Question about Reddy R70ET Utility Heater
Heater will not turn on
Hi I have a Williams Wall gas heater that has a lit pilot but will not come on? Can You help me please?
  • 1 more comment
  • Anonymous Dec 17, 2007
    Hi, I have a Williams furnace wall heater. This heater had been working fine but recently stop working. The pilot lit is still on but when I try to turn it on, it does not working. I did change a new thermostat, but it still doesn' t work. Please help me to solve this problem. Thank you.
  • UB 40 Dec 19, 2007
    I replaced the generator but now if i blow out the pilot light the gas stays on and if I try to turn on my wall heater it blows out the pilot and turns off the gas.
  • Anonymous Mar 23, 2014
    How do I add a wall thermostat to a wall mount Williams model 35 GV 3 heater Can any one please help
    Sergeant:
  • 288 Answers
If these are newer units 5 years or newer, there may be a thermal safety device up near the top. Follow the wires to find it. if you have this, bypass it by connecting the two wires going to it to each other and not the little disc. If this does not get the burner to ignite, then the next culprit or you do not have one then next is the pilot generator. This is the round cylinder next to the pilot flame. It and has 2 wires connecting to the gas valve. Remove it from the pilot assembly, it usually is just a clip, unscrew the 2 wires and pick up a new one. The connection on the gas valve has these wires labeled as TP for thermopile (dont ask, I don't know) replace in reverse as removed.
Posted on Dec 18, 2007
2 Suggested Answers
  • 2976 Answers
SOURCE: williams wall heater
It can be shut off, but do not just blow it out.
Posted on Mar 04, 2009
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
I have a williams wall heater in the garage model #3003612 the pilot wont stay lit what shall i do?
shut off gas use compressed air blow into and around over any tube. retry the pilot
Nov 01, 2015 | Williams Heating & Cooling
My wall heater is a williams gas wall heater and I just had a question is the pilot always suspose to be lit the main is not lit but when it is off there Is still a flame that's on Ithink its the pilot is...
All gas appliances have a constant on pilot light.This keeps you from having to light it everytime it goes on. The pilot flame is small, and usually mostly blue in color. If there is any yellow or orange color in the flame then the jet is dirty, which can cause a malfunction ( just thinking this could be handy to know!).
Thanks for using Fixya!!
Nov 09, 2013 | Heating & Cooling
Where is the orifice on a williams wall gas heater 290622
Where the pilot is unscrew pilot tube from pilot assembly and inside there it is
Feb 26, 2013 | Williams (5009622) Ceramic Gas Wall...
Williams wall furnace m#5009622, pilot light stays lit but main burner will not ignite
Check your thermostat most times all u need to do is tweak with the lever or on/off switch.
Nov 18, 2012 | Williams (5009622) Ceramic Gas Wall...
I have had the gas valve, the pilot, and the wall thermostat replaced. I know it's ridiculous because I have spent more than it is worth. The pilot is lit and the heater will still not come on. What...
Have you got the knob turned to the "ON" position? Are you getting 24 volts to the gas valve? Has the gas valve solenoid got continuity between the 2 terminals?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 08, 2011 | Williams (5009622) Ceramic Gas Wall...
Hello i have a williams wall Furnace model#25-35-50. I need to know if its a base board heat and also if you could tell me which wires are which. 1 red and 1 white
What you have is a Direct Vent, Gas WALL Heater. It is normally mounted about 6" off the floor on an exterior wall (since it has to be direct vented out). Not sure what the red and white wires are for, but suspect it's for the optional thermostatically controlled blower connection.
In any event, to help you install this heater properly, I have included a link to the Owner/Installation Manual, which should provide all the information you need to complete the installation correctly.
http://shopfnc.com/pdffiles/williams2man.pdf
You can download and print the manual for future reference.
Feb 26, 2011 | Williams 3003622 Ceramic Wall Mounted...
How do you turn the pilot light back on? This is an older model, probably about 10 years old or so.
Move the gas valve knob to the PILOT position and press down on the knob. You will be pressing down on a spring loaded safety magnet. Now light the pilot and keep holding down the knob till the thermocouple gets hot enough to produce electrical current and hold that spring loaded magnet in. This is your safety device. If the heat gets too hot the furnace has a fuse in line with that magnet.
When the pilot stays lit by itself without you having to hold down the button then advance the knob to the ON position. Then go to the wall thermostat and turn on the heater.
HOW IT WORKS: WILLIAMS WALL HEATER
Nov 11, 2010 | Williams 6508732 Gas Heater
How do I lite a wall room heater
First, turn off the gas valve for at least 5 min and ventilate the room. Most wall heaters are lit the same as a water heater. Find a red button to push or turn the gas valve knob to the pilot position. While pressing the red button or the gas valve knob, hold a match to light the pilot flame. After it lights continue holding the knob for one or two minutes. If the flame goes out when you release the knob the thermocouple is probably bad.
Oct 18, 2010 | Williams (5009622) Ceramic Gas Wall...
I HAVE A wILLIAM wALL hEATER. tHE PILOT LIGHT IS
The blower is heat activated, it takes more than the pilot. If the burners are on, verify power to the unit.
Jan 01, 2010 | Williams Heating & Cooling
Reddy R70ET Utility Heater Logo
2,054 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
