Question about Samsung DLP HL-P5663W 56" TV
Worth it to repair?
My Samsung DLP lost its color, the tech told me it's the dmd board. the cost to repair it will be about 1000.00. Is it worth it to repair it? It's four years old.
    Sergeant:
  • 269 Answers
Hi! 1000.00 is still cheap if you consider the prize when you have purchased it. i think it is still wort it.
Posted on Sep 25, 2009
Can you replace the screen on Samsung 67a DLP
Elisha,I was not able to find anywhere selling a replacement screen. May I ask why you want one? Did it get damaged? http://www.youtube.com/watch?v=-xUhOdzwLtw
Did you have the unit looked at by a repair tech? What is the year of your unit and symptoms? The screen is just like a projector screen (DLP stands for digital light processing) It does not have pixels like a monitor or TV has and doesn't wear out or break unless it was physically damaged. If you could get one the cost of repair would likely exceed the value of the unit. If you have picture issues it typically is the lamp, color wheel, or dmd board or a defective capacitor. Have you registered your unit with Samsung with current contact info? You may be part of the class action suit that Samsung recently settled http://reviews.cnet.com/8301-33199_7-57376508-221/samsung-power-defect-causes-some-tvs-to-fail-and-a-class-action-suit-follows/ you can try the link to http://www.samsung.com/us/capacitorsettlement/ but it is not working for me.
Jan 04, 2014 | Samsung HL-67A510 67" DLP HDTV
Samsung dlp tv freezes
The DMD board which will cost more than the set is worth---about 450 by itself.
Nov 29, 2012 | Samsung HL-R4264W 42" DLP HDTV
I have a 65hm117 tv. It has white spots and every day more spots ap[pier. What part do I need to replace.
I have the same problem with my 65HM117. Funny, but it started just when I was getting a FREE repair for a Samsung LCD tv with bad caps on the power supply about the same age as the 117. The problem according to Samsung tech (who was kind enough to look at it while he was here) is the DMD (digital mirror device) chip, the "processing" part of the DLP (Digital light processing). Suggested I call Toshiba. Toshiba rep, obviously not in the USA, told me Toshiba doesn't make DLP's anymore "because of all the problems." They apologized repeatedly, repeatedly pointed out the unit is "out of warranty," but NO help or recal even though they know they built a product with defective, unreliable technologyl. Bottom line, Toshiba lost a customer but SAMSUNG has one for life! I'd repair it, but can't find the part number for the board with the DMD...
Oct 18, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
ISamsung TV model # HC-P4363W
Check the tv out?If the tv have picture,colors R,G,B misalignment,picture have colors shadows,look like 3D pictures.The tv problems is it have a convergence problems.Very common on a DLP tvs.Very much repairables.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 17, 2010 | Samsung HC-P4363W 43 in. TV/DVD Combo
Samsung HLP4663W I have changed Bulb, Ballast, and Color Wheel, Yes, removed the Jumper and set to CW2 too!(color wheel had no sticker with CCA Values or Actuator or Index Delay Values on it) I set the...
th dmd pcb can somtimes cost as much as a rebuilt light engine that comes with the dmd pcb colorwheel and dlp chip. look into a rebuilt light engine from tri state modules or pts electronics.
Feb 06, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Have the picture but no color on my SAMSUNG DLP. What is causing it and how do I fix it?
Was it turning itself off just before it lost color? I have the same problem and my tech told me it was the DMD board, a pricey repair.
Sep 25, 2009 | Samsung DLP HL-P5663W 56" TV
Tv keeps turning off
Mine was doing that and then it lost all color..tech tells me its the dmd board, a pricey repair. Debating whether it's worth it or not.
Sep 24, 2009 | Samsung DLP HL-P5663W 56" TV
Turns on but eventually freezes in black and white
is better if u replace the optical block cost less money , also it come with new lamp and color wheel and new ballast , all this parts go bad after couple years
May 06, 2009 | Televison & Video
Samsung HLN 4365 wxixaa with Light engine failure????
When the tech said light engine what he ment was DMD board, the DMD board is the most important component on the light engine and most expensive, but still a lot cheaper then the entire light engine.
The DMD board can definetly, and often does cause intermitant errors. Your problem is absolutely not the Ballast, all the ballast is supply the power to turn on the lamp.
Your tech was right to go to the DMD board, the only other option that it could be is a digital board, you would have to see if it is doing this on all inputs.
Mar 03, 2009 | Samsung DLP HL-P5663W 56" TV
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
Sounds like you've lost your red video signal (chroma) somewhere along the line. This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. The analog has all your inputs on it, except DVI and RGB which go straight into the digital board. The digital scales (upconverts) the signal to HD (1080 or native) and sends it to the DMD or light engine. See which inputs are distorted. If only DVI is clean then you problem is the analog board. If you menu and everything is distorted then suspect the DMD board. If you run component or DVI through the resolutions (480i, 480p, 720p, 1080i) you can get an idea between the digital board and dmd. The menu is generated on the digital board. Somewhere red is getting lost.
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
217 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
