Question about Canon PowerShot SD600 Digital Camera
My SD600 says that the SD card is locked, when it is not.I have tried several different cards and the camera still thinks the card is locked.
  • 797 Answers
If your camera is under warranty, call Canon and see if they will fix it. If it is not, call Canon 800 number for repair. See if they will fix it, it may be worth your while to find out, and how much if anything it will cost. If it is too expensive, you may have a choice to trade-up or trade in to one of their refurbished units they have. This is a great program, and I have used it more than once.
This may be a problem with these models, but only Canon can give this answer to you. They have great service, and are willing to talk, so do it.
Posted on Sep 25, 2009
Work with a 1 GB card but shows Error message and card locked on new 8 GB card
The SD600 works with MMC and SD cards. Your new 8GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to use SD cards, 2GB and smaller.
Feb 03, 2011 | Canon PowerShot SD600 Digital Camera
We have a PowerShot SD600 camera that is having trouble reading memory cards. It comes up with "Memory Card Error" and "Memory Card Locked" even when the card is not locked. ...
This camera can use only cards with the SD mark on it. An identically physically sized SDHC card may be in the camera and could be causing the issue. Generally, SD cards have capacities up to 2 GB and the SDHC (the HC stands for High Capacity) are those 4GB and larger in capacity.
If the card you're trying to use is an SD card, the card may have become corrupted and need to be replaced. Try with a different SD card to be sure. Hopefully, it's a card problem - not a camera problem.
Please rate this reply - good luck!
Dec 03, 2010 | Canon Cameras
I bought a new SD card for my powershot SD600. I have tried two different cards and they both say they can be formatted. What is the problem?
Bet it's a brand new SDHC card.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 15, 2010 | Canon PowerShot SD600 Digital Camera
The screen say's memory card error, card locked, but it is a brand new card. I unlocked it and it still says error
I think you have a HC card, Any SD memory card about 2GB runs at a different compression rate to the 'normal' SD cards. ie High Compression. If you do have a larger card in an older camera it will not read, The camera cannot access the information, and it will not work. If it's a 2GB or smaller, try formatting the card - Go to your review menu, press setup and chose format from the list. This should sort it out.
Jul 25, 2010 | Canon PowerShot SD600 Digital Camera
How to format an SD card on a Canon SD600 camera when the menu says "memory card locked." The memory card is in the unlocked position. When we put the SD card in another Canon camera (SD780 IS), it works...
Could be that you have the wrong memory card.
SD600 will only work with the old SD cards, but the SD780 will take the SDHC cards.
SDHC was intended to give 4gb or more of storage, while the old SD started as 16 mb.  Different cameras have different limits, but it is always best to assume that the practical limit on an SD card is 2mb.  Even if the SD780 will take the SDHC cards, it can be more practical to only carry 2GB SD cards and know that they will fit either camera
Feb 22, 2010 | Canon PowerShot SD600 Digital Camera
I have loaded a new memory stick and get a message "memory card error" I have since tried another card and get the same maessage. Any idea waht the issue is.
Well if your camera is an SD600, I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Nov 17, 2009 | Canon PowerShot SD600 Digital Camera
My canon sd600 is not reading PNY sdhc memory card. msg says card is locked. it's clearly not locked
HC or High Capacity is not compatible with this camera. You have to buy a memory card which says only "SD" and NOT "SDHC". Cards of 2Gb and less are usually "SD". Cards of 8Gb and more are always "SDHC" for technical reasons. Cards of 4Gb can be either, but the SDHC kind are much more common, because they're cheaper and newer.
Jun 22, 2009 | Canon PowerShot SD600 Digital Camera
Camera thinks memory card is locked
check the pins where the memory card enter, if they are all there (not bended) go to canon site and download the latest framework.
P.S, mack sure to use the right SD Card type as the camera is compatible with some types and with a limited size only.
Oct 01, 2008 | Canon PowerShot SD890 IS / IXUS 970 IS...
"Card Locked" error is false!
Remove card from SD600 camera. Locate sliding switch on side of SD card and move from lock to other (unlocked) position. That ought to do it. Compact flash card is another issue.
Mar 19, 2008 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
77 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
