Question about Adobe Photoshop CS4 Full Version for PC, Mac
After having run demo mode CS4 I have purchased a license. Now after installation I receive a message "license has expired"What is happening?
  • 4 more comments
  • Francesco Marena Sep 25, 2009
    the proposed solution does not work. after unistalling and re-installing CS4 I encountered the same problem . I cannot de-activate the previous version as CS4 will not start and therefore I cannot access deactivation from help
    suggested solution is not working. I have un-istalled and re-installed CS4 twice alway entering the license number with the same result. The un-install process says I must de-activate the program before uninstalling but that is a catch22 I must install first to access the de-activate program from the help menu.
  • Francesco Marena Sep 26, 2009
    I have tried the various solution proposed (sol.II) but nothing worked. Working with Mac I also have Window Xp installed which includes a full working CS4. Do you think that could be the cause of the problem in installing CS4 on Mac? Even if I wanted to keep only one version of PS4(Mac) I could not de-activate the installed Window version as the de-activation key is grayed out.
    that was the first solution proposed. I reply indicating that it does NOT work. I also followed suggestions made by second expert all with no avail. I cannot eliminate the"Period expired " message which prevent from opening CS4 and using help to deactivate original license I also advised that on the same computer( a Mac running OS10.5.8 ) I also run Window XP which is presently operating CS4 without problems. I would prefer using Mac for Photoshop if I could not run the same application on same computer ( I can with CS2/3) but, even if I wanted it I cannot de-activate the Window installation as the relevant key is NOT active
  • Francesco Marena Sep 27, 2009
    I'll wait in case an easier solution is found. On the other hand I can still use CS4 under Window on my Mac
  • Dolores Dickerson Apr 14, 2012
    Hey this is good site with Adobe Photoshop Serial Numbers for all versions, here's the link:
    http://adobephotoshopkeys.eu.pn
    I hope this helps... Try it... its worked for me
  • 284 Answers
If you have purchased the license you should contact Photoshop and make them help you. They took your money, make them earn it :)
There is lots of information on how to crack the program but not much on how to fix a legit users problem or if there is you can't find it for all the cracks.
Give them a ring or send them an email.
Good Luck
Posted on Sep 27, 2009
  • 615 Answers
You need to uninstall the trial version first then install fresh copy using the new license number, and let me know thank you for giving me this opportunity to assist you. I will be working with you to conclusions of this issue. Please see that grant me your approvals by rating my service and I hope that I can serve you again the future.
Posted on Sep 26, 2009
  • Norman Al-Anbar Sep 26, 2009
    You may be correct about MAC you must uninstall the software first before we do anything you need to start fresh, If you cannot uninstall the program we can go to more lengthily process if you did not get any help that can work, if you like we can start uninstall the program and that requires going to the regedit and doing some work are you able to do it or do you like to wait maybe someone can get a better idea? let me know if that work if not we go to the next step. Please see that grant me your approvals by rating my service and I hope that I can serve you again the future. I will work with you in this issue to conclusion
  • 497 Answers
When you attempt to start Adobe CS4 applications, you receive the errormessage: "License has expired," and the application does not start.
This issue occurs when an Adobe CS4 Suite or stand-alone application isinstalled after the public beta version or Trail version of a CS4 application has beenremoved. When you remove the public beta or Trail version, you must also deactivate itbefore you attempt to install the retail version of an Adobe CS4 Suiteor application. If you do not deactivate, the system retains yourserial number information and automatically enters it into theappropriate spaces in the Adobe CS4 setup application.
SOLUTION:
Replace the Adobe CS4 beta or Trail serial number with your retail serial number.
1. Remove the CS4 application.
2. Download and run the Adobe CS4 Clean Script from the Adobe website at
http://www.adobe.com/support/contact/cs4clean.html
3. Locate and remove any remaining cache.db files:
  • On Windows XP and Windows Vista, the cache.db file is located in Program FilesCommon FilesAdobeAdobe PCDcache
  • On Mac OS X, the cache.db file is located in Library/Application Support/Adobe/Adobe PCD/cache
Important: After you delete the cache.db file, you must re-enter the serial numbers for your other existing Adobe products.
Reinstall the Adobe CS4 Suite or stand-alone application and enter the serial number from your retail version.
Check these links for more information:
http://kb2.adobe.com/cps/402/kb402003.html
NOTE: Applicable for CS4 also.
http://kb2.adobe.com/cps/403/kb403995.html
http://kb2.adobe.com/cps/494/cpsid_49485.html
Good Luck!!!!!!!!!!!!!!!
Posted on Sep 25, 2009
  • Mitesh Kr Anand Sep 26, 2009
    Did you try using the Adobe CS4 Clean Script from the Adobe website at?
    http://www.adobe.com/support/contact/cs4...
    Run it to clean the trail key.
  • 395 Answers
Hi, This is what you should do, uninstall the photoshop program and reinstall it again. Then input the license key this time. This should solve the problem. Just in case you still have the same problem then you shoul contact the software vendor. Hope this helped. Regards
Installed adobe cs4 on my mac, but when i try to start the program a prompt says, license has stopped working. please help me figure this out. thanks
Hi! usually it takes one year for the license expired. You need to check if your adobe installed has expired already or not. if that's the case you have to renew.
Jun 25, 2011 | Computers & Internet
License expired
Licenses don't expire for Adobe products unless you have a dodgy version installed. Start the application up again and a window will pop up asking you for a serial. Input the serial that came with the software when you originally bought it. This is usually found on the dvd casing. After you've entered the key, you should be back in business. :)
Feb 09, 2011 | Adobe Photoshop CS4 for PC
I get a message that says license has expired for
hi,
If the message appears that your license has expired for some songs, then it means that you have purchased the music online(or free trial) only for a particular period of time (say 2 weeks). after that particular time, you have to purchase the music from the online store where you got it. The rules change according to different countries. Please specify your country to know more and give me a good rating of you find this advice as helpful!
Mar 30, 2010 | Sony NWZ-E438F Digital Media Player
MESSAGE COMES UP AND SAYS YOUR LICENSE HAS EXPIRED AND I ONLY BOUGHT THIS CS4 COPY TODAY
Hello. Return it ASAP and tell the vendor what you are experiencing. There is no fixing it
Oct 15, 2009 | Computers & Internet
Please someone give me an installer of adobe photoshop cs2 or cs3 or cs4 please. i cant purchase it T_T please please
You would still need a license after the installation. As that would mean piracy if you will use a non licensed copy.
You can use a test installation which would give you a free 30-day trial license.
Aug 26, 2009 | Adobe Computers & Internet
CS4 Master Suite License Expired
If it is a legitimate copy then you can call adobe support
If not then I am sorry but I cannot help you.
Aug 14, 2009 | Adobe CS4 MASTER COLLECTION WIN E Full...
My MP3 player displays "License Expired" on the screen.
If you let your subscription to Rhapsody expire, you will get this message. If you didn't let your subscriptino expire then you will need to synch the files from Rhapsody itself back onto the player - the licenses have to be renewed once a year for some songs - once a month for others. If your subscriptino ever expires, you can no longer use the songs.
Feb 22, 2009 | SanDisk Sansa Clip MP3 Player
Error message: "Cannot play; the license is expired"
I have the nwz-a816 and if have had this issue a couple of times... It seems to give me that message on songs I have downloaded from Napster... I just connected it to the computer that the Napster application is on and it corrects this problem... Hope this helps...
Jan 20, 2008 | Sony NWZ-A816 Digital Media Player
Adobe Photoshop CS4 Full Version for PC, Mac  Logo
269 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
