Question about Cycling
Bicycle pump: how to use it for Presta valve (instructions don't show this well.
    Problem Solver:
  • 5 Answers
Pump itself may have a female adapter that rotates to accept presto, otherwise you need a small presto to shrader adapter sold at all bike shops near the register-brass piece that screws on to valve stem.
Posted on Sep 25, 2009
How to attach bontrager pump to presta valve
This pump does not need any presta valve adapter, the head unit is a dual unit for both presta and schreader.
1. On the bicycle tube. Open the valve by unthreading the small metal cylinder located at the very end of the valve stem. DO NOT force the the bead to come off of its threading. A couple spins counter clockwise will do the trick.
2. Insert the valve stem into the filler head. The lever on the back of the filler head should be "down" at this time.
3. Connect the filler head to the valve stem by lifting the lever on the head "up".
4. The valve stem and the handle on the filler head are now in parallel to each other, basically inline with each other.
5. START PUMPING.
6. If loosing considerable air while pumping, Try reinserting the valve in to the filler head, deeper, for a more secure fit.
If the issue persists, use a presta valve adapter on the valve stem. Traditionally used to convert presta valve heads to schreader heads, for use with filler heads not compatable with presta. A one dollar part available at any bike shop. Usually used in a pinch while airing up at gas stations or with schreader only pumps.
Dec 27, 2012 | Bontrager Supercharger Floor Pump - cycle...
I purchased a Schwinn bicycle pump, but I'm having trouble determining how to use it to inflate my standard bike tires. The instructions that came with the pump assume that I know the name of the type...
There are only two types - presta and schrader. If the instructions named them you could just Google them for descriptions and all kinds of other answers. The schrader is what we think of as the automotive style.
http://en.wikipedia.org/wiki/Presta_valve
http://en.wikipedia.org/wiki/Schrader_valve
Back to the search engines, "how to..." usually finds answers, such as "how to inflate a presta valve tube".
http://www.terratrike.com/media/documents/PrestaValve.pdf
http://www.youtube.com/watch?v=wreZho5I2E4
http://en.wikibooks.org/wiki/Bicycles/Maintenance_and_Repair/Wheels_and_Tires/Inflating_Tires
Aug 02, 2011 | Schwinn Cycling
How do i set up the pump to inflate a presta valve tyre?
If it is not a Presta pump, then you will need an adapter. These adapters usually run for less than a dollar and are easy to use. You can just screw it onto the Presta valve and then it converts it to a Schrader. You can see what they look like HERE. They should be available at any bicycle, camping or hiking store. Good luck and be safe riding! (Helmets are your friend)
Mar 04, 2011 | Topeak Peak Master Blaster Dx Pump
How do you inflate this tube with the presta valve?
The following link is a good explanation of inflating a presta valved tube if you have a pump with a presta valve head.
If you have an older pump that does not have a presta valve head, you can purchase a schrader valve adapter from your local bike shop that screws onto the presta valve and will allow you to utilize a pump with a schrader head.
A good explanation can be found here: http://bicycletutor.com/presta-valve/
Feb 18, 2011 | Cycling
The pressure gauge on my Topeak Joe Blow Ace floor pump is not working. The pump works fine. How do i take the pump apart and what should I be trying to do to repair?
http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html
  1. Rotate the wheel so the valve is resting just above the floor. Remove the valve cap.
  2. Unscrew the locking nut on the valve stem. Quickly press down the stem to loosen the seal. You should hear air escaping when the stem is pushed in--if you do not, loosen the nut and try again.
  3. Press the pump head onto the valve and flip the locking lever to make a seal. You'll hear air escape, but it should stop after you've locked the lever. If air continues to leak out, remove the pump head and reattach it.
  4. Make two pump strokes and listen for air moving into the tire. If the pump handle becomes hard to press down after only a few strokes, or if the pressure gauge elevates extremely quickly, remove the pump head and repeat Step 3.
  5. Inflate the tire to its recommended pressure. Remove the head by unlocking its lever and quickly pulling it off the valve stem. Secure the valve's locking nut and cap.
Presta Compressor Toolwww.prestaflator.comInflate Road or Mountain Bike Tires Accurately in Seconds!
Read more: How to Inflate a Bicycle Tire With a Presta Valve ' eHow.com http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html#ixzz1Brv5VfAX
Jan 09, 2011 | Topeak Joe Blow Ace Floor Pump
How do you use the schwinn bicycle aluminum frame pump?
Do you have a presta or schrader valve on you bike tube? A schrader is a standard valve, presta has a little nut that has to be loosened to add air. Your pump has both heads or adaptors (I don't know which model you have). You should have instructions with your pump to explain how to use it, if not go to www.ehow.com and you can read all of the instructions, no use me repeating what you can read on your own.
Jan 04, 2011 | Schwinn Bicycle Aluminum Frame Pump
HOW DO I PUT AIR IN A MOUNTAIN BIKE TIRE WITH A PRESTA VALVE WITH A TOPEAK MINI MASTERBLASTER PUMP.
Nov 02, 2010 | Topeak Mini Master Blaster
I have just purchased a Topeak Mountain Morph pump, which can be used with both Presta/Scrader valves. I have a presta valve on my bike, but am not able to inflate my bike. Not sure if I am doing...
Aug 25, 2010 | Topeak Morph Pump
How do I pump a presta valve with the Blackburn Mountain Air Bike Pump 4 Bicycle
They should be designed to fit both styles of valve, but you need to reverse the seal.
you should be able to unscrew the end, remove the sealing rubber and a plastic fitting that pushes on the valve, replace them the opposite way around ,and they will fit the presta.
Aug 22, 2010 | Blackburn Mountain Air Mountain Bike Pump...
Cycling Logo
310 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
