Question about Canon PIXMA MP210 Photo All-In-One Printer
My printer is showing error 1300 which I think indicates a paper jam yet there is no paper jammed in it. Is there anyway to reset it?
TIPS72
  • 369 Answers
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
Posted on Jan 04, 2009
ghassun
  • 499 Answers
SOURCE: canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
Posted on Jun 09, 2009
  • 13433 Answers
SOURCE: my canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
Semi-Driver
  • 434 Answers
SOURCE: Printer says clear paper jam then press reset
Could there possibly be:
A) Paper jammed internally: Power Off. Open the cover and remove the paper or scrap carefully. Do not touch the internal printer parts. Close the cover. Power on.
B) Foreign objects in printer: Power Off. Open the paper support and confirm that there is no foreign material in the auto sheet feeder. (If so, remove it by hand or with tweezers). Open the front cover and confirm that there is no foreign material in the unit. Avoid touching the inner workings of the machine.
C) Reset the printer:
1. Turn the printer off with the Power button
2. Disconnect the data cable from the printer
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. Attach data cable.
4. Turn the printer back on.
If all of these suggestions fail, your iP1600 may require repair service. Please note: With the suggested retail price of $29.99 USD, repair does not seem cost effective - you could just go out and purchase a new printer.
Posted on Dec 28, 2009
pineworks
  • 4041 Answers
SOURCE: alarm says paper jam,cant find any paper jam,
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 02, 2010
Paper jam in hp1300 cannot print
Remove the cartridge and paper tray to see where the paper jam is. If it is a whole page jammed inside of printer, before removing shut off printer and carefully remove paper if you end up tearing a piece this will make it harder to remove in pieces. After you have removed jammed paper reinstall toner cartridge and paper tray turn printer on and see if this clears the jam error message.
May 28, 2010 | HP LaserJet 1300 Printer
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
Hp laserjet 1020 thinks it's jammed but it's not
you will have to first disconnect the printer cable and eject the paper from printer tray.
after you should be delete the pending document and uninstall and reilnstall the printer.
best of luck
Aug 30, 2009 | HP LaserJet 1020 Printer
Canon MP470 printer jam error
hi...open the printer then clean..i think theirs a lot of DUST that's why printer said paper jam
Jun 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Paper jam error code with no paper jamb
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq17
Jun 16, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon ip4300 Error code 1300
Jun 09, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
PAPER JAM ERROR 201.02
if you are gettiing a 201 error without any paper in the printer you will need change the main motor drive if it fails to initialize this is the error that will show up and there is no other way to reset it
Mar 20, 2009 | Lexmark T640 Laser Printer
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
Error 1300 keeps coming up on myh Canon Pixma IP4000 although there's no paper?
Dear pants53,
Code 1300 indicates that paper jam error occurs. First, check whether any broken paper inside the paper path, remove it then press Resume/Cancel button. If problem still persist, means paper sensor error or paper sensor cam is broken. If it so, then I suggest you bring your printer to nearest service center.
Regards,
Nov 08, 2008 | Office Equipment & Supplies
Canon PIXMA MP210 Photo All-In-One Printer Logo
124 people viewed this question
old marine
old marine
