FAILURE TO CONNECT TO WEB SEVER @ 192.168.1.1
CURENTLY RUNNING HN7000 ON 192.168.0.1 I HAVE CHANGED THE LINKSYS ROUTER TO 192.168.1.1 NOW I CAN NOT RELIABLY RECONNECT TO IT. IT SEEMS I CAN'T CONNECT TO THE LINKSYS AT ALL NOW.
ANY THOUGHTS?
  • Anonymous Dec 27, 2007
    I have the same problem can not connect to 192.168.1.1. I am using the HN7000s and the Linksys WRT54G. Linksys was no help.
  • 556 Answers
I am assuming for discussion the following connections of the routers. I am also assuming subnet masks of 255.255.255.0 on both networks. The WAN side of the HN7000 conforms to the requirements of the ISP. The HN7000 has it lan side address set to 192.168.0.1 connected between the ISP to the WAN port and the Linksys from a LAN port to the Linksys's WAN Port. What is the WAN side address of the Linksys? -- It should be either be static 192.168.0.? unique and not in the DHCP range of the HN7000 or should be dynamic. If you utilize DHCP it should be enabled for both routers. The LAN side of the linksys router is 192.168.1.1. If the addresses are set up as stated and the routers are either as described or reversed.
Can you access the internet from the HN7000 by wire?
Can you access the internet from the Linksys reliably?
If either of those two are not true assure the DNS servers are established in the routers for DHCP or in the network adapters if that is preferred -- redo the test above and assure access from both networks is possible using wired computers. Attempt to configure the both routers from a computer wired to each router -- attempt to open configuration 2 times on each router and one time each from both wired machine -- record what works and what doesn't.
I would not be surprised in this configuration that the linksys could only be configured from the a device attached to it. But the HN7000 could be configured from a connection to either router.
Test the wireless connections to the internet as appropriate.
When done report any issues in a comment to this problem and I will assist in determining steps to correct issues. OK?
Posted on Dec 16, 2007
How do i log in for the first time
Basic step for login Linksys Router :
  • remove the router and modem power plug.
  • connect your router with modem.
  • power up router and modem.
  • open the Web Browser - 192.168.1.1
  • username- admin or blank and password- admin.
that's all for login
if looking for more help http://support.linksys.com/en-apac/support/linksys and Router Support for setting up your router setting.
May 19, 2014 | Computers & Internet
Linksys sd208 reset
The reset button is usually at the back of the router. If you are unable to locate it you can reset it using a web based set-up page. Make sure you connect your router to a PC using wired connection and perform the following steps:
Step 1:
Launch a web browser like Internet Explorer.
Step 2:
In the Address bar, enter "192.168.1.1" as the router's default IP address then press [Enter]. If this doesn't work or if the IP address of your router has been changed, enter it instead.
Step 3:
Enter "admin" in the Password field then leave the User name blank. If you have set up a User name and Password for your Linksys router before, enter your personalized credentials instead.
QUICK TIP: For Linksys Smart Wi-Fi Routers, you can enter "http://myrouter.local" on the Address bar to access its web-based setup page.
The router's web-based setup page should now appear from here you can reset the router.
for more info browse this link: http://kb.linksys.com/Linksys/ukp.aspx?pid=80&vw=1&articleid=3676
Sep 19, 2013 | Computers & Internet
How can I configure my router so all of my laptops can connect to the internet? Also, do I need to make any changes to my laptops configuration?
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
3676-001.png 3676-002.png Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Linksys Wireless-G Broadband Router
I need to get into my nat settings
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 08, 2010 | Linksys WRT160N Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
Forgot user name and password
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
How to confiuger it
just go to the web page of the router to configure it
ok at first you go to ther router page connect the router to the pc then
open the internet explorer in the address bar type 192.168.1.1 and he asking to you
user name and password just type in the user name admin and password is admin or password
after then go to the firewall option in that second line there nat option is there
you just change what you want then just go to the save and then go to the maintenance
in that restart is there click on it after two min you get it what you k
Apr 23, 2009 | Linksys Wireless-G WRT54G Router
I need to reserve an ip address on my Linksys WRT54G2 router
The ip address for your Linksys router will be 192.168.1.1 - you can assign an ip address within the same ip range - for example 192.168.1.6
Mar 25, 2009 | Linksys WRT54G2 Wireless Router
Computers & Internet Logo
437 people viewed this question
Alun Cox
David Payne
David Payne
