Question about Saws
Not cutting in straight line
Circular saw not cutting in straight line. it starts straight then veers to the left and keeps pulling more and more left until the blade gets stuck and stops turning.
    Problem Solver:
  • 14 Answers
Normally blade overheating. Improper blade or too few teeth for material, teeth not sharp and/or offset enough for proper width of cut. Teeth must cut wider than blade. Inexpensive blades tend to do this quickly. Other possibility: Bad bearing, check for play with saw unplugged. Blade should have little wobble. Other possibility: Saw body cracked/damaged(allowing shaft to skew) or very cheap saw unable to handle material
Posted on Sep 25, 2009
What would cause the ridgid 10inch wet saw blade to not cut straight?
damaged teeth on one side not cutting evenly so the good teeth on the other side allows the blade to veer away from a straight cut
Have the blade resharpened
Feb 17, 2016 | Blade Saws
My craftsman miter saw cuts but it is not a straight cut.
Here's an old dude trick that might help.
Safety first! UNPLUG THE SAW.
- Take a framing square and set it against the fence. It should be flush with the fence on both sides of the blade. If not, slide the square to one side and pull the blade down into full cut position, then slide the square against the blade and fence to check for square. If square, slacken the bolts on the other half of the fence and align it with the correct side.
- A bit of messing about should have it lined up just fine.
- If it is off vertically, there should be some alignment possible.
Patience and safety.
You'll get it.
Oct 08, 2015 | Craftsman Saws
Macallister chop saw blade problem, the motor runs but when half way through cutting wood the blade stops ?
I'm not sure if you have a chop saw or circular saw. Either way, it sounds like the nut and washer are not tight enough to hold the blade. If you have a circular saw clockwise will tighten the nut and washer onto the blade and hold it in place. Most chop saws are a left hand thread and then you would turn the nut counter clockwise to hold the blade tighter. The blade wobbles because it is not tight.
Feb 23, 2015 | Saws
Why does tile veer off?
If you have a bridge saw. The blade and motor may not be parallel with the rails the motor travels on.
Feb 18, 2014 | Felker FRS-38 Tile, Marble & Granite Rail...
Attach edge guide onto skill jigsaw
I don't know why they even provide edge guides with jig saws, they don't work worth a flip. The problem is that, unlike a circular saw, the direction of cut is unlikely to be 90 degrees from the direction of the mounted edge guide. The blade mounting is not made to ensure that the blade is held exactly straight. When you follow a straight line with your cut you will see that the body of the saw will probably crab a bit sideways like a car that badly needs a wheel alignment. I suppose the edge guide can work on 1/4 inch plywood with an aggressive blade, but that will give you a very rough cut. Much better to draw the line and just follow it visually. If you need to do a lot of this, and you want a nice straight line, use a circular saw. Good luck.
Jan 15, 2013 | Craftsman 680915001 Edge Guide
GUIDE DOES NOT LINE UP WITH BLADE EVER AFTER ADJUSTMENT NOTHING SEEMS BENT OR BROKE.
If you have removed the blade, check to make sure that you have assembled it correctly. All the spacers in the right place.
Feb 04, 2012 | Dewalt DW364 7 - 1/4'' Heavy Duty circular...
Will not cut straight lines
Tension the blade so it's correct tension.
Sep 03, 2009 | Saws
Cutting straight
this is usually caused by a dull blade or you need to carefully re-adjust the blade guides
Aug 12, 2009 | Ryobi 9 in. Benchtop Band Saw
Grinder question
Use a pencil and straight edge to mark the cutting line on the wood. Place the wood on the saw table and line the mark up with the saw. Place the mark on the right side of the blade to ensure proper cutting. Plug the saw in and put on your safety goggles. Support the wood on the work surface with your left hand, placing it far from the saw blade. Place your right hand on the handle, and push the trigger to start the saw. Move the saw blade down onto the wood. Put constant pressure on the handle to slowly move the blade through the wood. Release the trigger and raise the blade once the cut is complete. Make diagonal cuts in the same manner, by marking the wood and lining the mark up just to the right of the saw blade. Continue as you would for a straight cut. Remove the wood from the saw. Unplug the chop saw and dust the sawdust off. Remove the dust bag from the back and empty it. Vacuum any remaining dust off of the saw.
Aug 27, 2008 | Dremel 10 Diamond Cut-Off Wheels Saw Disc...
Saws Logo
293 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
