Question about Sharper Image Ionic Breeze 3.0 Air Purifier
It does not get power - Sharper Image Ionic Breeze 3.0 Air Purifier
  • 55 Answers
1. Try another outlet.
2. If still does not work, most electronics have or use a fuse. Verify but pulling out manual to see if it has a fuse you can change.
3. If that does not work, see if the power adapter is warm (if it has one) which means it it receiving current. If not it is a sign it is dead.
Posted on Sep 25, 2009
Where is the backup battery?
portable battery backup power supply for macbook pro and air
www.clubfidelis.com/news/index.php?q...battery-backup-power...air
PORTABLE BATTERY BACKUP POWER SUPPLY FOR MACBOOK PRO AND AIR: PORTABLE BATTERY BACKUP POWER SUPPLY ... HT201700 I need a portableback up battery for my MacBook Air 11 . ... air purifiers that controls mold.
Battery Powered Air Purifier - Wag.com
www.wag.com/html/sg/battery-powered-air-purifier.html
... 365-day return policy. Buy Battery Powered Air Purifier at Wag.com. ... MarinaBattery Operated Air Pump .... Penn-Plax Air-Pod Battery Back Up Air Pump.
Amazon.com - Mini Portable Battery Air Purifier Air Ionizer ...
amazon.com/exec/obidos/ASIN/.../amztowps-20
Amazon.com, Inc.Amazon.com - Mini Portable Battery Air Purifier Air Ionizer For Small Areas - BatteryOperated Air Purifier.
Jan 05, 2016 | Air Purifiers
Lasko Tower Fan stopped working but Speed switch has power on all but one cable, How to find the issue?
you should only have power on the black wire into the switch. The white wire feeds straight through. the switch breaks the black and routes it to one of the three outputs for the motor.
Aug 07, 2014 | Lasko 2510 36" Tower Fan with Remote...
Why doesn't the fan engage? The filters are perfectly clean and it receives power
See if the motor is bound up. Move the fan blade to check for stiffness. The motor may just need a drop of oil. There is an internal fuse in the motor that you cannot change It may have opened. If you have access to a volt meter check all the wires on the power switch
Jul 16, 2014 | Honeywell 50150-N True HEPA Allergen...
Carrier 58MVC100 furnace no power. Tree fell on main power line and after power restored noting going on with furnace/air handler. LED is not lit. 3amp fuse appears to be good and there is a sulphur smell...
Possible that when power got restored you furnace might have gotten surged. replace fuse any way to be sure. Check break box for trip circuit. Call a tech from there man.
Aug 08, 2013 | Carrier Infinity 58mvc080 Gas Furnace 80k...
My professional series ionic breeze gp s1830/961 will not turn on
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Nov 17, 2011 | Sharper Image Air Purifiers
Device appears to have no power. Power cord looks good, it was working the day before then suddenly stopped working... no lights indication of any power making it to the device.
This unit will not operate if it is plugged into a power strip - it must be plugged directly into the wall outlet. An extension cord may be used.
Aug 16, 2011 | Honeywell (18155) Air Purifier
My Honeywell no longer turns on. What could be the problem?
It can be power to the unit, power to the switch,relay or power to the blower.
You will need to remove to check the voltage and continuity with a multimeter to confirm on this failure.
Aug 23, 2010 | Honeywell 50250N Air Purifier
I have an F50f electronic air cleaner. none of the
you need to change the power supply please contact your heating and cooling contractor for service on the unit.
Mar 03, 2010 | Honeywell (F50F1032) Air Purifier
Pure Ion will not turn on. We took out the filters to clean them. Wall outlet works for other items. Have tried other outlets.
It sounds like the main board is not getting power. The power supplies have capacitors inside that do overheat and burn out. You can test power coming from power supply leading to main board with a voltmeter. You can try to unplug for 8 hours, in meantime while unplugged, press and hold power button for 5 seconds, then wait 1/2 hour and plug back in to see if unit has reset itself
Oct 13, 2009 | Brookstone Pure-Ion UV Air Purifier
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
83 people viewed this question
Top Sharper Image Air Purifiers Experts
Jason
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
