Question about Refrigerators
I made a tiny hole in my Haier's icebox, now it wont freeze
I accidentally made a tiny hole in my haier's icebox amd air started leaking out. fixed the hole but now the box doesn't freeze. help.
  • Refrigerators Master
  • 1,606 Answers
Best advise is to replace the refrig , unless the hole is in copper tubing . If copper , then a torch and silver solder will be the fix for the hole . Call a reputable repair company and have them come out and recharge the refrig . If the hole is in aluminum tubing , replace the refrig . There is no permanent fix for aluminum .
Posted on Sep 25, 2009
Testimonial: "Thanks that was helpful, but i guess i will have to buy a new one then."
My haier A.C portable unit is freezing up
Hello, the unit will freeze up from one of two reasons...either a low refrigerant charge due to a leak or the evaporator coil is dirty and must be cleaned with a coil cleaner.
May 03, 2012 | Haier Mechanical Air Conditioner HWF05XC7
Hello, I have a Haier ESA3109 10000 BTU ThruWallWindow Air Conditioner, and some how in moving, a hole was punctured thru one of the coils. We fixed that problem but all the ac freon has leaked out. How...
Its not that simple You need to vacume the system down before you can chagre it again. You will need a tech to do that for you . sorry but thats the way its done
Jul 23, 2011 | Haier ESA3109 WallWindow Air Conditioner
I i`ve got a haier split type air conditionner model HSU12XCA on R22 gaz which barely cools and freezes after a while. The suction pressure is at 120 PSI and it is freezing on the liquide line. I`ve clean...
The unit has a leak and is low on freon...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Haier HSU12XCA Cooling Only Mini Split Air...
I have a Haier ESA406K 10,000 BTU's that just
sounds like you have a small refrigerant leak which would at first result in the evaporator coil freezing over, then eventually not working at all.
Jun 11, 2011 | Haier Heating & Cooling
My haier freezes over the front how do i fix it?
Clean evaporator, and condenser coils.
check for low air volume.
Must be blowing strong.
Air volume is my guess.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 05, 2010 | Haier hwr10xc6 Air Conditioner
Haier ac unit keeps freezing in the front where the filter i located how do i prevent this
Freezing is a bad sign... but dont give up yet...
these are the signs that will cause freeze up...
dirty filter
t'sat not shuting off
cooling a room too big for the unit
settings at max but room is still hot
and the worst case... a/c leaking freon..
the leaking part is bad cause if you get someone to put it back in next year (or sooner) you have to call em back to recharge it again...
if everything checks out then it is the leaking freon... throw away...
what you pay $100 or so???
hope this was helpful
Apr 05, 2010 | Haier Mechanical Air Conditioner HWF05XC7
There is a tiny hole in the inside back and the freon gas leaked, is this repairable?
Hi:
It should be repairable. You would need a Heating/ Air Conditioning repair shop to silver solder the hole closed, and possibly sweat on a valve to evacuate and refill the system. I would call around and ask if the shops do this sort of thing. I had a similar repair done on a window air conditioner, and it saved me money!
Nov 17, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
My haier a/c window unit is spitting water through the vent
check the filter located behind the front panel it usually snaps out also make sure the drain holes on the out side bottom of unit are not stopped up and that the unit is leaned back slightly for drainage freezing is a sign of low air flow or low on freon the coil actually gets colder when freon starts to leak out hope this helps with your problem
May 15, 2009 | Haier hwr10xc6 Air Conditioner
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
