Question about Microsoft Comfort Curve 2000 Keyboard
Microsoft Comfort Curve 2000 v.1 Key ) problem
My keyboard started to show a similiar problem. The only way I can get a ) is releasing shift key before key 9 is released.
This is a very annoing problem.
Right, I've done a more extensive search on google for this and it turns out that you don't have to take your keyboard apart for this.
My I key wasn't working, so I found out that all you have to do is lift the keyboard up, turn it sideways and give it an almighty slap on the back.
Solved my problem!!
Posted on Nov 17, 2010
  • 2 more comments
  • zzzzzKEY Dec 28, 2010
    holy shiet.
    that WORKED!!!
    got my zzzzzzzz key back :)
    thanks man!
  • Kenny Jan 04, 2011
    Because this site doesn't seem to allow web site URLS to be posted, then I recommend using Google - search for "southpark whirlpool comfort curve 2000", and there it will link to a solution.
  • Solester Jan 29, 2011
    I also gave it quite a strong slap on the back in the area of the key that had the problem (the shift left key) and it worked! :)
  • zzzKEY2 Feb 22, 2012
    I just slapped it in the back for 2 times and THAT WORKED for me too!!!
    my Z key is back!!! THANKS
    Problem Solver:
  • 8 Answers
Hey Guys,
I have manage to workout the cause why few random keys tend to stop working on Microsoft Comfort Curve Keyboard. These MS comfort curve keyboard are sold in UK and Germany and some other parts of Europe.
The problems with this MS comfort curve keyboard starts when at random some of the keys stop working, it dose not matter how hard you press or for how long, they just wont work, this problem is due to static charge build up on the thin plastic sheet/mat inside the keyboard that has electric circuit printed on them. This new keyboard technology is wonderful and superb, the keyboard is sheer pleasure to use when it is working, when you press the key it is quite soft and silent, so, it wont wake the baby up. it has no mechanical parts inside keyboard, it has lots of small soft plastic **** on plastic matt that you press with your keys so they don’t make any sound, same as in your average Remote control. Even in this year 2010 this plastic sheet circuit board needs lots of improvement yet, because it suffers from static charge build up. Microsoft seems to have opted for the cheapest quality non expensive plastic sheet circuit mat for their keyboard, probably made from some cheep biodegradable recycled plastic condoms, these cheep mats always have tendency to hold onto electric charge and wont discharge when they should, and consequently cut off circuit connections to the keys, same technology that is used in majority of the household remote controls, and ,so, the reason why Remote keys tend to stop functioning after a while.
This problematic MS Comfort Curve Keyboard can be temporarily repaired, it takes about 15 min max. Unscrew and take apart keyboard, discharge the plastic sheet circuit mat and that’s it, the keyboard should work for few hours or days, but you will have to turn into baby sitter for this pest keyboard, as you will have to nipple feed the monster keyboard all over again, you will have to strip down the keyboard again and again, while it strips you L Till some tech guy from Microsoft sneaks onto YouTube to tells us about the permanent fix for the scary leaky discharge from MS Comfort Curve condom L A well funcked keyboard design from SM, that needs plastic mat printed circuit to be patched up with paperclips or hairclips or silver foil and tape L While half way through the year 2010, I still have not seen any info on Microsoft website about a keyboard that was designed on crazy train production line and needs to be returned back to Microsoft for replacement. On this occasion Microsoft must own up about bad keyboard design, the MS loose cannon keyboards that have been sold through vendors to customers.
Personally I never had any problem with any make of keyboard for the last 15 odd years, most of them were Microsoft brand. But in 2010 this was my 1st ever horror story that I had to open up a keyboard with screwdriver and use static charge tools to resolve the issue, as this real funky Microsoft Comfort Curve Keyboard turned out to be real nasty piece of crazy production work. Probably like Apple’s Book it was great idea, a keyboard with thin plastic sheet circuit board, and with no mechanical parts other then plastic keys. Was this risk worth taking by Microsoft? At this moment in year 2010. Two off the worlds leading computer software and gadget producer are desperately seeking two opposite solutions; Apple is looking for signal transmission Aerial as powerful as microwave oven to spit-roast their customers, and Microsoft is looking for quick Lightning conductor to earth the bad vibe signal from thunderous discharge?
Here are 4 easy options/solution to resolve the non-responsive key problem with Microsoft Comfort Curve Keyboard, chose wisely, and get the keys working again till Microsoft comes to rescue;
First option is to buy yourself about 200 to 500 meter of heavy duty electric cable, as you will need to connect your Microsoft Comfort Curve Keyboard to the nearest Lightning conductor in your local area, this will take care that your Microsoft keyboard gets properly discharged when you are busy typing away your long memos on Facebook to tell it to the rest of the world about your misery of using Microsoft keyboards. But downside is that each time there is electric thunderstorm in your local area it will for sure perish you and your Microsoft comfort curve, but upside is that in the end you will be able to bitterly complain to your Gods about nasty discharge from Microsoft Keyboards J
The 2nd solution is a wishful thinking, as still there maybe a hope in hell when in despair; that is if Microsoft has any spare time available to them as they have no time to help customers as they are always totally busy and committed to make lots and lots of money, billions of £$ in shortest time just in case they RUN OUT OF TIME? So, one can hope that MS (SM?) may send some keyboard drivers “service pack N” updates, say 1 Gb plus to Microsoft keyboard users, that will somehow discharge the overcharged keyboard, but again you may have to type each character twice on your keyboard because each time the keyboard static is discharged it will wipe-out your keyboard buffer too L
The third option is really easy and wont cost you fortune and wont make Microsoft super rich either. Go to your local shopping Mall or shopping centre and get yourself decent plastic shopping bag, open the back of the Microsoft keyboard, you will need to unscrew about 15 to 20 screws on the back of the keyboard, and then take out the Microsoft Plastic mat that is probably made from some cheep recycled condoms, and replace it with your good quality plastic shopping bag, hopefully then you wont ever have to worry about the MS SM keyboard problems.
The last and more realistic solution is that Microsoft must buy Google, it dose not matter how much it may cost SM, and then MS can put a video clip on YouTube to guide Microsoft Comfort Curve Keyboard user on how to take apart their keyboard and correct the plastic mat circuit problem J But 99.911 % of SM keyboard users do not have that extra wasteful time to fiddle around with their keyboards to repair them, and wont put up with jiggery-pokery. Therefore the wisest thing Microsoft must do is to own up the massively horrible problem with some of their keyboards and replace them, it should not matter if the customer has the receipt or not for the keyboard purchase, if the keyboard is less then 3 years old from the time the customer purchased the SM Keyboard, MS must give customer full consumer rights to take the keyboard back to the vendor where it was purchased or customer can send it back to Microsoft head office , and Microsoft must replace it by giving customer option to exchange their keyboards with similar or another safer? Microsoft keyboard. I wonder if the Microsoft Comfort Curve Keyboard was made by Toyota or by some toy or baby milk factory in china J
Posted on Jul 23, 2010
  • georgeh1960 Dec 31, 2010
    I've had the same problem with this keyboard.. I took mine apart and washed the key membrane. That fixed it.. I have 3 of these keyboards.. 2 of them have had this problem.. Now if you want a really good keyboard, try the Logitec Comfort Wave.. very nice...
  • 4 Answers
Well the SmApple guy put me on the right track, but the main deficiency with this keyboard is the lack of a proper ground (which would cause a static build up. Opening the keyboard, I found a bright metal screw that held the sheets to the small pcb board inside. I assumed this was a ground, but when I took that off, it wasn't connected to any sort of ground. So, I took a small wire, clamped it to the screw, and connected it to the USB (G) port. Voila, a working keyboard!
Posted on Mar 13, 2013
  • 2 more comments
  • David Madden Mar 18, 2013
    I am having problems with a Microsoft Ergonomic 4000 keyboard. The lights will come on but it refuses to work. Would what you did likely fix the problem?
  • Andrew Ornelas Mar 18, 2013
    I would suggest you open up your keyboard to see if it is a similar issue. I found this video on how to open it, if it helps. What you are looking for is a screw connecting the plastic sheets to the small pcb board. If there is a connection, check if it is grounded or just a dead end, like mine was. Then add a wire to complete the ground.
  • Ninety5hatch Sep 28, 2013
    The R button on my confort curve keyboard was not working. I opened it up and cleaned the membrane, but no luck. I was getting ready to throw it in the trash when i found Andrew Ornelas suggestion. The factory wiring crosses right over the ground screw he was talking about. I traced back the black G wire, stripped off some insulation, placed the exposed wire under the screws, and my keyboard works great again. THANKS! RRRRRRRRRRRRRRRRRRRR
  • Andrew Ornelas Nov 19, 2013
    That's awesome, thanks for the picture!
Andrew Ornelas yes!! you are on right!!! cable from screw to usb ground!! and all work perfect!!, I try slap on the back but some keys continue not work, I put the wire and all ok!! If help i put image:
Microsoft Comfort Curve 2000 v.1 Key ) problem - ffbf3ae1-09f6-4fcf-b805-2b31c9ac866a.jpg
Posted on Nov 19, 2013
  • Austin Rain
    Austin Rain Jul 24, 2014
    How does the wire fit into the usb ground (white part shown above?) - do you just pus in a stripped wire?
HOW DO I USE THE KEY TO TYPE A @
Hold down the SHIFT key on your keyboard, and press the '2/@' key. Release that key. Release the SHIFT key.
Feb 10, 2015 | Computers & Internet
What is "FN" key
Most laptop keyboards have a key marked "FN" or "fn". This is just another shift key, like the shift, control, and alt keys. If the instructions say something like "Press fn+F1" then press and hold the fn key, press and release the F1 key, then release the fn key. Exactly the same type of procedure as when the instructions say something like "Press Control+P".
Mar 19, 2013 | Computers & Internet
My Acer key board can not display the at sign above TWO key shows inverted commas instead and the hash sign above THREE shows a Pound sign? Please assist
Hold down the ALT(ernate) GR(aphic) key -- to the right of the SPACE BAR on your keyboard.
Press the '2' key.
Release the '2' key.
Release the ALT GR key.
Does an '@' display?
Check that you are using the "American English" keyboard mapping.
Control Panel -> Regional options.
Mar 06, 2011 | Acer NSK8458AN Keyboard
The @ symbol is on the wrong key it is on " key ,
Hold down the ALT(ernate) GR(aphic) key (to the right of the SPACE BAR).
Hold down the SHIFT key.
Press the '@' key.
Release the '@' key.
Feb 26, 2011 | Acer NSK8458AN Keyboard
When I want to put in a Question mark in a sentance, I get that funny little red E that is on the same key.
You have the wrong keyboard selected for your computer. This can happen based off where you purchased the computer. The installed keyboard profile is wrong. Do this below:
Control Panel > Regional and Language Options > Keyboards and Languages > Change Keyboards to the one for your correct language
Jan 18, 2011 | Toshiba 310CDT Keyboard
HOW TO GET MY LAPTOP TO STOP USING THE PINK ALTCAR
I found this on another website and it worked for me. Good luck.
Okay, I know this is an old question but when i searched for the same problem recently, it was the nearest I could find. So in case others are having the same problem:
The Vaio you have is a Canadian model, which has alternate keyboard drivers for English and French. The alt car key only works with the French keyboard (durr). To switch, press the LEFT control key and RIGHT shift key at the same time, then release. Now if you use the alt car key like the shift key, i.e. hold it down then press another key, you should be able to access the pink characters. To return to English keyboard, press left-ctrl and right-shift together again.
Sep 25, 2010 | Sony VAIO VGP-WKB1 Keyboard
I cannot get a question mark, the upper case E with a grave (green) on keyboard appears
When you get that it usually means the language setting for the keyboard has changed.
The standard key markings are valid for most english language settings. US is the default. To change this go to start - settings - control panel. Then look for Regional and language settings. Click on that and then in the window that open there are three tabs along the top. The middle one should say language, click on that one. In the Text Languages and input options area click on the Detail button. A new window opens. At the top it shows your language. And in the box under it will show your lnaguage and installed keyboard layout. So if I were using Canadian English and the US keyboard then the keys will function as marked. To change the keyboard language click the add button, then select your language and then the keyboard layout. When you click ok it goes back to the previous window but now will show the original setup and the new one you just made. Just remove the original and apply and close everything and your keyboard will now produce the correct characters.
Apr 23, 2010 | Acer NSK8458AN Keyboard
Key struck in the ignition can't get it out will turn to start but won't start nor allow me to take key out
Check if the key is broken, otherwise check the car's safety systems. If the battery has been discharged, the electronic vehicle immobilizer can be activated. Try to reconnect the battery and then take out the key=) Good Luck, Regards David.
Jul 12, 2009 | 2003 Cadillac CTS
Want to know hot key combination to switch ports from keyboard.
Press and release CTRL-ALT-SHIFT
Press and release Machine # (1 - 4)
Press and release ENTER
or
Press and release 9 (This puts you into Prev/Next Mode)
Prev = Left Shift - Next = Right Shift
Press and release space bar to exit Prev/Next Mode.
Aug 15, 2008 | Protec Microsystems Bytelan KVM/4 KVM...
Datalogic Heron D130 (Barcode Reader) Header setup
Whether or not you can set this feature depends on which interface type you are using if you are using wedge interface then the procedure is described below: The extended Header/Terminator keys for Wedge Interface users can be customized by defining them through a simple keyboard setting procedure. For example, the Numeric Keypad keys can be set for use as Headers or Terminators by substituting the default extended keys using this procedure. The type of computer or terminal must be selected before activating the keyboard setting command. Press and release a key to set it. Some characters may require more than one key pressed simultaneously during normal use (refer to the manual of your PC or terminal for keyboard use). The exact sequence must be indicated to the reader in this case pressing and releasing the different keys. Example: If one has to press the "Shift" and "4" keys simultaneously on the keyboard to transmit the character "$" to the video, to set the "$", press and release "Shift" then press and release "4". Each pressed and released key must generate an acoustic signal on the reader, otherwise repress the key. Never press more than one key at the same time, even if this corresponds to the normal use of your keyboard. Press "Backspace" to correct a wrong key entry. In this case the reader emits 2 beeps. Note: "CAPS LOCK" and "NUM LOCK" must be off before starting the keyboard setting procedure. "SHIFT" must be repressed for each character and cannot be substituted by "CAPS LOCK". Check page 31-33 of the "heron reference manual", downloadable near the bottom of this link page; http://www.datalogic.com/_vti_g2_dwnlDett.aspx?idCF=1&idC=44&rpstry=13_ Hope this helps :)
Mar 19, 2007 | Datalogic Heron D130 Handheld Barcode...
Microsoft Comfort Curve 2000 Keyboard Logo
5,366 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
