Question about Danby DWC283BLS Wine Cooler
Fan not working
My wine cooler is not cooling at all. It has three fans inside it and one is not running. I have switched the fan connection at the circuit board and the non-working fan starts right up. Do you think the circuit board could be the problem?
  • troutbum Mar 15, 2008
    My cooler shows and upper deck temp of 73 and 71 on the lower. Compresor is hot but does not seem to be running. I've got the unit unplugged for now fearing a fire hazard. Help?
  • perplexxed Mar 22, 2008
    wine cooler only cools to 65 degrees- fan not working- have unplugged our wine cooler as suggested and plugged back in but that didn't fix the problem. Run activation light keeps turning on.
    Scholar:
  • 90 Answers
Does it have a compressor and does it run? If so there is probably a relay on that board that is bad or only runs with the compressor.
Posted on Feb 16, 2008
My dual zone wine cooler stopped cooling. Power is good and fan is working.
Fan is wired separately from the cooling unit. you may have a wire corrosion issue. take put the shelves, disassemble the back of the unit from the inside and observe the wiring to see if there are broken or corroded wires/connections. R/R if necessary.
Dec 14, 2014 | Magic Chef Dual Zone Wine and Beverage...
Wine cooler not cooling.
Your themostat inside the cooler may be broken.
Mar 19, 2014 | EdgeStar TWR282S Wine Cooler
One side of my Eurocave SoWine Cooler does not work.
As you must be aware there are individual fans in both the compartments. Check if the fan is running in the compartment not cooling. If not, check the wires / connection of fan or replace the fan.
If the fan is working than the issue may be with the THERMO ELECTRIC ELEMENT. you'll need to replace it.
Sep 09, 2013 | The Wine Enthusiast Wine Enthusiast...
It just stopt cooling (wgersdorf@yahoo.com)
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
FR23SL Uses Peltier Cooling - No compressor nor freon....
Luzer - Thanks for the very helpful solution. My cooler has the problem described. When I take off the back and plug it back in, all three fans run, but the unit does not get cold. Is it possible that it needs new fans anyway (like maybe they are going but not moving enough air to generate the effect)? Or woudl it be something else?
Thanks!
Mar 25, 2010 | Emerson (025806803716) Wine Cooler
Emerson FR24RD Wine Cooler
If you are handy with small electrics, or know someone who is...
I had a similar problem and just solved it.
My cooler was leaking and had trouble keeping the proper temperature.
It was also making a buzzing sound which is what lead me to my solution.
BTW - The liquid that was leaking was condensation, probably because the unit was not holding a constant temperature.
Unplug the unit first - no need to get electrocuted.
These units use peltier cooling- essentially a large heat sink with three fans attached.
Click here for more info regarding peltier cooling.
The peltier unit is not repairable, but the fans are; which was what my problem was.
There are three fans on this unit, one on the inside and two on the outside.
Follow these steps to remove them.
  1. Remove the rear cover. It is held on with ten screws. This exposes the two exterior fans and the peltier heat sink
  2. The heat sink is held on with four screws - remove them and pull the heat sink out. The third fan is on a short wire lead, so be careful when removing the heat sink from the body of the cooler.
  3. The two exterior fans are connected to a control panel, the electrical connection is easy to disconnect.
  4. Once all of the wires have been disconnected, you can remove the fans from the heat sink.
  5. The fans are screwed to a mounting plate, which is screwed to the heat sink
  6. You must remove the mounting plate first to expose the screws that hold the fan to the mounting plate. The fans are typical computer case cooling fans
  7. I only needed one fan, but replaced all three because I didn't want to do this job again.
  8. I purchased my fans from Newark.com the prices were better than what I found at the computer websites. Also, these fans are much better than the original and will hopefully last much longer than the three I got from the old ones.
  9. You need one of these and two of these. The total with shipping was around $30
  10. You will need to splice the old electrical connection sockets onto the new fans using wire crimpers or solder them on.
  11. Attach the components in reverse order and power on the unit.
  12. These fnas may move more air than the originals, because the unit seemed to cool much quicker than I remember.
  13. Total time for repair is about 45 minutes
Hope this helps and Good Luck
Nov 26, 2008 | Emerson (025806803716) Wine Cooler
The fan to disperse air inside the STC55800 wine cooler is inoperable.
9721, Boul Métropolitain Est
Anjou, QC, Canada
H1J 3C1
Telephone : 514-374-5343
Fax : 514-374-5344
Oct 04, 2008 | The Cellar STC55800 / STC55810 / STC55820...
Emerson wine cooler /ER2352
Aug 03, 2008 | Emerson (025806803716) Wine Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Danby DWC283BLS Wine Cooler Logo
507 people viewed this question
Top Danby Furniture Experts
Charles T Nevin
Charles T Nevin
Dennis Boxerman
jasbo
jasbo
Are you a Danby Furniture Expert? Answer questions, earn points and help others
