook
A95 pictures are grainy with horiz lines, camera makes clicking s
Contact Cannon tech support. A95 has a sensor problem. If it is the sensor Cannon will pay shipping both ways and repair it for FREE.
Dec 27, 2008 | Canon PowerShot A95 Digital Camera
Clicking noise
clicking?
if it is a ticking sound, check your oil level.
if after you shut down, then you probably had the air conditioning on? If so, normal.
does it drain the battery?
Oct 02, 2008 | 2001 Pontiac Grand Am SE
A95 Trouble
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Dec 08, 2007 | Canon PowerShot A95 Digital Camera
Canon PowerShot A95 Digital Camera Logo
50 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
